Is an alignment necessary??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 043RZ, Jun 28, 2014.
  1. Jun 28, 2014 at 8:01 PM
    043RZ
    043RZ [OP] Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Just curious but i need to pull and replace the driver side oil seal on the front differential. All im going to do is simply unbolt the 4 bolts to the lower ball joint and swing the spindle out of the way and of course pull the cv shaft. After i put it back together do i have to get another alignment? I dont think i need to. Any opinions on this?
  2. Jun 28, 2014 at 8:20 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Should be fine without, your not changin anything related to alignment
  3. Jun 28, 2014 at 8:26 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    If you work on the axle, no. Work on steering/suspension, yes.
