Is gear hunting fixed in the 2021 Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cf250, May 22, 2021.
  1. May 23, 2021 at 8:51 AM
    #61
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Could swear i'm around 2200 in 6th, or bit more at 80 mph.
    davidstacoma likes this.
  2. May 23, 2021 at 10:06 AM
    #62
    mkultra007
    mkultra007 Well-Known Member
    Mark
    2021 TRD OR DCLB
    2021 OR here. Not bad. Turning ECT on helps in hilly terrain. Only times it was annoying were I first picked it up, until the ECU "learned" my driving habits. I've done a lot of electrical work in the last 6 months, and it's definitely the ECU. Every time I disconnect the battery it loses it's marbles and has to repeat the learning period. Very noticeable difference.
  3. May 23, 2021 at 11:34 AM
    #63
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    Mine runs almost dead on 2000 RPMs at 80mph in 6th. Makes for a quiet and smooth ride while cruising down the interstate.
  4. May 23, 2021 at 12:02 PM
    #64
    zoo truck
    None
    Just curious what rpm you have at 60 mph.
  5. May 23, 2021 at 12:14 PM
    #65
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Ya sure you have the v6? Around 2200 is about right for the auto with a 4.3, which came with the 4 cylinders.
  6. May 23, 2021 at 12:26 PM
    #66
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Back in the day transmissions had 3 speeds. Then 4 became common, then 5. And today we have 6, 8 and 10 speed transmissions in trucks. They didn't design a transmission with 6-10 gears and intend for it to only use 3 of them. They are supposed to change gears more often.
  7. May 23, 2021 at 1:02 PM
    #67
    Bigmatt503
    Bigmatt503 Well-Known Member
    Good to know. Thanks
  8. May 23, 2021 at 1:08 PM
    #68
    jpb2
    jpb2 Well-Known Member
    Jeff
    Southeast Mo
    2021 DCSB TRD OR AT
    I would trade for manual. The wife can't drive then.... yep I'm an asshole
  9. May 23, 2021 at 1:42 PM
    #69
    Taco1701
    William
    GA
    60mph in 6th is running 1500 RPMs.
    zoo truck[QUOTED] likes this.
  10. May 24, 2021 at 4:55 AM
    #70
    zoo truck
    None
    Yeah, thats about what i see on my tach...somewhere between 1500-1600 rpm. Must of been doing 80 + mph when getting a higher rpm reading.
  11. May 24, 2021 at 5:07 AM
    #71
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
    I've only got 750 miles on my 2021 but that's my take as well. No hunting, but it will aggressively upshift unless you keep your boot in it. It wants to be turning 1500 RPMs all the time.
    I have only ever driven my 2021 (first Tacoma!) but all the horror stories I heard about the auto in this truck turned out to be non-factors for me.
  12. May 24, 2021 at 6:31 AM
    #72
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    My 6.4 had very very little lag and would lots of boost quickly with the factory twin turbos and minor mods. My 7.3 takes a little longer but as long as I don't lug it the boost will build relatively quickly.
  13. May 24, 2021 at 7:13 AM
    #73
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I owned a 1968 Oldsmobile Cutlass with a "power glide" 2 speed transmission. Low and High. And you guys think the 6 speed sucks!!!
    jpb2 likes this.
  14. May 24, 2021 at 7:30 AM
    #74
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Thanks for posting the gears, so we can all see the obvious problem with the auto trans from 2016 to 2021, and no the new truck may have better ecu mapping to make you feel better, but the problem is obvious. As others have said, this engine is not n it's power band until 2500 rpm plus. But the 5th and 6th gars on the trans are over drives and worthless. The engine can't maintain highway speed limit in 6th gear, due to lack of power at 2k rpm or less, so it drops down to 5th and sees it can't do it there either and drops down again, then you left off the gas and it goes back into 6th, then you slow down and you hit the gas which causes it to shift all over again. The only real solution is regearing to lower ratios. If toyota had used the exact same gear ratios on the auto trans that they did on the manual trans there would be no problem using std tire size.
