Is it 2",2.5", or 3" ? Completely confused!
Discussion in 'Suspension' started by JP22, Aug 25, 2012.
  1. Aug 25, 2012 at 7:17 AM
    JP22
    JP22 [OP] Active Member
    Alabama
    09 DCSB 4X4
    After looking at ALL the lifts, I had decided to go with the OME setup. But after talking with the different distributors I got 3 different answers on the lift heights. I want 2.5-3" to fit the tires and wheels I like. So which height should I expect with the full OME setup.
  2. Aug 25, 2012 at 8:52 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Which coils ?
  3. Aug 25, 2012 at 8:58 AM
    Beast Mode
    Beast Mode Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    Make sure you get the top plate spacer to get the full 3".
  4. Aug 25, 2012 at 9:00 AM
    OZ-T
    Peter North
    British Columbia
    Not true for all cases
  5. Aug 25, 2012 at 9:01 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Toytec guys are GREAT--They helped w/my lift.
    I am sure others are good too--just saying my experience.
  6. Aug 25, 2012 at 9:02 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    884s, 885s, 885x's, or 886 coils?
  7. Aug 25, 2012 at 9:02 AM
    OZ-T
    Peter North
    British Columbia
    Which coils ?
  8. Aug 25, 2012 at 9:46 AM
    JP22
    Alabama
    09 DCSB 4X4
    885 coils is what was quoted. 3 quotes and 3 different heights.
  9. Aug 25, 2012 at 10:17 AM
    OZ-T
    Peter North
    British Columbia
    885's with no top plate spacer raised my DCLB 4x4 2 1/2" up front , hasn't moved in over a year
    1/4" top plate spacers will get you another 1/2" of lift
    Don't forget to add the 5mm trim packer to the driver's side shock below the coil mount for taco lean
  10. Aug 25, 2012 at 10:35 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    X2
  11. Aug 25, 2012 at 1:02 PM
    JP22
    Alabama
    09 DCSB 4X4
    2.5 is what I would like 3 would be ok. I just couldn't figure why there was 3 different heights on the same parts. This is the first lift I have done and it is for my son. So I want it to be RIGHT. It's a double cab short bed 4x4 with really crappy factory leaf springs. Thats why I had decided to go OME to get the dakars included in the package. And it was HIGHLY recommended by most everyone on the site.
  12. Aug 25, 2012 at 3:57 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Cause all trucks are different so some say 2.5" some say 3" but realistically w/o top plate you prolly won't get a full 3". Plan to get some new UCA at 2.5" and higher lift.
