Is clutch adjustable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Far12, Jan 21, 2015.
  1. Jan 21, 2015 at 9:53 AM
    Far12
    Far12 [OP] Active Member
    Oregon
    97 Tacoma 3inch lift
    LCE header 32x11.50 Maxxis Bighorn Tires Ultra wheels Skanda seat covers
    Hi, I'm pretty new to TW and I have a 97 2.7l tacoma and the clutch doesn't start grabbing until it's about halfway out or more. I was wondering if there is any adjustment that can be made to the linkage or something? Thanks in advance!
  2. Jan 21, 2015 at 11:37 AM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    I would actually like to know this as well.
    GQ7227 likes this.
  3. Jan 21, 2015 at 12:35 PM
    gearcruncher
    Canadain bumper technician
  4. Jan 21, 2015 at 1:14 PM
    Indy
    Indy Master of all I survey.
    If it's the original clutch from 97, it's probably ready for a new one. I had a 96 that had a lot of pedal before it caught. Once I pulled it apart it was pretty obvious what the problem was.
    GQ7227 likes this.
  5. Jan 21, 2015 at 3:04 PM
    Far12
    Oregon
    Thanks for all the info!
  6. Jan 21, 2015 at 3:05 PM
    Far12
    Oregon
    Also, do you know how much a new clutch assembly would cost and get it installed?
  7. Jan 21, 2015 at 3:48 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That depends on where you buy it and who installs it. Prices vary
    GQ7227 likes this.
  8. Jan 21, 2015 at 3:53 PM
    Far12
    Oregon
    whats the average price?
  9. Jan 21, 2015 at 4:35 PM
    gearcruncher
    Depending on the shape of your drivetrain ,$700 would be an average cost to have it done .
    This would include a new clutch kit consisting of a new pressure plate , clutch disc and release bearing .
    This does not include a new pilot bearing or the cost to have the flywheel machined .
    The flywheel " MUST " be machined for warranty purposes ,
    Nor does it cover the cost to flush the hydraulic assisted clutch components
    Nor does it cover shop supplies , nutts , bolts , zip ties , oxy/acetylene usage , universal joints or transmission fluid .
  10. Dec 24, 2019 at 6:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was told by Toyota dealer mechanic clutch is not adjustable,
    so i don't know the best route to attempt to alleviate the cold weather idle lurching that has been going on for many years it seems
    what should i be looking at
  11. Dec 24, 2019 at 6:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Wait till the truck warms up !!
    If your in stop and go driving till the truck warms up.
    If it is really a problem sitting down and looking at the signal from the coolant temp sensor you could send a signal that the engine was up to temp Just a matter of voltage as it is a simple thermister .
    cruiserguy and GQ7227 like this.
  12. Dec 24, 2019 at 6:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this usually happens parked in the garage/driveway
    i have to use the clutch pedal to start it (don't usually use the cancel button)
    so its in neutral and i let the clutch out (parking brake on) to step out and clean snow or scrape ice, it lurches in neutral when i let the pedal out, which seems odd, its been happening for so long now i don't know if its normal or not :notsure:
  13. Dec 24, 2019 at 6:39 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is because The Gear oil is so cold .
    The cold gear oil is enough to make the truck move even in neutral
    Remember the Main Shafts of The Transfer case and Transmission are spinning .
    You never notice this does not happen in the warm weather no snow to brush off.
  14. Dec 24, 2019 at 6:40 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    The clutch itself isn't adjustable. The pedal however is. gearcruncher has the link up there for reference.
    Cost break-down (did it myself) was $360 for a marlin crawler clutch kit. (OEM components, little more heavy duty). $85.00 for a brand spanking new flywheel. About $30 in beer and shop rags. Most of the cost is labor. This job in my neck of the woods ranges from $800 - $1200 depending on the shop.
    cruiserguy and GQ7227[QUOTED] like this.
  15. Dec 24, 2019 at 6:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was going to try the TW recommended gear oil next time it needs changed
    perhaps that will make the difference!
  16. Dec 24, 2019 at 6:42 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Most likely not much The colder it is the thicker it gets.
    Unless you want to change fluids for winter and summer
    Move to a warmer climate
  17. Dec 24, 2019 at 6:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am going to find the pedal spring and shoot some nut-z lube up there to stop the squeak that seems to be seasonal
  18. Dec 24, 2019 at 6:45 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i would rather move to a colder climate!
    was not totally sure if there was any harm being done with this lurching
  19. Dec 24, 2019 at 6:48 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Swap the old spring it for a linear spring, that's usually what causes the squeaking.
    GQ7227[QUOTED] likes this.
  20. Dec 24, 2019 at 6:49 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    ... will have to do some trial and error this winter with the clutch-start-cancel button
    it was squeaking during the first several years i had it, iirc
    had it lubed up a few times eons ago which seemed to help
    since its mostly 'seasonal' i have learned to endure
    nagorb[QUOTED] likes this.
