is higher octane really any better for the 4 cylinder?
Discussion in '4 Cylinder' started by TacomaGus, Apr 30, 2010.
  1. Feb 6, 2011 at 3:14 PM
    #41
    BP348
    BP348 Well-Known Member
    San Diego, CA
    2004 DC 4x4
    i have run 91 since the day i bought the bitch, ill prolly keep doin it cuz a few extra buck a tank aint shit to a OG
  2. Feb 6, 2011 at 9:52 PM
    #42
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    I've been running 93 octane since I got it a couple of month ago. Reading this thread I'm going to try 87 for a while to see what it does.
  3. Feb 7, 2011 at 7:02 AM
    #43
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i always used 93 octane and then i switched it 87, seamed like the truck did not respond as well. Then i tried 89 and the truck seamed to run just as good as 93 with edging out a tad bit better gas mileage.
    so 89 from here on out with the fill ups
  4. Feb 7, 2011 at 9:14 AM
    #44
    &erson
    &erson Well-Known Member
    Sunshine State
    4x4 SR5
    Wet Okoles, Weathertechs, All-Pro Rear Bumper/Hitch & Sliders
    I tried high test for a few weeks & got 0 improvement. Happily back to the cheap stuff.
  5. Feb 7, 2011 at 1:14 PM
    #45
    jcemitte
    jcemitte Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    lol this looks like a job for that performance pruimer thread :D
  6. Feb 7, 2011 at 2:18 PM
    #46
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Me too. After buying the truck, I tried various fuel grades: disconnected the battery overnight to reset the ECM and gave it several tankfuls to adjust to the different octane, etc etc. I found absolutely no benefit from using anything over 87 octane.
  7. Feb 7, 2011 at 5:02 PM
    #47
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    performance per octane levels is purely compression ratio dependant. study what your compression ratio's are and and put in proper octane grade accordingly.
  8. Mar 21, 2011 at 3:21 PM
    #48
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    Higher octane only helps prevent premature ignition on higher compression motors... which either results in knocking/lower performance or your computer adjusting timing etc to eliminate that knocking, also hurting performance.
    Regarding previous posts about needing a controlled environment to test whether higher octane has any benefits: Your testing environments may be tainted by the fact that in many cases, you actually get high octane when purchasing lower octane fuels.
    I wish I had asked more questions as to why, but a terminal operator on our fuel pipeline told me never to buy premium because they ship out a lot of premium even when the truck was supposed to be loading regular. I dont know if it is an excess of premium production at the refinery or the fact that unleaded gets drained so fast and they have to suppliment premium to meet their contracts.
  9. Mar 23, 2011 at 10:10 PM
    #49
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    I think my truck runs better on regular (87 I think) versus premium.
    I heard that if you put premium in a vw jetta they blow up? random lol but wanted to say it
  10. Mar 24, 2011 at 2:31 AM
    #50
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    My truck seems to run better on 93 octaine especially during the winter months when the gas is that crappy winter blend. Gas milage possibly 1 mpg better. My driving is inconsistant so its hard to be accurate.
  11. Mar 24, 2011 at 3:18 AM
    #51
    Theunicorn2004
    Theunicorn2004 Member
    Arizona
    064x4
    Stock
    I used 91 because its a cleaner burn so cleaner engine. And only chevron or shell.
  12. Mar 24, 2011 at 3:46 AM
    #52
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Very true. I use Sunoco it is one of the few gas companies that dont support enemies of USA
  13. Mar 24, 2011 at 3:59 AM
    #53
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Guess mine isn't doing too bad based on what has been posted. I usually get 320 or so on 87 and that is right at 1/8th of a tank left driving 75 on frwy with 32x11 E load heavy ass tire/wheel combo and stock gearing with 5 speed. Tried plus and super a coupla times but it made no difference in mileage or performance so I just feed it regular from Shell.
  14. Mar 24, 2011 at 12:33 PM
    #54
    DGXR
    Friend
    Sacramento, CA
    LOL -- High octane is designed for high-compression engines and does not burn cleaner in a normal-compression engine. You are wasting your money and making fat cats even fatter.
    That's good gas mileage for a prerunner 4-cyl with big ass tires. I bet you could do even better going 65! :)
  15. Mar 24, 2011 at 11:11 PM
    #55
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    not necessarily true i do have a different truck them him but with the same motor i usually average around 400+ miles per tank. :D
    but when i did try and use premium there was absolutely no gain in performance and it could have been me but it seemed as though the truck idled a bit rougher.
  16. Mar 25, 2011 at 5:09 AM
    #56
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Dunno bout that, it only turns 2500 rpm doing 70-75mph in 5th. Doing 65 would lug the shit out of it in 5th gear. Maybe 60-65 in 4th. Kinda interested in 4.56 gear change.......
  17. Mar 25, 2011 at 5:44 AM
    #57
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    If you're doing 2500rpm at 75mph it would be ~2167rpm at 65mph... hardly lugging.
  18. Mar 25, 2011 at 5:53 AM
    #58
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Maybe not lugging but definitely no acceleration or torque for headwind especially with overhead rack items like this..........
    Had to draft behind 18 wheeler on frwy to hold 70 mph like this due to 20-30 mph headwind.....or drive in 4th gear, lol. Thinking sweetspot for mpg with my setup would be closer to 3k rpm..........
  19. Aug 12, 2022 at 9:07 AM
    #59
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i get much better performance with my 2TR-FE on 91. it runs on 87 but i get significantly less power and mpgs. It also gear hunts like crazy on 87 with no gear hunting on 91.
  20. Aug 12, 2022 at 5:08 PM
    #60
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    I ran 91 on my truck in the first few months after I got it, then switched to 87. My MPG went up with 87. Hardly scientific, but that's my experience. Even though the 3rd gen 2.7 has a higher compression ratio than older 2.7s, I'm not sure it's enough to take advantage of 91.
