Is it bad to "Down Shift" a lot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trexTRD, May 15, 2015.
  1. Jun 26, 2016 at 11:22 AM
    #101
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Heat generated in the trans would be negligible, if any. The only thing causing any amount of wear is the actual lurching, non rev matched downshift. My gf's Corolla will downshift when I lift off the gas going down a steep hill. It's a 4 speed auto so the ratios are far apart. When it shifts, the car lurches forward as the RPMs shoot up and it feels like it must be horrible for the trans. It annoys the shit outta me. A perfectly rev matched downshift however, is nearly unnoticeable.
  2. Jun 26, 2016 at 11:26 AM
    #102
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Because, the torque converter on the Tacoma only locks up in 4th and O/D - so - in the first three gears while decelerating there is slippage in the converter, generating heat. In 4th and O/D, while decelerating, if the converter is locked up, the transmission temps will actually cool, but will rise if the converter is not locked up - throttle position sensor and engine load dependent. Another variable - even though the converter is generating heat when decelerating in say 3rd gear, the engine coolant temp is going down, transmission fluid is running through the radiator is affected by the decreasing coolant temps, still rising but at a decreasing rate.
  3. Jun 26, 2016 at 11:28 AM
    #103
    jbrnigan
    Midwest
    You got your engineering degree from where???
  4. Jun 26, 2016 at 11:41 AM
    #104
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    I have done this in a 2015 Dodge 2500 and saw absolutely no big change in temps
  5. Jun 26, 2016 at 11:48 AM
    #105
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    It doesn't take an engineering degree to determine the intent of a design.
    Me and my accounting degree would happily take you through a cost benefit analysis of downshifting vs braking though!
  6. Jun 26, 2016 at 11:56 AM
    #106
    jbrnigan
    Midwest
    That would be sure to keep the power train engineers at Lexus, Mercedes, GM, and Ford in stitches for weeks. LOL
  7. Jun 26, 2016 at 12:05 PM
    #107
    JeffreyB
    Jeff
    That is why engineers are not in charge of the money.
  8. Jun 26, 2016 at 12:30 PM
    #108
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    But does that heat matter more than accelerating. up the hill? No.
  9. Jun 26, 2016 at 12:38 PM
    #109
    jbrnigan
    Midwest
    They are if they are the CEO. And unless you are the CEO at your company, you're not in charge of the money, you just count it. LOL
    worthywads likes this.
  10. Jun 26, 2016 at 12:46 PM
    #110
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    2013 Tacoma AC 4x4 M/T 2.7L
    I probably should've left this thread alone at post #38. :notsure:
  11. Jun 26, 2016 at 12:46 PM
    #111
    worthywads
    Cased closed on the accountants guess.
  12. Jun 26, 2016 at 1:21 PM
    #112
    JeffreyB
    Jeff
    Ok fair enough, I'll take his word for it, my argument is incorrect. Downshift away friends!
