is it a vacuum leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by todd.perkins, Dec 19, 2020.
  1. Dec 19, 2020 at 11:50 AM
    todd.perkins
    todd.perkins [OP] Member
    cold start problem, brakes hard, low idle, after warm up everything is fine
    Black DOG Lila likes this.
  2. Dec 19, 2020 at 12:23 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld Todd.
    0 vehicle info = O replies
    Rastopher and loudboy like this.
  3. Dec 21, 2020 at 7:06 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Yo Todd. If you elaborate we’re happy to help. But if you want answers people need information.
    todd.perkins[OP] likes this.
  4. Dec 21, 2020 at 7:15 PM
    djm228
    djm228 Professional Dumbass
    Dan
    Buffalo, NY
    1998 Tacoma SR5 V6 4x4
    I'm not very mechanically inclined, but I think a vacuum leak would still show some symptoms after warmup. Correct me if I'm wrong.
  5. Dec 21, 2020 at 9:55 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    Is there a check engine light?
    Is there an error code?
  6. Dec 22, 2020 at 5:53 AM
    todd.perkins
    No check engine light. Have not checked for an error code yet. Through testing I have discovered that there is no vacuum leak.
    Symptoms are the first start of the day whether morning or afternoon is extremely hard to start. After the first start it will start all day long with no problems. Once started the brake pedal acts normally with no problems.
  7. Dec 22, 2020 at 6:16 AM
    todd.perkins
    Additionally. First start has very low idle. After first start and engine warm up idle is normal on all subsequent starts.
  8. Dec 22, 2020 at 6:38 AM
    Black DOG Lila
    Virginia
    Does the CEL light up with ignition on?
  9. Dec 22, 2020 at 7:38 AM
    todd.perkins
    If the ignition is turn on but not started there is no CEL. After it starts still no CEL.
  10. Dec 22, 2020 at 7:48 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Check for a code with scanner. Sounds like your CEL might be burned out or unplugged. I’m pretty certain that if you have the key on but not started the light should come on. Are you the original owner?
    jonesbt and todd.perkins[OP] like this.
  11. Dec 22, 2020 at 7:54 AM
    Black DOG Lila
    Virginia
    CEL bulb is toast or disconnected
    Run an OBD2 SCAN
    Free at many auto parts stores
  12. Dec 22, 2020 at 7:59 AM
    todd.perkins
    I am the original owner and had did not notice it was not on. Next step will be to check the code. Will update.
    Thanks
    maxtherat and Black DOG Lila like this.
  13. Dec 22, 2020 at 9:38 AM
    Rastopher
    Ras
    Sacramento, Ca
    In regards to the brakes, I’d treat that as a separate issue. For what it’s worth, the first press on the brakes on my truck has been a little jarring since i can remember. Could be an issue with something but hasn’t been an issue for me for 5+ years.
    What year and engine is your truck? It does matter. For example my 2002 2.7 4cyl idles warm at 650rpm-750rpm. When it’s warming up the idle control valve opens more and it idles roughly around 1150-1250.
    how old is your battery? Have you checked it’s health?
    What is your idle at when cold with no accessories on (heater fan, a/c)? Does it change idle when you reach operational temperature?
  14. Dec 22, 2020 at 12:00 PM
    todd.perkins
    Code P0118 - Engine Coolant Temperature Circuit High Input. Trouble Area: 1.Open or short in engine coolant temperature sensor circuit 2.Engine coolant temperature sensor 3.ECM.
    Would this impact first start of the day?
    Starting to suspect fuel pump or fuel filter??
    Steves104x4 likes this.
  15. Dec 22, 2020 at 12:02 PM
    todd.perkins
    Year is 2003 Tacoma Pre-Runner. Idles before this started was 8K rpm. Now until engines warms up it is 4.5K rpm with lots of misses and some back fires.
  16. Dec 22, 2020 at 12:14 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replace the engine coolant temperature sensor and good luck!
  17. Dec 22, 2020 at 12:32 PM
    Rastopher
    Ras
    Sacramento, Ca
    I’d clean your mass airflow sensor first. If it’s dirty it could be underreporting air. It isn’t super likely but its super easy to do. Then i’d check to see if you have a sticky idle air control valve, or if the vacuum controlled throttle plunger is sticking.
  18. Dec 24, 2020 at 9:45 PM
    maxtherat
    Inland Northwest
    Yes this would definitely have an effect on cold start idle. Hopefully the coolant sensor is easy to access. Make sure to check the wires at the connection too. If you have multimeter it would be good to check the sensor before replacing. Good luck and merry Christmas
  19. Dec 30, 2020 at 5:38 PM
    todd.perkins
    I sincerely want to thank everyone who has given me good advice on this thread. This actually is the first thread I have ever received a response on.
    I am at a standstill until next week thanks to external factors.
    I noticed a pin hole at front end bottom of the air cleaner box. Also in the box there was a broken-up pecan shell, tons of leaves and it looks like something started chewing on the bottom of the air filter. The back of the air filter feeding the engine however was pristine. ?????
    For those like myself who are not naturally mechanically inclined I have found two excellent videos that fit my engine.
    To clean the Mass Air Sensor
    https://www.youtube.com/results?search_query=cleaning+mass+air+flow+sensor+toyota+tacoma+3.4l
    and to replace the Cool Temperature Sensor
    https://www.youtube.com/watch?v=J9nHgZUoWyo
  20. Jan 7, 2021 at 11:55 AM
    Rastopher
    Ras
    Sacramento, Ca
    Hey Todd, how’s the project going?
