Is a Torque wrench absolutely necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Apr 29, 2010.
  1. May 2, 2021 at 1:37 PM
    #121
    ScodyDood
    ScodyDood Member
    Sean
    2013 White Tacoma TRD Sport
    N/A (Yet ;})
    Soooo is a 3/8in drive with 20-100ft/lb or a 1/2in drive with 50-250/lb more useful????
  2. May 2, 2021 at 1:37 PM
    #122
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    For suspension work!
  3. May 2, 2021 at 1:41 PM
    #123
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Kyitty likes this.
  4. May 2, 2021 at 2:10 PM
    #124
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The 1/2 inch drive is more useful. Both is best.
  5. May 2, 2021 at 2:13 PM
    #125
    eon_blue
    Azusa, CA
    Both, but if you have to pick one, 50 - 250lb 1/2" drive
    Things like the cv axle nut, upper ball joint nut on SPCs, carrier bearing stake nut etc require upwards of 150 - 170ft lbs.
    I have the Pittsburgh 20-150ft/lb 1/2" drive and a Tekton that goes up to 250. Both are inexpensive and have served me very well
    Kyitty likes this.
  6. May 2, 2021 at 2:19 PM
    #126
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    Hell yeah! Thanks guys! I’m not trying to take a chance so I’m sending it with a torque wrench for the bigger things I’ll be doing with the truck ‍♂️
  7. May 2, 2021 at 2:27 PM
    #127
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Unless your putting together engine internal, then no. The rest of these dorks just love to overly complicate bolts.
  8. May 2, 2021 at 2:34 PM
    #128
    Waasheem
    Waasheem
    2007 xrunner
    Matco makes a torque adapter. Bta150 $144 3/8 drive, with a good range of 10-150 ft lb. That’ll get you low enough to do spark plugs and high enough to do lug nuts. Close as it may get for one to do it all. Also a 1/2 drive cta250, $167, 10-250 ft lb. Prices are from last year so they may have changed.
    I own 2 precision instruments torque wrenches, and very rarely ever use them. If I'm doing a head gasket, I definetly use them. Otherwise they sit in their cases.
  9. May 2, 2021 at 2:35 PM
    #129
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    And eventually I got a 5-70 ft/lb.
    ScodyDood[QUOTED] likes this.
  10. May 2, 2021 at 2:45 PM
    #130
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    Yeah I mean...I’m somewhat new to working underneath my truck and don’t wanna have shit falling off one day when I’m driving so I’d rather be safe than sorry I guess...
  11. May 2, 2021 at 2:46 PM
    #131
    Rockslide
    Rockslide Well-Known Member
    2019 Cement Tacoma Off Road
    Regardless of which size you go with, don't forget to invest in some lubricant as well. I've used ARP assembly lube for years, and I don't use my TW without it.....
    ScodyDood likes this.
  12. May 2, 2021 at 2:46 PM
    #132
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    It’s all a learning experience for me, maybe I won’t use it all that much but peace of mind is good by me
  13. May 2, 2021 at 3:55 PM
    #133
    ken01976
    ken01976 Well-Known Member
    St Louis MO
    2014 Tacoma TRD Sport 4x4
    Holy dead thread revivalist. What sort of necromancy is this?
  14. May 2, 2021 at 4:02 PM
    #134
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    I searched torque wrench and revived the dead thread lmfaooo
  15. May 2, 2021 at 4:41 PM
    #135
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    My uncle Pete was an old school auto mechanic who never relied on a torque wrench for anything. Said if you wasn't working on jets, airplanes or rockets, it was a tool designed to wring cash outta folk who can't grasp the physics of fastening things.
  16. May 2, 2021 at 5:21 PM
    #136
    ken01976
    St Louis MO
    I’m guessing your userid applied to him as well.
    spitdog likes this.
  17. May 2, 2021 at 6:10 PM
    #137
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I'd say if you're fastening to aluminum or working with torque-to-yield fasteners a torque wrench is a must. I personally have three 1/4", 3/8", and 1/2" drives and I use them, maybe not 100% of the time, but they do get used on critical fasteners. I've also found called out torque spec errors a couple of times.
  18. May 2, 2021 at 8:18 PM
    #138
    ScodyDood
    ScodyDood Member
    Sean
    N/A (Yet ;})
    I’m not working on rocket shit and I feel I have a good sense on how to tighten things but I wanna take care of my truck! It’s the hope I don’t f%#k nothing up!
  19. May 2, 2021 at 8:25 PM
    #139
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I know I don't need to say it because everyone knows this, but I'll say it anyway. :D
    Every torque wrench needs a buddy. Torque for tightening things, breaker bar for loosening things. Never loosen with the torque wrench.
    Just another thing I learned the hard way. :anonymous::anonymous:
    mdywv and GOLIVER0131 like this.
  20. May 2, 2021 at 8:41 PM
    #140
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I like to tighten every fastener to the listed torque spec. Tight is tight but the click helps me sleep at night.
    Mully likes this.
