Is a Torque wrench absolutely necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Apr 29, 2010.
  1. May 1, 2010 at 4:34 AM
    #61
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Lots of good experiences in this thread..but I don't think anyone answered why torqueing to spec. is so important...
    Tightening into aluminum is obvious: spark plugs easily strip out aluminum heads when overtightened. Some people get the 'feel' and know when to stop when just when the compression washer is crushed, but if you rarely change plugs a torque wrench can be a life safer.
    Some bolts should be tightened into the elastic range of the fastener (head bolts, for instance). That way they can stretch a little as the parts expand with heat, then tighten back up as they cool, without coming loose. Torqueing is the ONLY way to make sure that happens. Lots of of suspension bolts are the same way (and are frequently 'use once' bolts because they won't stretch the same way again, incidentally.)
    Others need to have all the bolts in a pattern tightened as close to equal as possible, like wheel lug nuts to prevent warping brake rotors.
  2. May 1, 2010 at 4:41 AM
    #62
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's dangerous: you really need to know the design torque. The engineer sets the torque based on a lot of conditions, not just what the fastener can handle. Should look in the repair manual and use what the engineers spec'd that fastener for.
    Just think of this hypothetical: using grade 8 fasteners in mounting flange for a plexiglass window; tighten them to spec and you'll crush the window. Less obvious would be if it was aluminum: you could squeeze the aluminum and it will cold flow around the fastener and work loose in service.
  3. May 1, 2010 at 5:05 AM
    #63
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That's a good point. I've also noticed a lot of people don't use torque wrenches correctly: be sure to keep the handle centered on the pivot when using a beam torque wrench.
    Also be sure to STOP when an adjustable torque wrench clicks! It makes me so mad when I see so-called shop "techs" just keep on grunting long after it clicked.
    With any torque wrench, calculate a compensation factor for lateral extensions (like claw foots) that take the center of moment away from the center of the square socket attachment point.
    Finally...beam wrenches are really rugged, as long as the read-out plate is intact just bend the pointer back to zero and go. But the adjustable tools lose calibration very easily, especially if dropped. VERY IMPORTANT to back off adjustment to zero to relieve pressure from the spring when storing them. I'd stick to beam-type wrenches for critical fasteners like head bolts and suspension bolts, unless you've calibrated your adjustable recently.
  4. May 1, 2010 at 6:50 AM
    #64
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The bottom line is that if you are really going to do any work right you need a torque wrench. I have both a foot/lb and and inch/lb wrench. I'm a torque wrench Nazi and use them religiously on everything. There are many reasons as others have mentioned from making sure the component is fastened on tight enough to hold but not enough to cause stress and damage. I also believe in using anti-seize paste on most everything. This helps make sure the poundage is accurately being applied and so the the bolt/nut comes off when needed.
    For sure use a torque wrench and anti-seize on lug nuts and spark plugs. I had an Acura that has wheel shimmy after a tire shop did a free rotation. I double checked the nuts with my torque wrench and found that a couple were under specs and others were over. I never removed the wheel but just loosened/tightened the nuts to specs. The shimmy went away completely. I would never even think about putting in steel spark plugs with crush washers in an aluminum head without my inch/lb wrench.
    Also a torque wrench is usual longer and is a good substitute for needing a breaker bar in many cases.
    One more thing. Always store the torque wrench with the setting on the lowest poundage. This keeps the spring inside the wrench accurate.
    (Everyone is entitled to my opinion)
  5. May 1, 2010 at 8:24 AM
    #65
    bryant8
    bryant8 Active Member
    Dallas
    2008 Black Double Cab Long Bed
    TRD CAI, eBay Fog lamps, LED bed lights, 12V bed plug
    IMO its very important to have one in your tool box. It only takes a few seconds to get the right torque for your application. Do it right the first time.
  6. May 2, 2010 at 3:48 AM
    #66
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How many of you put the torque wrench back to ZERO when you're done using it?
  7. May 2, 2010 at 3:52 AM
    #67
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    :wave:
  8. May 2, 2010 at 6:28 AM
    #68
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  9. May 2, 2010 at 6:35 AM
    #69
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x3.............if ya dont.,...calibration will get outta whack.
  10. May 2, 2010 at 7:59 AM
    #70
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    x4 but that is also one reason I am going electronic. They recal every time you power on.
  11. May 3, 2010 at 5:44 AM
    #71
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    I agree with most of you post but the part quoted.
    In a jam use whatever you find, but a breaker bar is less "springy" than the torque wrench and more effective than it.
    My 1/2" breaker bars are next to the 2 TQ wrenches in the truck toolbox
    Also a 24" long 1x1 square pipe is there too so it can add some leverage to the breaker bar when needed
  12. May 3, 2010 at 5:53 AM
    #72
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I used my torque wrench on everything but the top three nuts on the front shock housing. It wouldn't fit (nb4thatswhatshesaid)
  13. May 3, 2010 at 6:58 AM
    #73
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I changed out my spark plugs yesterday without the aid of a torque wrench.
    Reading this thread makes me feel not so good.
  14. May 3, 2010 at 7:57 AM
    #74
    Janster
    Jandy
    Lancaster, PA
    Spark plugs are one of those 'more critical' items where you want to use a torque wrench. And that's simply because if you go too tight, you could mess up the threads in the block - and that's a major headache to fix.
    Why not take the spark plugs out and put them back in with the proper torque (and anti-seize)? YOu're better off doing that now....then you are waiting till the next time you have to pull the plugs.
  15. May 3, 2010 at 7:59 AM
    #75
    bambooshoots
    Kevin
    College Station, TX
    Antiseize I did use.
    Man, the thought of going back to the plugs on the driver's side....*shudder*
  16. Feb 22, 2011 at 12:12 PM
    #76
    BCooley
    BCooley Member
    Laguna Beach
    06Prerunner
    None
    i'm going to replace my spark plugs this weekend and somebuddy gave me a tip: 'you dont need a stinkin' torque wrench! just "finger tightened the plugs" then finish it off with a half turn with your 99cent ratchet. is he right? or is he really my buddy? pls advise.
  17. Feb 22, 2011 at 12:16 PM
    #77
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's kind of an old method of doing it. Honestly, I just changed the plugs in my motorcycle this way, finger tight and 1/4-1/3 turn with a wrench. Toyota gives you a torque spec, why not use it and do it right?
  18. Feb 22, 2011 at 12:17 PM
    #78
    Janster
    Jandy
    Lancaster, PA
    And you listened to them?
    :facepalm:
    Do you really think that all fingers & hands are created equal? That all fingers and hands can 'finger tighten' at the same rate?
    NOOOOOoooooooooooooooo
  19. Feb 22, 2011 at 12:18 PM
    #79
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I don't put it to zero, I put it to the lowest setting which is 20 ft-lb. But yes I do this every single time.
  20. Feb 22, 2011 at 12:27 PM
    #80
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    whats the difference between the one that have a setting and the ones that have a needle and are a beam type torque wrench...the needle ones are way cheaper but im wondering if they wear out or something???
