Is adding fuel stabilizer with HEET harmful?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Satchmo!, Oct 20, 2024.
  1. Oct 20, 2024 at 9:08 AM
    Satchmo!
    Satchmo! [OP] Well-Known Member
    2019 Tacoma TRD Off-Road
    Hello all,
    I wont be driving my truck as a daily driver anymore. It will be sitting in the garage for +6mths moving forward. I wash/waxed it, detailed interior (so no food), pumped up the tires to avoid flat spots, peppermint on rags under hood and spare tire for rodents, keeping battery hooked up with a NOCO 1 hooked to it every other week, fuel tank is topped off full.
    My main concern is I put 2 bottles of HEET (forgot I put one in and accidently put a 2nd in) after I filled it up about a month ago. Did not realize HEET is not a fuel stabilizer. Will it hurt anything if I add a fuel stabilizer to a full tank with already 2 bottles of HEET in it?
    Also if you guys have any additional tips or if I am missing anything else critical, I would appreciate the info.
  2. Oct 20, 2024 at 9:23 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I'm not sure any fuel additive will assist over that period of time. I'd be more inclined to drop it down to 1/4 tank and then fill with
    fresh quality gas after you start driving it again. Why don't you just leave it at my house and I'll drive it around for you a few times
    a week....
  3. Oct 20, 2024 at 9:25 AM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    I think you will be fine. I have a couple vehicles that wont get driven for months at a time and all I do is keep them hooked up to battery tenders. Never had an issue with fuel. They both take 93 but I for sure have had gas sit in atleast one of them for over 6 months and it has been fine
    ace_10, SGJarrod, Chew and 1 other person like this.
  4. Oct 20, 2024 at 9:28 AM
    Bishop84
    Bishop84 Well-Known Member
    Thats pretty much it.
    I'd disconnect the battery with the noco on it for that long, but gas is pretty good now, I wouldnt stress about it beyond what you've done.
    I typically remove the battery when its stored that long incase the battery starts to leak, it can leak somewhere someone can see it.
    ERod27 and Chew like this.
  5. Oct 20, 2024 at 9:33 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I'd leave tank full so there’s less air above it for water to condense from.
  6. Oct 20, 2024 at 9:44 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Fill it up all the way with ethanol free and put a battery tender on it.
  7. Oct 20, 2024 at 9:45 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Been doing it for decades. Run tank down, add stable and a can of techron, the quicksilver Merc stuff is good also. Fill with non ethanol or ''powersport'' fuel [usually 89 but no ethanol]. Make sure your brake fluid is fresh every couple of years. Do NOT wash it and then store it, wash it a week or so before storage and drive it to make sure ALL water is evaporated inside panels and such, standing water is bad. Fresh wax is good, cover it, anti mice devices and such are VERY good, plug any intakes. I run mine til hot, [drive it don't let it idle] pull into my spot, shut it off and immediately spray about a 30 second shot of kroil into the tailpipe and immediately plug it with a oil soaked rag. I want it to evaporate off inside the system and recoat as much as possible. Never had a sensor fail, always starts right up in spring.
    If there is a water drip point in the muffler, Kroil may drip from it so put a little pan under it or plug it up with a bit of ductseal.
    I always toss mothballs [real ones, not the fake crap] inside and inside the airbox so mice don't find it appealing.
    And yes, battery tender or pop one lead and float charge with a tender that only charges if the voltage goes below a certain point. Overcharging is just as bad as under and make sure, if you have cells you can check the electrolyte level in, to check it periodically and refill as needed with distilled water only.
  8. Oct 20, 2024 at 9:53 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Learning some stuff about long-term truck storage here.
    I use a battery tender for my riding mower...so I definitely agree with that suggestion.
    Moth balls is a good idea too.
    The gasoline part...which way to go??? lol
    I'll come back here if I ever have to park my truck for long periods of time.
  9. Oct 20, 2024 at 10:01 AM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I store my Jeep over the winter (4+ months).
    • I second ethanol free gas, and a full tank.
    • Disconnect the battery.
    • Along with moth balls, put a few dryer sheets inside. Keeps it smelling fresh, and I've read mice don't like it?
    • And mice bate under it!
  10. Oct 20, 2024 at 10:08 AM
    fxntime
    Some sticky traps with a peanut [oils from peanut butter can release a mouse] in the center allows you to see if mice are gaining access to your storage area. I put a little dam of cayenne pepper around each wheel, mice do NOT like tracking thru it and I don't see too many mice with Sombrero's here.
    I'd get along well with Slo Poke Rodriguez though.
    grogie and TacoTime55 like this.
  11. Oct 20, 2024 at 10:11 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    Friggin' Hilarious!
  12. Oct 20, 2024 at 10:19 AM
    Load_Elevation_Fail
    Load_Elevation_Fail Active Member
    Rob
    Oklahoma
    2021 Tacoma TRD OR
    5.29 Gears 3” RC Vetrex Coilovers RC Speedo Calibrator Borla Exhaust OTT Tune 33” KO2s TRD Rims K&N 1.5” Spacers Clazzios Ultra White Interior LEDs Garmin Mini 2 Wide Cup Holders Cali Raised Blue Tint Wide View Mirrors Cat Shields Tailgate Lock Bed Mat Lexus Front Diff Drain Plug RAV4 Stereo Knobs Toyota Metal Oil Filter Housing
    I’ve stored vehicles for months to years being in the military. One thing I do, and some might say it’s not necessary, is put the vehicle on jack stands. Too many times I’d come home to flat spots on my tires. Takes all of 30 mins and harbor freight has them fairly cheap.
    PoolFixer and TacoTime55 like this.
  13. Oct 20, 2024 at 11:08 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    Good point.
  14. Oct 20, 2024 at 11:37 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Adding on, also if you have less that a 1/4 tank it leaves part of the fuel pump and sending unit exposed and they will dry out and could cause the sending unit not to work.
    I have been there before FYI
  15. Oct 20, 2024 at 11:55 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's literally just a bottle of methanol. Doesn't really do any harm but unless you're in some crazy temps it's also not useful either. It has to be pretty damn cold to freeze gasoline
  16. Oct 20, 2024 at 12:00 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I just air up to 45 lbs in each tire. Simple and easy.
  17. Oct 20, 2024 at 12:12 PM
    fxntime
    It's not about the gas, it's about the water in the gas and it separating out and freezing or causing corrosion.
    It's why for storage especially, non ethanol gas is a better choice then even premium with ethanol.
  18. Oct 20, 2024 at 12:24 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Toyota’s agency for aid organization and NGO vehicle sales, Toyota Gibraltar Stockholdings, has a pamphlet with their recommendations for short- and long-term vehicle storage.
    There’s some good advice in it.
    And the main TGS website is absolutely worth a visit too for those who haven’t seen it yet.
  19. Oct 20, 2024 at 4:39 PM
    GearHead899
    Justin
    Ocean View, NJ
    Peppermint oil for mice. At my old house I had issues with them. Moth balls just made my truck smell gross and the mice didnt mind it. The drier sheets smelled better but they made nests with it. But peppermint oil worked for me
    llibrm likes this.
  20. Oct 20, 2024 at 4:45 PM
    lbhsbz
    lbhsbz Well-Known Member
    HEET is simply ethanol....it isn't really good for anything except mixing with water and burning better than water. I'd go drive it till the tank is mostly empty...fill it up with fresh fuel and normal stabilizer...
