is an aussie locker drop in or do you have to adjust.
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Feb 9, 2011.
  1. Feb 9, 2011 at 2:40 PM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    i was curious if an aussie locker was a straight drop in mod or if i would end up adjust my backlash and such. i have the 8.4 rear end with 4.56 gears. non elocker obviously
  2. Feb 9, 2011 at 4:46 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
  3. Feb 9, 2011 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt have to.
  4. Feb 9, 2011 at 4:49 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    No all lunchbox lockers are straight drop in, no need to adjust backlash.
  5. Feb 9, 2011 at 5:50 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    koo koo hopefully once i get my tax rreturn i can purchase one of these bad boys
  6. Feb 9, 2011 at 6:59 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I heard they were very easy to install. Go for it!
  7. Feb 9, 2011 at 7:05 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i didnt see any for the 8.4 rear on their website? where are you buying one? im curious because they look pretty good
  8. Feb 9, 2011 at 8:40 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    look up the locker for the landcruiser. it uses the same rear axle. they call it an 8" rear though. same thing as a 8.4"
  9. Feb 9, 2011 at 8:43 PM
    Yoytoda
    Roland
    completely stock
    good to know, thanks
    have you looked at the powertrax lockers? Any benefits of the aussie over the lock-right or noslip
  10. Feb 9, 2011 at 9:10 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    i guess just the no-slip doesn't pop and make funny noises. the powertax is pretty much the same. im just gonna go with an aussie cause from what i have read it will perform the same as either of the powertrax offraod.
  11. Feb 9, 2011 at 9:28 PM
    Yoytoda
    Roland
    completely stock
    just to be clear, their website shows the land cruiser rear as an 8.875 or 9.5" R.G.
    the front is an 8" but will that work in the rear of our trucks?
  12. Feb 9, 2011 at 11:20 PM
    Yoytoda
    Roland
    completely stock
    seems like the the older 8" carrier is different though, so the spider gears/lunch box locker might be different...
  13. Feb 10, 2011 at 5:51 AM
    SargeSlapnuts
    Nick
    Pooler, Ga
  14. Apr 28, 2011 at 7:00 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I think you need to mark and make sure you place the washers, shims and bearing caps on the correct sides or it will be off from original. Whatever came off the right side needs to go back on the right and same with the left.
  15. May 4, 2011 at 9:09 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    You don't have to remove the carrier with the lunch-box lockers. Therefore no adjustments with the shims or bearing caps...
  16. May 9, 2013 at 10:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
