Is cold/ cool air intake worth it?
Discussion in 'Performance and Tuning' started by saugus, Sep 18, 2011.
  1. Nov 27, 2013 at 3:06 AM
    #121
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    You do realize that your Off Road package is a performance package right?
    And you are right, to each their own, but I'd doubt you would take a stock Tacoma over one that is raised and supercharged if you had a choice.
  2. Nov 27, 2013 at 3:08 AM
    #122
    S1000RR
    You most definitely can. :D
  3. Nov 19, 2016 at 5:02 PM
    #123
    Toastyyyyy86
    Toastyyyyy86 Member
    Colorado
    2015 TRD Pro
    I was wondering if it is possible to make the good scoop on my trd pro functional? Has anyone used it as ram air intake? Or forced induction? Thanks guys
  4. Nov 19, 2016 at 5:06 PM
    #124
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Why? Not much room for the necessary plumbing, and it's not high enough to "ram".
  5. Nov 19, 2016 at 5:49 PM
    #125
    Toastyyyyy86
    Toastyyyyy86 Member
    Colorado
    2015 TRD Pro
    I was thinking it could act more like a snorkel. Get that true cold air into the intake. But I see what you're saying about there not being much room for the plumbing.
  6. Nov 19, 2016 at 10:01 PM
    #126
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    The top of the hood is one of the lowest pressure areas on a vehicle. Not a good place to locate an intake in spite of all the cool 60s and 70s factory and custom hotrods that made the look famous.
  7. Nov 19, 2016 at 10:14 PM
    #127
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    To maximize a CAI
    1) wrap intake tube with a 4" dia heat sleeve from DEI , doing this lowers intake temp so you're actually seeing cooler temps
    2) using fire resistant foam padding and build up the upper section of the filter box so it is completely sealed from warmer engine compartment temps . Doing this will only allow colder ambient outside air to enter the CAI
    3) fab up a a intake tube and flanges by using the cowl panel area . this way you pick up cold air only from the windshield cowl area . This is similar to a NASCAR style air intake
    Use components from this company to fab up a true cold air system
    http://www.ramairbox.com
    1largemouth likes this.
  8. Nov 20, 2016 at 8:26 AM
    #128
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Of course a cold air intake system is worth it. That's why your truck came with one from the factory. Leave it alone and waste your money on something else.
    MadDaddy likes this.
  9. Nov 20, 2016 at 9:02 AM
    #129
    swainick13
    swainick13 Well-Known Member
    N
    N.C.
    2011 Tacoma TRD V6
    Yes I have the k&n and it's great.
  10. Nov 20, 2016 at 9:25 AM
    #130
    lumtron
    lumtron Active Member
    Dan
    Colorado
    '17 TRD OR
    Ok so I'm not necessarily looking for increased hp nor mpg, hoping an aftermarket CIA would help my 3rd gen engine become more efficient at high altitudes, most driving at 5500-8000ft. Would this help my cause, or spend money on other mods?
    I can't tell if my engine sucks wind on slight inclines or the way I'm driving the auto trans. I've been driving manual for a decade so auto is foreign to me at the moment. It just seems like I'm sucking wind going up the slightest hill (constant gear 4 to 5 shifting...put in sport mode to bypass on most mountain roads).
  11. Nov 20, 2016 at 3:33 PM
    #131
    worthywads
    This seems counterintuitive to some but the higher the altitude the less "intake" you need. The air is that much thinner so less flow can happen. If the air is 20% thinner then it's like your intake is 20% larger already.
    Now let's wait for someone to say something like, "there's the same amount of oxygen at sea level as Mt Everest", and miss the point that yes there are fewer oxygen molecules
  12. Nov 20, 2016 at 7:01 PM
    #132
    1largemouth
    1largemouth Well-Known Member
    Martinez CA
    06 Tacoma
    Snorkel it
  13. Nov 20, 2016 at 7:05 PM
    #133
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I've seen drag race cars run 2-3tenths faster using Cold air set ups
  14. Nov 20, 2016 at 7:11 PM
    #134
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    True, but those I bet didn't have one to start with like our trucks come factory with. That's the difference.
    My 1984 Camaro ran a little faster and got a tad better mileage when I modded it but it had a single snorkel factory setup to start, so adding a second snorkel and relocating the intakes was a vast improvement.
  15. Nov 20, 2016 at 7:12 PM
    #135
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Intakes do increase hp, but as others have said stack the performance parts.
    intake + URD Maf Calibrator + exhaust
    Lean out the fuel curve on WOT and feel the difference!
  16. Nov 20, 2016 at 7:56 PM
    #136
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    My 02 DC Pre Runner 2.7 4cyl has a TRD supercharger , K&N CAI and Doug Thorley tri y header runs very well
  17. Nov 20, 2016 at 7:57 PM
    #137
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
  18. Nov 21, 2016 at 7:20 AM
    #138
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    I've got the TRD CAI (came with the truck) and it just makes the truck louder... In my honest opinion thought about replacing it with a stock CAI the exhaust is enough for me.
  19. Nov 21, 2016 at 8:05 AM
    #139
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    They didnt make it functional for a reason.
  20. Nov 21, 2016 at 1:27 PM
    #140
    Toastyyyyy86
    Toastyyyyy86 Member
    Colorado
    2015 TRD Pro
    I appreciate all the info guys. I think I'll spend my money elsewhere (armor). An aftermarket CAI doesn't sound worth it.
