Is it bad to "Down Shift" a lot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trexTRD, May 15, 2015.
  1. Jun 24, 2016 at 6:17 PM
    #61
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    +1
  2. Jun 24, 2016 at 6:19 PM
    #62
    81shark
    81shark Well-Known Member
    Ok.. add snow and off roading to my list.
    But normal day to day driving..
  3. Jun 24, 2016 at 6:21 PM
    #63
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    There's just no good reason. At best it burns more gas, and brake pads are pretty cheap. At worst it puts wear on the tranny, which is far more costly to fix than brakes, and still burns more gas. All it buys you is less wear on the brakes. In either case, it's not worth it.
  4. Jun 24, 2016 at 6:24 PM
    #64
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    normal day to day driving includes hills and snow in winter for me
    but I guess I just " can't work a clutch "
    :rolleyes:
  5. Jun 24, 2016 at 6:25 PM
    #65
    OZ-T
    Peter North
    British Columbia
    It doesn't wear the tranny to select anothef gear other than D
  6. Jun 24, 2016 at 6:29 PM
    #66
    skootx
    Erie, CO
    That may be, it's debatable. But it doesn't matter- you'll still burn more gas than brake pads are worth.
  7. Jun 24, 2016 at 6:31 PM
    #67
    OZ-T
    Peter North
    British Columbia
    Or just have no brakes at the bottom of some long hills
    I'm not super concerned about a microscopic reduction in mpg in my truck , I just drive it and use it like a truck and its not all that debatable , it does no damage to select gears in the auto in the Tacoma
  8. Jun 24, 2016 at 6:34 PM
    #68
    bogginator
    bogginator Well-Known Member
    Marsh
    Cherokee County
    2015 Black DCSB XSPX
    It's a never ending $100-$200 a week thing & still going.
    I'm curious to know how it burns more gas.
    Norton likes this.
  9. Jun 24, 2016 at 6:35 PM
    #69
    OZ-T
    Peter North
    British Columbia
    I'm assuming he's referring to higher rpm's
  10. Jun 24, 2016 at 6:35 PM
    #70
    skootx
    Erie, CO
    Oh, long hills is definitely a different story. I was referring to OP's original situation- braking when coming to a fast stop, or in everyday traffic. Yeah, no question on hills- I tow a 5,000 lb trailer up and down the Rocky Mountains regularly and always downshift for descents, and ascents too when needed to maintain speed.
    EDIT- Yeah, regarding burning more gas I'm referring to RPM's.
  11. Jun 24, 2016 at 6:35 PM
    #71
    jbrnigan
    Midwest
    Perhaps you should circulate and forward a petition to Lexus, Porsche, General Motors, FoMoCo, Fiat etc etc informing them that they are wasting their money manufacturing autos with "paddle shifters", allowing the driver to manually select which gear on the automatic transmission they prefer because "there's just no good reason" and "it's not worth it". I'm sure they will appreciate your unqualified expert opinion on their engineering, marketing and performance options for their automatic transmissions.
    95 taco likes this.
  12. Jun 24, 2016 at 6:37 PM
    #72
    OZ-T
    Peter North
    British Columbia
    The truck won't allow a downshift if the rpms would be such that damage is possible
  13. Jun 24, 2016 at 7:46 PM
    #73
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I only downshift my auto after I drive my sisters wrx and loath Toyota for not making a manual DCLB :mad:. And then promptly view threads about manual swapping, and then remember I get paid 10.50 an hour :(:(:(:(
  14. Jun 24, 2016 at 8:44 PM
    #74
    Pigpen
    Dan
    Northwest Montana
    I downshift to slow down every time I slow down. I've done this with every man tranny vehicle since I started driving in 1990, never had any issue :notsure:
  15. Jun 25, 2016 at 5:59 PM
    #75
    skootx
    Erie, CO
    It's really not that big of a deal, and it totally depends on what you want to do. Want better mileage and less clutch wear? Put it in neutral and coast up to stops. Want more control? Downshift. That's the whole reason I've driven manuals for 30 years- you can vary depending on conditions.
  16. Jun 25, 2016 at 6:07 PM
    #76
    OZ-T
    Peter North
    British Columbia
    You guys know this thread is about shifting an auto right ?
    and v
  17. Jun 25, 2016 at 6:14 PM
    #77
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've been driving well over 40 years, about 50/50 split between autos and manuals. I don't always downshift when stopping, but do when it will help with either transmission. Which is actually quite often. I have no idea how many miles I've driven, well over 1,000,000 and have never damaged a transmission in any way. You can't be stupid and try to go to 3rd gear at 65 mph, but anyone with any sense can, and should take advantage of what the transmission was designed for. In fact mine will downshift automatically at times in order to slow me down. Don't try to tell me they weren't designed to do this. Brake pads are cheap, but rotors aren't and with labor at $120/hour as well as my time I want to make my brakes last a very LOOOONG time. I usually get 60,000 -70,000 on front and 150,000 on rear brakes.
  18. Jun 25, 2016 at 6:22 PM
    #78
    jbrnigan
    Midwest
    Asking myself the same question, but, this is TW - LOL
  19. Jun 25, 2016 at 10:23 PM
    #79
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I'll bite. It is a well known fact that heat kills transmissions over time (there is actually an active thread on it right now). In order to slow/stop your vehicle from rolling, friction is required, whether it is in the transmission or the brakes. Friction creates heat. Therefore I agree that it is "best not to do it". Don't get me wrong, I would put it in a lower gear going down a slick hill, but I would personally avoid downshifting regularly.
  20. Jun 25, 2016 at 10:26 PM
    #80
    OZ-T
    Peter North
    British Columbia
    So thats somehow not an issue if the truck does it's "engine braking" downshits on it's own when you apply the brakes going down an incline ?
