Is an alignment necessary for an OEM shock absorber replacement?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfernoTonka, Jan 24, 2018.
  1. Jan 24, 2018 at 7:52 AM
    InfernoTonka
    InfernoTonka [OP] Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    I was told that replacing the rear drivers side shock that was defective requires an alignment? Is this true?
    I thought alignments were for front ends. Service rep claims that Tacomas need rear end alignments as well. Not sure that this sounds correct.
    It's $89...
  2. Jan 24, 2018 at 7:54 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I wouldn't think so, I mean if they were taking the whole leaf pack out maybe. But I would think not.
    James_Bond likes this.
  3. Jan 24, 2018 at 7:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ask him to show you the adjustment points.
  4. Jan 24, 2018 at 7:56 AM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    Nope, no alignment is needed after replacing any of the rear shocks.
  5. Jan 24, 2018 at 8:02 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Alignment not needed for shock replacement and yes, the rear end can be aligned on pretty much any vehicle.
    billybob50 likes this.
  6. Jan 24, 2018 at 8:04 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Wow. Dealerships are so pathetic.
  7. Jan 24, 2018 at 8:18 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Nothing to align in the rear, unless your pants are in the crack, seriously though, unless you have 4 wheel independent suspension or rear steering, nothing at all...
  8. Jan 24, 2018 at 8:22 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Some service reps remind me of Jiffy Lube employees making up stuff for $.
    I took my wife's MDX once for a rear diff oil change and was told by the service rep that their process doesn't allow air to get into it when refilling so nothing gets contaminated.
    Maggot61 and wilcam47 like this.
  9. Jan 24, 2018 at 8:27 AM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    I can check and fill your blinker fluid for $19.95
  10. Jan 24, 2018 at 8:37 AM
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Jokes on you. They remove all the oxygen out of the room while wearing a supplied air respirator suit to change the fluid.
    specter208, cshrum, over60 and 3 others like this.
  11. Jan 24, 2018 at 8:43 AM
    InfernoTonka
    UPDATE:
    I'm going to allow them to do an alignment because it is recommended yearly. Also apparently the alignment points will show up on the print out report.
    Also it keeps me on good terms with the dealership.
    If this was an issue after 6 months of ownership I would have declined and come back once the year mark came. As it turns out I've had the truck for about 14 months so maybe it's not a bad idea in the history of bad ideas.
    Also I don't mind taking the hit on this if it turns out to really not be necessary. Especially if it means saving someone on the forum from the same situation in the future. I might be taking one for the team here LOL.
    I will post the alignment report when I get it.
    Thanks for all the quick responses.
    djembefola, Maggot61 and James_Bond like this.
  12. Jan 24, 2018 at 8:46 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    make sure they align the front also since they are charging you 89 bucks for adjusting nothing in the rear...
  13. Jan 24, 2018 at 8:48 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If it's required, why isn't it being covered?
    SRBRO5 and EdgeCrusher like this.
  14. Jan 24, 2018 at 8:49 AM
    InfernoTonka
    Yeah, I made sure of that. It's my understanding it will be an all around alignment. Honestly it's the first I've heard of this so it will get interesting either way.
  15. Jan 24, 2018 at 8:51 AM
    InfernoTonka
    I was told it was wear and tear not covered. Does that sound correct?
  16. Jan 24, 2018 at 8:54 AM
    Jrobb
    Jrobb Well-Known Member
    Jon
    SF Bay Area
    2017 Double Cab Lb SR5 Magnetic Grey Metallic
    A shock should not go bad in 14 months. The other one didn't...
    J
    wilcam47 and InfernoTonka[OP] like this.
  17. Jan 24, 2018 at 8:57 AM
    InfernoTonka
    That shock is being covered. BTW that is covered up to 3 years/30,000 miles. That's what I was told at least. They agreed it was a manufacturer defect.
    I am going to push to have Toyota care cover this alignment.
    tcjacado, EdgeCrusher and James_Bond like this.
  18. Jan 24, 2018 at 8:59 AM
    uurx
    '12 t|x pro
    just make a fuss about the before and after print out and you should be ok, dont take no for an answer with receiving your copy of the print out....
    might wanna put some paint on the cam tabs, then you will know for sure if anything has had a wrench on it.
    this is not 100% true, one lazy shock absorber can take a shit on its own very easily.
    but you are right it really should not at just over one year of age.... but it does happens
  19. Jan 24, 2018 at 9:03 AM
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    The only way to align the rear axle is to loosen up the leaf spring U bolts and re-position the axle.
    I went to a place and they only offered the 4 wheel alignment when I did my tie rod ends on my old truck, they didn't touch the rear axle.
  20. Jan 24, 2018 at 9:05 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    cshrum and InfernoTonka[OP] like this.
