Is brake clunk a way of life with these trucks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Apr 23, 2021.
Do your brakes clunk?
  1. Yes, all the time. It’s annoying
    24 vote(s)
    37.5%
  2. No, I never notice it.
    37 vote(s)
    57.8%
  3. Drum brakes are the best for Off Road.
    3 vote(s)
    4.7%
  1. Apr 23, 2021 at 8:23 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Just pull the e brake before letting off the brake and putting in park. And foot on brake to reverse/drive and release e brake. And it won’t happen.
    Stocklocker[OP] likes this.
  2. Apr 23, 2021 at 8:23 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    My auto 2nd gen would clunk in reverse.
  3. Apr 23, 2021 at 8:26 PM
    jdgray44
    jdgray44 New Member
    2017 Quicksand Tacoma
    Mine does it too. I’ve learned to live with it!
    BOZOJUICE and Stocklocker[OP] like this.
  4. Apr 23, 2021 at 8:34 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You're explaining the truck falling against the parking pawl when shutting the truck down.
    The OP, is talking about the issue of the brakes slapping in the calipers when switching directions, reverse to forward. (driving)
    tonered, Skydvrr and Stocklocker[OP] like this.
  5. Apr 23, 2021 at 8:48 PM
    Professor D
    Gregorny
    Mass
    Yes
    Ahh okay I guess I haven’t noticed that. I just assumed that’s what he meant. We talking like backing our of a parking spot and going from reverse to drive?
  6. Apr 23, 2021 at 8:49 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Bingo!
  7. Apr 23, 2021 at 8:50 PM
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    I think what aggravated this for me, is I used to park facing downhill after backing up my driveway, now I park facing uphill and back down my driveway while on the brakes. When I reach the street, my pads and shoes are primed for a clunk when I hit the stop sign at the end of my street. Maybe it always did it, but now I notice it every day. Once it clunks once, I’m pretty much good for the rest of the drive.
    My wife’s Camry is parked in the same orientation, and subjected to the same forces, but does not clunk, or at least very little.
    I can live with it. If I do my brakes I will report back and see if the clunk improved with new pads and shoes.
  8. Apr 23, 2021 at 8:54 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I see what's going on here. Quit running into that stop sign. No more clunk!
  9. Apr 23, 2021 at 8:57 PM
    Stocklocker
    17TRDORDCSBAT
    :rofl::rofl:
    :thumbsup:
    Bertw192[QUOTED] likes this.
  10. Apr 23, 2021 at 9:02 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    A lot of these complaints aren't limited to Toyota/Lexus either. Ford had a lot of complaints about the ticking and gear hunting as well. Sometimes those are just characteristics of modern powertrain.
  11. Apr 23, 2021 at 9:15 PM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Self adjusters in rear drums tighten up the shoes with sudden rearward stops. Unrelated to op noise, thought I'd mention rear drums do tighten up and click/ scrunch sometimes.
  12. Apr 23, 2021 at 10:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Grease on the ends of the pads where they would strike the caliper can help.
    Pull a pad and look for wear marks on the ends.
  13. Apr 23, 2021 at 10:52 PM
    Stocklocker
    17TRDORDCSBAT
    Thanks for the tip. I’ll check it out.
  14. Apr 23, 2021 at 11:02 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Nope, never experienced brake Clunk on my '18 TRD Sport.
    I feel more and more fortunate everyday that I don't have any of the MANY Tacoma issues reported here on a daily basis.
    Makes me wonder how many are actually imagined.
  15. Apr 23, 2021 at 11:05 PM
    #35
    Stocklocker
    17TRDORDCSBAT
    Yeah....I’m imagining it. Want an interesting thing to imagine.
  16. Apr 24, 2021 at 5:37 AM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Our Subaru is bad about that. For my Taco, it isn't reverse, but turning the pads slap around in the calipers.
  17. Apr 24, 2021 at 6:07 AM
    #37
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    There are two pins that go through each set of brake pads. The holes in the pads eventually become worn and they are allowed to move around on the pin, more importantly they are allowed to slide back and forth, at times like when you change the direction of the vehicle from forward to reverse. This makes an audible “clunk”.
    I suppose you could grease them, but the damage has already been done and likely won’t fix it for long (if it fixes it at all). Could be worn from lack of original lubrication at the factory, or perhaps the ingress of dust, dirt, mud, or water.
    Either way it’s easy enough to diagnose, simply remove the wheel and you should then be able to move the pads around and will hear the *clunk* noise (although quieter since your hands don’t have the force of a multi ton vehicle coming to a stop).
  18. Apr 24, 2021 at 6:28 AM
    #38
    splitbolt
    NW Arkansas
    Bertw192 likes this.
  19. Apr 24, 2021 at 7:24 AM
    #39
    Stocklocker
    17TRDORDCSBAT
    Great information. Thank you. My truck has its original brakes, so I imagine there is some wear. The truck had 74,000kM (50,000miles) on it. It’s seen lots of grit in its life.
  20. Apr 24, 2021 at 7:30 AM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but no. Those pins only retain the pads. It is the caliper itself that limits fore / aft pad movement. Our calipers are very similar to most motorcycle four piston calipers with top loading pads.
