Is bigger better? Throttle body questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Jul 21, 2016.
  1. Jul 21, 2016 at 7:26 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
  2. Jul 21, 2016 at 7:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    aint going to work, our motors are fly by wire and need the specific TB to work.
    on a NA'd motor the dual vvti 1gr TB is pretty much pointless.... now if you are supercharged then it might get you some gains.
  3. Jul 21, 2016 at 8:31 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Larger TB diameter isn't going to do anything worthwhile unless you've already done a lot of other engine mods and you're actually lacking airflow. Wouldn't be worth the effort IMO.
  4. Jul 21, 2016 at 9:09 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Only thing I've done is a afe dry and magnaflow exhaust. I've also seen someone on here with their cats hollowed out. What's the benefit in that? In my understanding the cats don't really restrict any flow. Also is polishing the throttle body worth the time?
  5. Jul 21, 2016 at 9:09 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks that clears some shit up
  6. Jul 21, 2016 at 9:54 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Some NA guys have upgraded to a larger throttle body and claim it helps a bit with low-end power and improves throttle response. If you're interested in doing it, it'd be much cheaper to send your current throttle body to maxbore.com and have them bore it out. To make use of any of the possible improvements you'd want to also add in a URD MAF Calibrator.
