Is cold/ cool air intake worth it?
Discussion in 'Performance and Tuning' started by saugus, Sep 18, 2011.
  1. Sep 19, 2011 at 5:58 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    The old version of the CAI, which you can't buy anymore, was said to provide an extremely slight benefit. The CAI you can buy today only looks good under the hood and makes more noise, no performance benefit.
  2. Aug 20, 2013 at 5:39 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    I was just watching motorweek on axs tv, and they were comparing the mpg of the Toyota fj with and without the cold air intake and catback exhaust system. they only got .4 of a gallon increase. once you payback for the cost of the modifications it will be about 47k miles before you start saving a penny.
  3. Aug 20, 2013 at 5:41 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    and the stock truck already has a cold air intake.
  4. Aug 20, 2013 at 5:42 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I would do it purely for the sound and it depends on where you live too
  5. Aug 20, 2013 at 7:44 PM
    BBentley
    BBentley Member
    Brian
    Alabama
    K&N air kit, Borla exhaust, Toytec lift
    I guess it's a personal preference. The first thing I did to my '07 was a K&N cold air kit and the Borla exhaust. I wasn't going for mpg, but performance. And I love it!
  6. Aug 20, 2013 at 7:57 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Sound/butt dyno performace or did you actually gain real performance?
    To the OP, did they do any HP tests too?
  7. Aug 20, 2013 at 8:01 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Awesome thing is most "cold air intakes" actually raise the temperature of the intake air.
  8. Aug 20, 2013 at 8:03 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    CAI + snorkel >>> intake temp = outside air temp :D
  9. Aug 20, 2013 at 8:07 PM
    gjacobsjr
    gjacobsjr Well-Known Member
    Jerry
    Reno, NV
    12 Tacoma SR5 MagGrey on Black
    Black Raptor 16x8 Leer Shell Blacked out windows Pro Comp 3 in lift good year 265/75/16 Airaid CAI Cat Back 2 3/4 pipe with magnaflow and tip
    Bet you mine sounds better than yours. Lol plus there is noticeable power difference. Airaid CAintake, throttle body spacer and custom cat back exhaust. Vroom vroom bitch (jesse voice)
  10. Aug 20, 2013 at 8:09 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    A suspension lift doesn't give you any MPGS either :)
  11. Aug 20, 2013 at 8:09 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I went from a afe stage 2 si, header back exhaust and urd maf to stock and i'm happy with stock
  12. Aug 20, 2013 at 8:31 PM
    Spoonman
    Jamie
    Alberta
    Snorkels are good for something!
  13. Aug 21, 2013 at 5:04 AM
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    throttle body spacers are just anodized paper weights....
  14. Aug 21, 2013 at 5:47 AM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I put one on with my supercharger and it really brings out the sound of the supercharger so I would do it again just for the sound it makes
  15. Aug 21, 2013 at 6:11 AM
    #35
    gjacobsjr
    Jerry
    Reno, NV
    Funny how everyone talks shit and they are all running stock???? Makes sense to me
  16. Aug 21, 2013 at 6:16 AM
    #36
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    x2
    FYI, if lower intake temps are what you want, insulate your stock Air Intake tubing. The stock is already a "Cold Air Intake" and all that most aftermarket CAI's do is smooth out the flow path and create less air flow restrictions. Which is where you get the added noise from, and the slightly higher performances at higher RPM's due to the less restricting flow during the high RPM air flow velocities.
    Though a lot of Aftermarket CAI's also suffer from engine bay heat soaking. Insulating them has positive effects as well.
    Just don't be an idiot and buy the ones that suck air from IN the engine bay...
  17. Aug 21, 2013 at 6:27 AM
    #37
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    before i got this volant, i had home made one. welded together a filter box out of some thing gage sheet steel, and then insulated it. just had a plastic intake tube like any of the other aftermarket companies. with the insulated box, i ran 3-5 degrees cooler than the volant does in 90 degree weather. now, the snorkel on the other hand, is a trump-all it seems, getting my intake temps at or within 2 degrees of outside air temp. that's while driving of course. heats up a little sitting at idle. may wrap the intake tube for that.
  18. Aug 21, 2013 at 6:37 AM
    #38
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I saw that on motorweek as well. I'd venture to say if you are trying to save penny's on gas you have the wrong vehicle. You need a bicycle. Anyone adding a CAI and trying to save money is doing it for the wrong reason.
  19. Aug 21, 2013 at 7:38 AM
    #39
    ozmon420
    miami, florida
    08 tacoma
    exactly!
  20. Aug 21, 2013 at 7:45 AM
    #40
    13TRDsport
    NE PA
    The only thing throttle body spacers do is make noise. It is useless in a Fuel Injected engine with a throttle body design. Older cars with carburators benifit from a tb spacer but thats about it.
