Is changing the Valve cover gasket and Timing cover seals at 70k miles common on these
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vishrb, Dec 5, 2022.
  1. Dec 5, 2022 at 4:41 PM
    vishrb
    vishrb [OP] Member
    I am still looking at used Tacomas. I see one listed that had the Valve cover gasket and Timing cover seals replaced at 70k miles. Is that common in these?
  2. Dec 5, 2022 at 4:50 PM
    Soonr1
    Soonr1 Well-Known Member
    2022 Army Green TRD Off Road
    That’s a negative ghostrider.
  3. Dec 5, 2022 at 4:51 PM
    vishrb
    vishrb [OP] Member
    I was going to say that was the type of shit I had to do on my landy. Albeit quite often.
    Junkhead likes this.
  4. Dec 5, 2022 at 4:51 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    What year?
  5. Dec 5, 2022 at 4:51 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    On my 2016 Sport the timing chain and rear main seal started leaking at 100,000 miles.
  6. Dec 5, 2022 at 4:52 PM
    vishrb
    vishrb [OP] Member
    2016 OR
  7. Dec 5, 2022 at 4:56 PM
    Bishop84
    Bishop84 Well-Known Member
    It does happen, probably one in a couple hundred. Haven’t revealed anything newer than a 2019 though.
    As long as the block is dry the repair has no real bearing on the value of the truck. If anything you’re better off now that it’s been re sealed.
  8. Dec 5, 2022 at 5:16 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Earlier years, some16's/17's had timing chain cover leaks. Do to, not properly applied sealent to the cover.
  9. Dec 5, 2022 at 5:55 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Not really common but does happen in all years. There’s a thread on it. If it was replaced then it’s good to go. Make sure to have it on a lift and inspect meticulously the underside for any type of leaks. Focus also on passenger side near the firewall. That’s where the dreaded coolant leak occurs. Expensive repair.
    davidstacoma and Andrew.arw like this.
  10. Dec 5, 2022 at 5:56 PM
    vishrb
    vishrb [OP] Member
    OK, thank you for the advice.
  11. Dec 5, 2022 at 6:35 PM
    Soonr1
    Unrelated, given the inflated used market you probably could get a new truck for the same price or a little more. You’d also have the piece of mind of knowing it hasn’t been abused. Just a thought. I’ve seen some tacos with over 100k going for 35. New ORS are around 40.
  12. Dec 5, 2022 at 7:32 PM
    vishrb
    vishrb [OP] Member
    I have for sure looked at new. I just can't get there financially. Or at least I did not see any new OR's for 40. All were 43 plus. Then come with higher taxes etc... But yeah that would be nice.
    hiPSI likes this.
  13. Dec 6, 2022 at 1:39 AM
    Soonr1
    Dang, well there’s nothing wrong with a SR or SR5. I’d rather have a new SR than a used OR with 70k on it but that’s just me. Take your time because there are signs in some areas the market is starting to adjust. Good luck man!
    carcinoid, bulalo and auskip07 like this.
  14. Dec 6, 2022 at 6:05 PM
    vishrb
    vishrb [OP] Member
    So yeah, I am including SR5's in the search now. Saw one this morning at a good price and it was gone by this afternoon. LOL. Looks like I can get a SR5 and add the locker later and get better mileage. Still not as good as I thought. I did price out a new SR5 but unfortunately, it was just a bit out of my range as well. Looks like I am really needing to stay 35 or below and that is it. No stretch beyond that.
  15. Dec 6, 2022 at 6:09 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Good luck. I hope you can find one. I found a unicorn in 2021, a 2021 model OR 4wd with 3K miles and zero options in the color I wanted. $40K. So, keep looking.
  16. Dec 6, 2022 at 6:29 PM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    Just dropped mine off at the dealer today for the leaky timing cover repair...2016 OR, started leaking a year ago at about 53k miles and finally fixing it now. It was getting pretty bad, making a mess out of things. There are a few threads about it on here
    davidstacoma likes this.
  17. Dec 6, 2022 at 7:41 PM
    vishrb
    vishrb [OP] Member
    oh, ok. So common enough for a thread then. Surprising. I mean that is the crap I went through nonstop with my Rover. It was a beast off-road but broke my heart one too many times.
    Dan 77 and jgr81[QUOTED] like this.
  18. Dec 6, 2022 at 7:59 PM
    carcinoid
    carcinoid Well-Known Member
    Don’t forget to figure total cost. If the budget is that strict that you have to stay under $35k, it’s likely you’re financing. A new vehicle will have fewer maintenance costs for the first several years (and has free maintenance included) and will usually get a better financing rate. A new double cab 4x4 SR5 at $37k might have a lower total cost than a used off road at $35k when all things are considered.
  19. Dec 6, 2022 at 8:07 PM
    jgr81
    Jen
    Summit County CO
    yeah it's a bit of a pain for sure, but I haven't had any other issues with the truck since I bought it new, knock on wood.... but at least you'd be getting one that has already had it fixed!
  20. Dec 6, 2022 at 8:20 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    From what I've read the timing cover leak is more common on the 2GR-FE.
