is higher octane really any better for the 4 cylinder?
Discussion in '4 Cylinder' started by TacomaGus, Apr 30, 2010.
  1. May 3, 2010 at 1:33 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    my last fill up was with 87 again and i'm going to keep track of the mileage so we'll see how it goes
  2. May 5, 2010 at 4:06 PM
    SimiGuy
    SimiGuy Active Member
    Joel
    Simi Valley
    02 Tacoma Single Cab 2.4L
    6" adjustable coilover lift add-a-leaf black unique rims BFG AT KO's 410 rear end 2 10" subs xm radio alpine head unit and amps painted front bumper half a$$ intake
    In my 02 2.4L auto the truck does best on 89 octane. Runs smooth and consitant. When filled up wih 87 I can notice more acceleration lag less mpg. on 91 it felt the same as 89.
    I always fill my truck wth 89.
  3. May 5, 2010 at 4:34 PM
    Yota1
    Yota1 Well-Known Member
    i run medium grade, what ever it is, 89 or 91.
    i run premium in all my power equiptment
  4. May 19, 2010 at 2:10 AM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    My 05 RC 2.7 I use 87 and get 400 miles to a tank.
  5. May 20, 2010 at 2:06 AM
    dsailer
    dsailer Member
    Orlando, FL
    Well, I have never seen an owners manual that clearly directs you to use 87 Octane.
    They all say "Minimum of 87" This means never use anything lower.
    So, If you are using 87 and your knock sensor detects ping, the computer retards timing to lessen the spark knock. Retarded timing equals a slight loss of power.
    I actually tow with my 4cyl, I use mid grade (89) to avoid the issue of spark knock, and retarded timing resulting in loss of power.
    Rememgber that octane is the measurement of a fuels ability to resist knock.
    oldtoyman and cryptolime like this.
  6. May 20, 2010 at 9:18 AM
    TacomaGus
    Gus
    Morgantown, WV
    how do u know if ur truck pings?
  7. May 20, 2010 at 9:32 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You will hear it. It will be a high pitched knocking noise coming from your engine. It usually happens under load and is more common when it's hot outside. I had a 1994 Ford Ranger that could run 87 octane in the winter, but during the summer, I had to run 89 to stop it from pinging. My current Tacoma has never pinged on 87 octane, even in +100 degree weather.
  8. May 22, 2010 at 5:30 PM
    Barnone
    Barnone Guest
    There's more energy is regular gasoline, which has more volatile molecules (more explosive power) than high test. The additives in high test promote a more uniform burn, in order to reduce engine knock.
  9. May 22, 2010 at 6:02 PM
    TacoNinja12
    TacoNinja12 Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    in my opinion, if you say its a waste of money to use higher octane thats a little silly. It cost like 20 cents more so after 15 gallons thats like 2.50. i can definitely tell a difference in my truck going up hills, with 87 it seems like I'm driving through mashed potatoes and i have to down shift. as for mpg im unsure because i have been buying 93 octane since i got my truck and only put in 87 on accident. thats just my opinion though, i love my truck so i give it the best drinks when its thirsty!
  10. May 22, 2010 at 10:20 PM
    Tacovendor
    Tacovendor Well-Known Member
    SoCal
    4x4x4cyl
    Just wait!
    Doing the test now, My FJ Cruiser burns supreme and if I run regular it cuts my MPG about 3 miles per gallon. I'll post up after this tank.
  11. May 23, 2010 at 8:03 AM
    Barnone
    Barnone Guest
    Isn't your FJ a 4.0l V6. We are talking four cylinders here. The V6 can take advantage of higher octane fuel but the I4 was designed to use 87 octane.
    If you think that you get more power or better MPG out of a I4 with high octane fuel then something is wrong with your calculations or your engine.
    It would be almost impossible to prove one way or the other without a controlled test environment.
    87 octane has more energy than higher octane fuel because higher octane fuel has additives that reduce the burn rate to prevent preignition (knock) in higher compression engines.
  12. May 23, 2010 at 2:53 PM
    TacomaGus
    Gus
    Morgantown, WV
    well i tested 3 tanks of each and i got just under 20 mpg running around town in the same spots (i drive a lot) and with the 87 i was getting about 17 so it does make some difference with the mileage, idk about performance tho
  13. May 26, 2010 at 4:14 PM
    kungfupanda
    kungfupanda Well-Known Member
    So Cal, Cerritos
    2010 4x2 Taco TRD SPORT
    HID - Low, LED interior lights, LED license plate light, HID Yellow fog lights, Access Limited Roll Cover, Hitch/Tow Package, Ceramic Tint, Wet Okole's, Magnaflow Exhaust, DFab Bars, Bully Bar Back, HID Yellow Fog Lights
    So for the V6 4.0. what about mid grade gasoline? I have a 2010, do you hear ticking in your engine? I use 87 per the service dudes, they say don't waste your money.
  14. May 26, 2010 at 4:21 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    If I were you, I would judge for yourself if it's worth it. Try a few tanks of each grade and see if you notice enough improvement to warrant the extra cost of higher grade gas. Your truck will run fine on 87, but you may like the performance increase of premium.
  15. May 26, 2010 at 4:33 PM
    #35
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    i have a second gen 4 cylinder 5 speed, and I only run high octane in the summer when I know im going to be using the AC, the small increase in power seems to bring my shift points back to where they were without the AC on. Although you have to pay pretty close attention to the truck in the first place to pick out the difference between the high octane vs regular
    cryptolime likes this.
  16. May 26, 2010 at 8:36 PM
    #36
    kungfupanda
    So Cal, Cerritos
    Is it bad to switch back and forth octanes? Will "spark knock" occur? If I go long driving, should I put premium? When is the best time to put premium and regular? Sorry if this question has been asked already...
  17. May 27, 2010 at 6:37 AM
    #37
    Barnone
    Barnone Guest
    Not bad to switch back and forth.
    Spark knock (pre ignition) should not occur on normally aspirated four cylinder Tacos unless something is wrong with your engine or the gas isn't really 87 octane. In any case, don't lug your engine.
    Best time to buy is when you need fuel.;)
  18. May 27, 2010 at 6:44 AM
    #38
    005Tacoma
    2005 Toyota Tacoma
    In middle Georgia all we have is 87, 89, 93, I tried 93 for about 3 weeks and seemed to use MORE fuel using 93. So I went back to 87.
  19. May 27, 2010 at 6:49 AM
    #39
    Barnone
    Barnone Guest
    In theory that is what should happen since some energy is lost in higher octane fuel because of the anti knock additives.
  20. May 28, 2010 at 5:48 AM
    #40
    kungfupanda
    So Cal, Cerritos
