Is getting a lift worth it?
Discussion in 'Suspension' started by dylanxcarter, Sep 6, 2017.
  1. Sep 6, 2017 at 8:26 PM
    #61
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Still don't understand why the owner of that truck thinks it's the hulk if it's red...
    RobP62[QUOTED] likes this.
  2. Sep 6, 2017 at 8:29 PM
    #62
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  3. Sep 6, 2017 at 8:30 PM
    #63
    ICU1
    ICU1 Well-Known Member
    Where did you get the headlights and how much if I may ask?
  4. Sep 6, 2017 at 8:38 PM
    #64
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    There are some for real experts on here so listen to them and take your time.
    Just remember, no two trucks are alike and even the same models and model years may have varied results with same components. Nothing is ever 100% guaranteed.
  5. Sep 6, 2017 at 8:42 PM
    #65
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Cause the flash made less sense? :notsure:
    SixthSnail[QUOTED] likes this.
  6. Sep 6, 2017 at 8:44 PM
    #66
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    This is ridiculous...
    Key-Rei[QUOTED] and RobP62 like this.
  7. Sep 6, 2017 at 8:48 PM
    #67
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    @dylanxcarter getting a small lift can be very worth it and not throw the geometry off too much. Between 1-3 inches is about the sweet spot for anybody who actually wants to get the most out of their truck off-road.
    This allows you to clear 33-35" tires (Depending on how much you want to cut), which increases ground clearance.
    The 6"+ lifts are just for show. They aren't practical for off-roading in most instances. Pavement Princess is the general term. That is why most trucks that lifted are just show trucks. Some people actually use them though.
  8. Sep 6, 2017 at 8:57 PM
    #68
    dylanxcarter
    dylanxcarter [OP] Member
    Dylan
    17 Quicksand Tacoma SR5
    Thank you, appreciate the info. This was very helpful
  9. Sep 7, 2017 at 3:02 AM
    #69
    Clearwater Bill
    Billy
    Largo Florida
    People are doing that on OE wheels. (stock)
  10. Sep 7, 2017 at 3:04 AM
    #70
    dylanxcarter
    Dylan
    I want to get different wheels and 17's I just don't know what offset that would work so I don't get any rubbing
  11. Sep 7, 2017 at 3:14 AM
    #71
    Key-Rei
    Key
    Florida
    Anything from +25 to -25 with 0 being the sweet spot. Granted that's factoring a 8" wide or less wheel, stock I belive is a 7" wide.
  12. Sep 7, 2017 at 3:25 AM
    #72
    dylanxcarter
    Dylan
    I'm looking at the XD820 grenades that are 17x8.5
  13. Sep 7, 2017 at 3:27 AM
    #73
    Key-Rei
    Key
    Florida
    Shouldn't be an issue as long as the offset is close to 0. A 265 might look a little funny on a 8.5w wheel but it shouldn't rub.
  14. Sep 7, 2017 at 3:29 AM
    #74
    dylanxcarter
    Dylan
    What would you recommend?
  15. Sep 7, 2017 at 3:37 AM
    #75
    Key-Rei
    Key
    Florida
    With a stock suspension the tire you listed is a good choice I would just go for a 7.5 or 8 wide wheel, a 265 on an 8" wheel or wider is just going to look a little stretched as the tread width is approaching the rim width. Generally you want a little puffiness to the tire on a truck so 1.5" to 2" of overlap. IE a 285 or 12.5 tire on a 8/8.5 wheel. But then that's too wide for stock and would rub or require fender trimming possibly a CMC.
  16. Sep 7, 2017 at 3:58 AM
    #76
    dylanxcarter
    Dylan
    Thank, appreciate your help!
    Key-Rei[QUOTED] likes this.
  17. Sep 7, 2017 at 4:38 AM
    #77
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey man, just wanted to say be safe and try to stay dry down there. Saying prayers for all my Florida forum peeps!
    Rob
    doorsidedown and Key-Rei[QUOTED] like this.
  18. Sep 7, 2017 at 4:38 AM
    #78
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You too man, be safe!
    Rob
  19. Sep 7, 2017 at 4:41 AM
    #79
    Key-Rei
    Key
    Florida
    Thanks man! Definitely praying myself too. Looking like I'll be on the ride it out crew at work, probably a safer place to be than a house if this thing is as bad as they say. (And it definitely looks like it is) and my rig will be in an parking garage so also fairly safe I think.
  20. Sep 7, 2017 at 4:43 AM
    #80
    ChadsPride
    Sponsored by TacomaWorld.com
    His previous truck was green
    SixthSnail[QUOTED] and RobP62 like this.
