Is bilstein 5100 the way to go
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eric.gumberry, Oct 17, 2014.
  1. Oct 17, 2014 at 5:50 AM
    eric.gumberry
    eric.gumberry [OP] Well-Known Member
    Eric
    North Carolina
    2006 6 speed 4x4
    17 in methoods and 265/70r17, 884s and billys at 1.75 in front no rear lift
    I am wondering if I should put bilstein 5100 shocks and struts will this make my ride better on road not much of off roader I just what to lift my truck...let me now what you've done love to see it and love to talk about trucks
  2. Oct 17, 2014 at 5:56 AM
    TRD2013Chris
    TRD2013Chris Well-Known Member
    chris
    CT
    Black 2013 Tacoma TRD Sport Dbl Cab Long bed
    Ride will improve.
    Honestly\ you will find more answers by hitting the Search button. Most people will ignore this question because its been asked a TON of times.
    Welcome to TW
  3. Oct 17, 2014 at 5:57 AM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
  4. Oct 17, 2014 at 6:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Depends on what you mean by "rides better". If you want a soft cushy ride, then the 5100s will not do that, as they will firm up the ride due to firmer shock valves. If you also lift the truck with the fronts, the you will preload the springs which, again, will firm up the ride more.
    For me, the 5100s were better as I wanted a firmer "truck" ride. For you,,, depends on what you want.
  5. Oct 17, 2014 at 6:14 AM
    Snogoer05
    Snogoer05 Well-Known Member
    Maine
    05 SR5
    Billy's all around. 1.75 up front. Fisher HT 6'8" Steel blade. Custom bed rack. Mt Shasta.
    I just had 5100's put on all fours and it has been a great improvement! Haven't used them off-road yet but I did notice an improvement with towing my 3500# boat.
  6. Oct 17, 2014 at 6:28 AM
    galvyork
    galvyork Well-Known Member
    Don
    Ypsilanti, mi
    Trd Offroad
    yes they are better than stock in my opinion. i have mine set at 2.5 lift in the front and love it.
  7. Oct 17, 2014 at 7:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    set mine at 1.75 with stock TRD OR coils, and LOVE the slightly extra firmness, it rides like it should now.
  8. Oct 17, 2014 at 9:18 AM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    I'm running 5100's all around with Eibach Coils set at zero and General Spring HD Leaf Packs. Great ride. A bit stiffer than stock but I can't complain.
  9. Oct 17, 2014 at 9:21 AM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    for a simple leveling shock i don't think they can be beat for the price. i agree with the others that they offer a better ride than the stock bilsteins.
  10. Oct 17, 2014 at 9:24 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    For a budget lift you can't go wrong with 5100s :thumbsup:
  11. Oct 17, 2014 at 9:46 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    I ran 5100s set at 0 ome 883 springs and I was not a fan of the ride. It's great on smooth roads, but if the road was patched and had potholes etc it would rattle my dash. Even worse if you ever drove on a fire road with washboard ripples. They are good shocks but I think they suffer a little on the initial stroke of the suspension when you preload the spring. If your going buy the 5100s and springs I would spend a little more and get a coilover like fox 2.0. I just switched and it's 10x better then my 5100s with ome springs. HD I done it first the price difference is only a few hundred. Plus they come complete and ready to install instead of having to swap around parts and compress springs. Just do some research and thinking term.
  12. Oct 17, 2014 at 10:48 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    I just had 5100s put on to replace the ancient OEM Bilsteins. Those were probably never replaced since the truck was new in '05. The fronts are just set at 0 for now with the stock OR coils but it has made a HUGE difference. Whether or not you want any lift, I recommend the 5100s so far. Time will tell if I decide to get some coilovers and new leaf springs later on.
  13. Oct 17, 2014 at 5:15 PM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    I installed a complete set on my Taco about a year ago. I was impressed by the improved ride. I think it is one of the best mods you can do to your Taco. Quite a bit beefier than the original Bilsteins.
  14. Oct 17, 2014 at 7:02 PM
    Ma Deuce
    Ma Deuce Well-Known Member
    Joe
    Colorado
    I'm a big fan of Bilstein shocks. I've run them in a few different trucks. I prefer the adjustable Rancho RS 9000s though.
