Is an AGM battery worth the cost?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjbrown210, May 29, 2023.
  1. May 30, 2023 at 4:13 PM
    #41
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    AGM in my 97 Civic EX, definitely not "designed for AGM". No issues and headlights have been consistently brighter since switching to one.
  2. May 30, 2023 at 4:23 PM
    #42
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    A real deep cycle 100ah LiFePo4 battery weighs 25lbs. They have BMS and are capable of an order of magnitude more cycles. Using the right battery for the right application, priceless.
  3. May 30, 2023 at 5:56 PM
    #43
    SpeySquatch
    2016 TRD OR DCSB
    dang! I bought mine a year ago in Idaho…not sure about the price diff
  4. May 30, 2023 at 7:07 PM
    #44
    4-Day-Work-Week
    4-Day-Work-Week Well-Known Member
    2022 OR DCLB Army Green
    Good management of an AGM can get 7+ years use. I don’t discharge mine past 80% and I don’t have to mess with a battery heater in sub zero winters. I also don’t need two batteries. Different strokes for different folks.
    YF_Ryan likes this.
  5. May 30, 2023 at 8:01 PM
    #45
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I think it's worth the cost because AGM is more reliable, less maintenance, larger storage capacity, faster cranking time. See my group 31 post here!
    4-Day-Work-Week likes this.
  6. May 31, 2023 at 4:55 AM
    #46
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Wow, hot topic.
    OP what did you decide on?
  7. May 31, 2023 at 5:00 AM
    #47
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    Its fun to buy shit we dont need. Is the hard on worth 350? Maybe depending on your circumstances. :beavisd:
  8. May 31, 2023 at 5:13 AM
    #48
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Not worth it. Go EFB instead.
    MannyS likes this.
  9. May 31, 2023 at 5:23 AM
    #49
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I got a regular lead acid battery from Wally World in my truck. When I push the start button, the truck starts every time! Every 5 years or so, i buy a new one. No need for anything fancy in my little world.
    If you want a AGM battery and can convince yourself it's worth the extra coin, then go get one!
    Zuba Gooding Jr likes this.
  10. May 31, 2023 at 5:27 AM
    #50
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I have the OEM battery in my 2 year old truck, which I'm keeping an eye on since the starter battery in my wife's Prius left her stranded (fortunately in the garage, and I have a jump pack) at 2 yrs and 3 months. My battery tester says 10.3v on the load/crank test and 98% health at 560 CCA tester setting. For some reason though the SoC is never higher than 12.4v whenever I put the tester on it (12.38 this time). I know the heat here in FL is brutal on batteries and it didn't surprise me that her OEM battery died at just over 2 years. I'm debating whether I should replace the battery pre-emptively and just go with the AGM. I can throw the AGM version of my tune on so it charges at the correct voltage.
    YF_Ryan likes this.
  11. May 31, 2023 at 5:35 AM
    #51
    Buck Henry
    Serious question here; does additional after market electrical loads (compressors, lights, fridge units, etc) dictate the need to jump from LA battery to AGMs? And if a tune is required to properly charge them, then what were these AGM batteries designed for in the first place? Are there cars that come from the factory with them?
    And I see them at my local Wally World all the time, but there is no warning sticker on the battery saying "modification to charging system required for proper charging ".
  12. May 31, 2023 at 5:36 AM
    #52
    2019 TRD Off Road
    Some cars come with them. They will charge in cars not designed for them, just not to 100%.
    Battery capacity and quality is probably a bigger factor for running extras than battery type.
  13. May 31, 2023 at 6:26 AM
    #53
    23TacoSR
    23TacoSR Well-Known Member
    You're going to hear arguments on both sides. It boils down to if you really want to spring for more $$ or not. I would stick with as quality regular flooded battery myself.
  14. May 31, 2023 at 7:00 AM
    #54
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I'm an AGM fan for a lot of the reasons stated in the thread. I didn't dispose of my factory battery early, though. It is just one of those things that seemed like a reasonable upgrade when the time came. I got a stock size 24f from AutoZone I believe. I run a winch off of it and have the charging voltage increased via tune. It also sits on a 1a AGM charger 95% of the time since it is not my DD. I also went with a Jackery to run my fridge instead of a dual battery set up. Way more versatile, simpler, and cheaper.
  15. May 31, 2023 at 7:05 AM
    #55
    _Shay_
    _Shay_ Well-Known Member
    2020 Cement Tacoma
    It's worth if, in my opinion. But I have a solar setup to trickle charge the battery to its full capacity.
  16. May 31, 2023 at 7:53 AM
    #56
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Cars equipped with the auto start/stop feature usually come equipped with AGM batteries from the factory. This is one "feature" I thank the Toyota Gods every day for not putting into my truck :)
    golfindia likes this.
  17. May 31, 2023 at 8:56 AM
    #57
    RyanDCLB
    4/19 DCLBOR
  18. May 31, 2023 at 9:30 AM
    #58
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    I had 2 of the 3 lead acid batteries in my boat start leaking. So i pulled them all and replaced with group 27 AGMs, mainly to prevent leaks. Worked great so far, but I'll probly just keep lead acids in the yota.
  19. Oct 23, 2023 at 7:02 PM
    #59
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
    How about them Optima batteries...amirite?
    Really though, are optimas just complete crap now and no one even considers them any more?
  20. Oct 24, 2023 at 8:20 AM
    #60
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I had three for about 3 years (1 start battery, 2 house batteries). never gave me any trouble. I finally blew the seal on my starting battery though after my alternator died and I drained that sucker flat trying to drive to a freeway exit. Ended up slapping two jump packs on it and drove on those for another 1/4 mile. I think recharging it off the new alternator with my voltage booster prolly finished it off. I moved onto an X2 power, but only because it was higher capacity and cheaper at the time, otherwise I'd have been happy with another Optima.
