Is Discount tire smoking crack?
Discussion in 'Wheels & Tires' started by thatdood, Oct 17, 2012.
  1. Oct 17, 2012 at 4:03 PM
    thatdood
    thatdood [OP] Well-Known Member
    Texas
    Black 09 DblCab SR5 minus mud flaps
    I've got a 2009 Tacoma Prerunner double cab with no lift. I just bought some XD Monsters 18x9 with -12mm offset.
    The guy at discount tire told me I would have to have a lift put on my truck before these wheels would fit right. He said they would stick out too far now. I've done a lot of research on here and have seen several guys running these same wheels with either 265/60/18 tires or 285/60/18 tires.
    What do you guys think?
  2. Oct 17, 2012 at 4:10 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i could see a small lift so you have no rubbing. -12 is alot of offset, no?
  3. Oct 17, 2012 at 4:13 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Gonna need some lift.
  4. Oct 17, 2012 at 4:14 PM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    Duhhhhhhhhhhhh gonna need a lift, They know what they are talking about. Derp
  5. Oct 17, 2012 at 4:27 PM
    thatdood
    Texas
    From the kmc wheels website, it shows these are the correct offset for a prerunner. [​IMG]
  6. Oct 17, 2012 at 4:39 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You might get away with a 265/60 on that wheel, but not a 285/60. A 285 will definitely rub without a lift.
    That is not showing you what the "correct" offset is, that is showing you what will fit.
  7. Oct 17, 2012 at 4:43 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    be weary of anyone telling you your truck will need a lift to fit a tire or wheel if they do not ask you the application of your truck.
    unless your mall crawling a lift will not stop you from rubbing.
    your shock geometry and travel remains the same with a lift (if it rubs without a lift it will rub with one)
  8. Oct 17, 2012 at 4:48 PM
    thatdood
    Texas
    Agreed. Basically I am planning to put 265s for now until I can afford to lift and get wider tires.
    Agreed as well. I'm driving mostly in town and on the highway. I may take my dogs to the lake, but no serious off-roading.
  9. Oct 17, 2012 at 4:50 PM
    thatdood
    Texas
    I plan on eventually lifting. I'm not much of a mechanic, but -12mm is a little less than half an inch. I guess that is a lot in the offset world? I'm honestly asking because I don't know.
  10. Oct 17, 2012 at 4:51 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I didn't read the post, only the title, and my response is....
    Most likely.
  11. Oct 17, 2012 at 4:55 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I suggest you do some more research, because there's no way you can agree with XXXX, and agree with me. What he said makes no sense, and is the exact opposite of what everyone else is telling you. The whole reason you need to lift, is because it's the only way you're going to avoid rubbing with those wheels. Trust me, I'm currently running the same width and offset wheel, and used to run 285/60/18's myself.
  12. Oct 17, 2012 at 4:57 PM
    Aw9d
    Aw9d That one guy
    Lazy fucker.. :D
  13. Oct 17, 2012 at 5:00 PM
    thatdood
    Texas
    I appreciate the encouragement. What I'm saying is that I plan to run 265s and then eventually lift and run 285s.
  14. Oct 17, 2012 at 5:01 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    No shit! there was only 11 posts to that point!!:facepalm::D
  15. Oct 17, 2012 at 5:03 PM
    XXXX
    sKiP
    05 Prius
    :rofl:
    Everyone including you are wrong. It's simple geometry.
    Please tell me how lifting a truck changes your geometry and shock travel :popcorn:
    If you don't believe me pop this question over int he "mid-travel bs" thread and see what happens
  16. Oct 17, 2012 at 5:09 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Please tell me how lifting doesn't provide more tire clearance. Actually never mind, I remembered that you just like to argue.
  17. Oct 17, 2012 at 5:11 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This is true for the preferred types of lifts (5100s, OMEs, coilovers). If the OP goes for a Revtek top plate spacer lift, the wheel position at full tuck will be lower than stock, so tire clearance is increased. Of course, he will have other problems associated with spacer lifts (like shocks breaking). The other alternative is lift spindles, which likewise increase tire clearance with no drawbacks other than cost.
    To the OP: 265/60-18 is a 31" tire and will fit with that wheel at stock ride height. 285/60-18 would probably require you to trim away the lip of the plastic fender flare where it wraps around the bottom of the fender.
  18. Oct 17, 2012 at 5:15 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Would have to chop the cab mount too.
    To each his own, but if I were you, I'd look into those SCS wheels. Think I'll get a set in bronze for my black truck next go around.
  19. Oct 17, 2012 at 5:15 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    LOL at this post.
    -12 offset on a 9" rim = 4.52" backspacing.
    With a 265...not a single fuck given. With a 285 and a 3" lift....still gonna need a hammer and a grinder if you want to be rub free.
  20. Oct 17, 2012 at 5:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Depends on the lift. For a 6 DB lift...you're correct.
    But for your standard 3" lift (pick your poison) you only get more tire clearance AT RIDE HEIGHT. Full compression and you're in the exact same boat as without a lift.
