Is a Torque wrench absolutely necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Apr 29, 2010.
  1. Apr 29, 2010 at 1:30 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Under tightened - Comes loose
    Over tightened - weakins the bolts strength
    michael roberts likes this.
  2. Apr 29, 2010 at 1:44 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    +1!
    I like to use a torque wrench because it takes the guess work out of the equation. The click type is the best for most jobs. But for really critical bolts I like to use the bar type.
    Over time the click type can go out of calibration.
    Craftsman makes a very reliable and affordable bar torque wrench.
    My click type are all Snap-On.
  3. Apr 29, 2010 at 1:48 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    If you don't want to be called a "hack," I'd get one!
  4. Apr 29, 2010 at 2:01 PM
    WILLIAM ROBERT
    WILLIAM ROBERT Well-Known Member
    Edmonton
    it's blue
    I use torque wrenches as well, rims and brake drums can warp very easily, depending on how big a guy you are or the size of the bar you are using. One thing to note is that all torque wrenches are not built the same, you get what you pay for. It is also important to note that most torque wrenches are only accurate within a certain range of their torque scale(middle). The cheaper ones can be out of spec as much as 15% at the very bottom and top of their scales. So, that means that if you are using the torque wrench to tighten your lug nuts to say 90lb/ft then a wrench that is good for 50-150lb/ft is a safe bet.
  5. Apr 29, 2010 at 2:02 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Let me know if you want better replacements. I have all the ones I ordered and used from LA Wheel & Tire (much better than the toyota crap) for sale since I just bought new wheels.
  6. Apr 29, 2010 at 2:17 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    well I got my torque wrench, but some stuff came up, so I'll have to wait until tomorrow morning to start :( Better to start fresh anyway.
  7. Apr 29, 2010 at 2:25 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ^ yep sure do!!
    always uses a torque wrench when required. now, if were talking about the brass fitting in my TRD CAI, i can see passing on, but when its the ubolts for my leafs..torque them down!
    as others have said, HF has a 1/2 drive one for like $15, lifetime warranty.
  8. Apr 29, 2010 at 2:56 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    If you have a small bolt, use a small 1/4" drive ratchet, for most automotive work use medium 3/8" drive ratchet, for big suspension bolts use a 1/2" drive ratchet and breaker bar.
    Using common sense and the right tool for the job makes it easier and faster, whenever torque needs to be specific, use the torque wrench.
    When you use the torque wrench the first time, try it on your wheels and you will probably find out that you're overtorquing things, do the same in a few projects and you'll develop the habit of using it due to the fact that you over torque things regularly.
  9. Apr 29, 2010 at 2:57 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    It makes me happy to see so many say that a torque wrench is the right way to go.
    I even torque oil drain plugs! But you know what? The cars that only I service, you can break the drain plug loose with a wrench and take it out with your fingers. Even when the vehicles have over 250K on them. Unlike the Honda I worked on today that the lady takes to lube shops. The plug came out with the threads. Oh, and it was low on oil with a variable valve timing fault.........
    Spark plugs are another issue. You will see torque values of 13-30 foot pounds depending on the application. All about materials and sealing style.
    Many shops keep lug nuts and studs in stock. I have a hard time remembering when I had to replace one on any vehicle I work on with any regularity. If they have just had new tires or a service elsewhere, look out.
    The comments people have made about warping drums and rotors is spot on. Even have seen repeated failures of hub style bearing caused by the use of an impact to install. Go figure. The XXX torque value actually helps set preload in some designs.
    I own four. I am switching over to the new digital ones now. (already have one) They self calibrate. You would be shocked at how far off a mechanical wrench can get over time.
  10. Apr 29, 2010 at 3:04 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I should use a torque wrench more often but my elbow is calibrated pretty accurately -- I have a good feel for an approximate value. Any engine work (especially spark plugs or cyl heads) or suspension work, I definitely use the tq wrench.
  11. Apr 29, 2010 at 3:35 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    What is HF?
  12. Apr 29, 2010 at 3:37 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Harbor Freight
  13. Apr 29, 2010 at 3:40 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I have had one since the first time I broke a water pump bolt years ago. You will only do that once before you learn. I can't imagine not having one with newer engines and parts. Spend money and buy a good one, it will last you a lifetime if you take care of it. I usually buy Craftsman tools just for the warranty and ease of returning them.
  14. Apr 29, 2010 at 6:42 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    the reading a torque wrench gives you is just a ball park. some engineer figured a fastener of a certian size needs to be TENSION some amount. they test them on a tool called a skidmore, and note the torque needed to reach the tension. then they tell us. this is in a perfect world. we add antiseize, it acts as a lube, numbers get wacked. rust? wacked. having said that..rebuilding motors? i use a torque wrench..same for wheels. some things, i just tighten down.
  15. Apr 29, 2010 at 6:51 PM
    #35
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Bolts and studs are designed to be stretched a particular amount when they are tight. Too much, they can break or strip the threads. Too little, they will either loosen or not hold the parts tight enought (eg.,a cylinder head will leak and cut). Guessing at torque on suspension parts is attempted suicide.
  16. Apr 29, 2010 at 6:56 PM
    #36
    aficianado
    back to bone stock.
    yea, you are right...but i tested bolts for months on end. big fancy torque wrenches, and a skidmore. day in and day out. just testing nut/bolts before we put them into service on a steel bridge. you would be surprised the range a bolt has before it moves from the elastic ductile zone to yielded.
    in general, if you can get a torque wrench on the target fastener, do it. i have a slew of them. one is an 8' snap on (from work).
  17. Apr 29, 2010 at 6:58 PM
    #37
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Necessary? No. A good idea? Yes.
  18. Apr 29, 2010 at 7:42 PM
    #38
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    I have broken and stripped so many nuts and bolts, with the corresponding extra work, delays, and cost, that I definitely recommend a good torque wrench, if you do much automotive work you probably even need 2, one for lower levels of torque (inch-lbs) and one for the heavier duty stuff, lug nuts, suspension components, valve cover bolts, spark plugs, and yes, oil drain plugs. Everything in a service manual with a torque value, it is there for good reason, and having things torqued correctly is worth a lot, peace of mind that it is tight enough, and avoidance of making a job a lot more complicated due to breakage. My manual sense of how tight things should be is a lot better than it was years ago, but I don't trust it.
    So, yes.
  19. Apr 29, 2010 at 7:50 PM
    #39
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I'm taking everyone's advice, and already bought a torque wrench. My thing is about EVERYTHING being torqued to spec is. . . take my motocross bike for example. Every nut and bolt on that thing has a torque spec, but there is absolutely no need to torque any bolt on it(besides the engine).
  20. Apr 29, 2010 at 8:06 PM
    #40
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
