IS IT A LIE OR TRUTH?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jsecre02, Oct 23, 2021.
  1. Oct 24, 2021 at 10:14 AM
    #121
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I think we got derailed a bit, but it is what it is. :thumbsup:
  2. Oct 24, 2021 at 10:15 AM
    #122
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes.
  3. Oct 24, 2021 at 10:16 AM
    #123
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    This is more like it!! Wow that last one OUCH!!!
    INSAYN and Junkhead[QUOTED] like this.
  4. Oct 24, 2021 at 10:16 AM
    #124
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Hahaha!
    71tattooguy[QUOTED] likes this.
  5. Oct 24, 2021 at 10:18 AM
    #125
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    I'll explain this to you very slowly so you can maybe understand.
    I wish it was easier to put 35s on the tacoma because I'm not going to run my stock $40,000 truck on trails that will damage it.
    BTW, I don't know if you've ever heard of trails called the Rubicon, Fordyce, Dusy-Ershim, Bronco canyon...
    All in my backyard. None of which I would even think of considering in a tacoma on 31s. All of which I have done on jeeps with 35s
  6. Oct 24, 2021 at 10:26 AM
    #126
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    A taller tire and wider tire are not synonymous. A taller skinny tire will have better lbs per square inch on hard surface trails with rocks than an equivalent sized tire that is wider.
    The gains in soft surfaces are negligible if any being wider, as a properly aired down tire at a given tire height will be the same length in contact area, but the additional width can be hindering with the amount of extra rolling resistance is created by the width of the wave in front of the tire. This wave could be soft sand, snow, mud etc.
    Aesthetics are not even part of the equation. :facepalm:
    tinker_troy and BuzzardsGottaEat like this.
  7. Oct 24, 2021 at 10:32 AM
    #127
    kairo
    kairo >_>
    Nor Nev
    Lol. Wow. You've gotta be trolling at this point. In case you aren't, and you actually believe you're correct on contact patches and traction, I've added something that might help.
    Thatbassguy likes this.
  8. Oct 24, 2021 at 10:32 AM
    #128
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You do know that Jeeps and Tacomas are built differently for a reason, right?
    A Jeep on 31s could probably still out run a DCLB Taco on 35s on any of those trails you just mentioned. You would still need more than 35s on your truck to keep up with Jeeps with 35s on those trails.
    Again, my reference about bringing a knife to a gun fight is still relevant here.
  9. Oct 24, 2021 at 10:35 AM
    #129
    kairo
    kairo >_>
    Nor Nev
    And if you go back and read carefully, you'll notice that never once did I ever even hint that 35s were an end all solution. My original comment was that I wished it was easier to get 35s on, like the gladiator.
    Although it did get you to grace us with the comedy of your litany of errors, so I'm thankful for that.
  10. Oct 24, 2021 at 10:36 AM
    #130
    kairo
    kairo >_>
    Nor Nev
    And you'd be wrong, again. You ain't running a tj on 31s up the first two walls on Fordyce.
  11. Oct 24, 2021 at 10:36 AM
    #131
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I was joking about the aesthetics part, but I guess the emoji didn't make that clear enough for you.
    I guess by your logic we should all be running skinny 31's. That's what all of the more experienced off-roaders are doing, right?
    Increased pressure doesn't equal increased traction, BTW.
    Obviously, to the point of this thread, a Wrangler is definitely a superior off-roader.
    What's weird, though, is that most of the built Jeeps I see are on larger tires than stock. I guess they must not know what they're doing. They should probably just pick better lines.
    Junkhead and kairo like this.
  12. Oct 24, 2021 at 10:50 AM
    #132
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    I saw your emoji, and figured I would tease a little. You okay? :thumbsup:
    No, I am not at all saying we should all be on 31s. In fact I don't believe I evan made a lean in that direction.
    Most of the jeeps you see off road are built to go on much tougher trails than a Tacoma with 31s, 33s or even 35s. If the Jeeps are sporting anything bigger than 35s, then you and I both know it's either for looks or they go on trails we would have difficulty walk on, let alone taking a Tacoma through with anything smaller than a 42.
    Thatbassguy[QUOTED] likes this.
  13. Oct 24, 2021 at 11:04 AM
    #133
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Judging by resale value and the amount of used jeeps for sale i'd have to say the Taco is the the better choice.
    71tattooguy likes this.
  14. Oct 24, 2021 at 11:05 AM
    #134
    Thatbassguy
    James
    I agree with this.
    But, I'll still argue that bigger tires have advantages no matter what vehicle you put them on. While they may not be necessary for what someone is doing with their truck, they can definitely make things easier.
    I don't think anyone would argue that big tires are a replacement for good judgement and good driving.
    Junkhead and 71tattooguy like this.
  15. Oct 24, 2021 at 11:16 AM
    #135
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Agreed.
    "Bigger" tires are not equal. Tall skinny vs tall wide will have their variables over a given terrain. Pros and cons to both.
    Adding 35" tires to a DCLB Tacoma whether easy or not, is not going to compete at all with a Jeep on 35s on anything that requires that kind of clearance. Ground clearance under the lowest point is one thing, clearance at either end and center of said vehicle is another. If picking better lines is at all an option, then a driver should rely on that as best they can regardless of tire size. Yes taller tires will give more options for picking lines, that's a given. However, 35s on a $40,000 DCLB Tacoma isn't going to fix it's length and hangups on the trails that absolutely require Jeeps to run 35s. Trail damage IS going to happen on said Tacoma. Phyzziks!
  16. Oct 24, 2021 at 11:30 AM
    #136
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Ginger or Mary Ann…….why not both!!
  17. Oct 24, 2021 at 11:35 AM
    #137
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Well had a lot of Tacoma’s since 1989 and have had only a few minor recalls but have a lot of friends and people that know of people with Jeep’s and they cannot say the same . They do look so good with all the mods but if there at the dealership you can’t use them much .I have a good friend that has one of the first Gladiator Rubicon and he has been without it for a total of 3 months in 4differant times because of electrical issues. So GoodLuck to all Jeep owners
    Junkhead likes this.
  18. Oct 24, 2021 at 1:01 PM
    #138
    Thatbassguy
    James
    This sounds like lemon law territory. Has your friend tried to get Jeep to buy it back?
  19. Oct 24, 2021 at 1:43 PM
    #139
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Jeep is #1 for quality, reliability, drivability, rugged good looks, off-road capability, resale, and getting chicks in my books.
    I drive a Toyota because I like to do my own repairs, enjoy showing off my driving skill in a less capable vehicle, don’t like to draw attention to myself, and am already married.
  20. Oct 24, 2021 at 1:51 PM
    #140
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    All this talk about Tacomas not performing. I decided to go wheel my Tacoma that’s on 33” today.
    Hit a few obstacles I had only done in my Rubi on 38” .
    3’ and 4’ ledges.
    Taco survived with a few new scratches on the skids and sliders. I was missing the front locker and 38” but I got through the obstacles with some finesse.
