Is alignment needed when installing 1/4" spacer for driver side lean?
Discussion in 'Suspension' started by larry2375, Jan 4, 2011.
  1. Jan 4, 2011 at 9:34 AM
    larry2375
    larry2375 [OP] Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    I already have the 5100's set at 2.5" but want to install the 1/4" spacer to correct the driver side lean, will I need another alignment. Thanks.:)
  2. Jan 4, 2011 at 10:31 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
  3. Jan 4, 2011 at 10:34 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 any time you take apart your front suspension components you will need to get it aligned.
  4. Jan 5, 2011 at 1:03 AM
    larry2375
    honolulu
    wow, that's another $100 for alignment and the part alone is only $20. ill go and get it done, thanks guys!
