is it a gas ⛽️ hog ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Nov 1, 2023.
  1. Nov 1, 2023 at 10:18 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello community,
    So my Tacoma got me about 10mpg today and is eating fuel like nothing. What should I do , I’m currently running 30% bigger tires and got heavy topper on my bed that’s it. My driving is very grandpa . Tacoma is 2nd gen 4 banger 5 lug. What should I do to improve my mpg? Thanks
    When it was stock I use to get about 25mpg.
  2. Nov 1, 2023 at 10:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Go back to stock :notsure:
  3. Nov 1, 2023 at 10:25 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    LS swap?
    herecomesace likes this.
  4. Nov 1, 2023 at 10:30 PM
    Nazareth7
    2007 Tacoma 2x4
    Tires are aggressive ones
  5. Nov 1, 2023 at 10:39 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Probably should start saving your gas rewards points for a Tesla truck.
  6. Nov 1, 2023 at 10:43 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Is it Friday already? Why do you have aggressive big tires on a 2WD 4cyl truck? Silly. Go back to stock. You're just going to get responses of people dunking on you for crippling your own truck.
    You could also search the forum for answers instead of having people spoon feed it to you. Here's a link, time for you to do some reading: https://www.google.com/search?q=site:tacomaworld.com+improve+mpg
  7. Nov 2, 2023 at 10:19 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Huge tires on a 4 banger is your problem along with a lot more weight.
    50Buck likes this.
  8. Nov 2, 2023 at 10:35 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is nothing you can do to improve fuel mileage from the factory. There is a lot you can do to make it worse as you've discovered.
    The good news. The 30% larger tires mean your speedometer and odometer are off as well. That means you are actually driving farther than you think on each tank of fuel. So, you're actually doing a little better than 10 mpg. Maybe 11 mpg.
  9. Nov 5, 2023 at 4:35 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    my 15 4cyl 4x4 gets 18-20 in summer(summer tires) 16-18 winter tires(stock size but more aggressive tread)
  10. Nov 6, 2023 at 6:22 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Make sure all of your maintenance is up to date. Fluids, spark plugs, throttle body cleaning etc.
    Did you start getting that shitty fuel mileage right after you put on big tires and a heavy topper on a 16 year old 4 cyl truck? Or did it all of a sudden happen? Either way, common sense should tell you that you won't get stock mileage when the truck is not stock anymore. More weight = more drag.
  11. Nov 6, 2023 at 6:28 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Is it always 10mpg? Or just this most recent tank? I've had some really bad tanks of fuel like that too. Maybe winter gas blend change? But likely just a shitty tank of fuel. Might take a couple tanks to get back to where you were previously. That's been my experience.
  12. Nov 6, 2023 at 6:32 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    try putting 30% smaller wheels and see if you get 25mpg
  13. Nov 6, 2023 at 6:44 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Get 420 miles per tank on mine
  14. Nov 6, 2023 at 6:46 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    This guy is a troll…….dont give him a second thought.
  15. Nov 6, 2023 at 6:48 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Don't forget to adjust any mpg calculation you may be doing due to larger tires - your truck will "think" it's traveling fewer miles because of fewer wheel rotations per mile actually traveled.
  16. Nov 6, 2023 at 7:31 AM
    Crash415
    Crash415 Well-Known Member
    22 TRD OR MT
    40 inch tires on a 4cyl taco? Right, and I'm Cindy Lauper.
    TacoSR523 likes this.
  17. Nov 6, 2023 at 8:30 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    When did humanity forget that "LoOkInG cOoL" comes at a price?
