is it bad to run my front diff with no oil if i dont use 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97yota4wd, Nov 3, 2012.
  1. Nov 3, 2012 at 4:52 PM
    97yota4wd
    97yota4wd [OP] Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    okay so long story short my front diff hates me and i cant get the passenger side inner axle seal to stop leaking. took it apart and put it back together about 4 times now.
    i have went through 2 new seals so it cant be that....
    i have to use my truck tonight, i was wondering if it was okay to drive it but just not use the 4wd? i can pull my front drive shaft really easy. what do you think? as long as i dont put it in 4wd i would think its fine.
  2. Nov 3, 2012 at 4:55 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    if i understand the 4wd system right then you would have to pull the cv's for the front diff not to spin
  3. Nov 3, 2012 at 4:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Lockout hubs?
  4. Nov 3, 2012 at 4:57 PM
    97yota4wd
    Eric
    Mesa, AZ
    yes they are locking hubs so i can unlock and lock
  5. Nov 3, 2012 at 4:58 PM
    95 taco
    95 taco Battle Born
    then i would imagine it would be OK, personally i wouldn't do it but i think it would work.
  6. Nov 3, 2012 at 4:58 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Sounds a little crazy to me but if you pull both axles and cover the holes somehow, theoretically you can drive it if you don't engage 4wd.
  7. Nov 3, 2012 at 4:58 PM
    97yota4wd
    Eric
    Mesa, AZ
    and i would assume if its not locked in at the hubs the axle wont spin right? so the diff wont spin?
  8. Nov 3, 2012 at 4:59 PM
    97yota4wd
    Eric
    Mesa, AZ
    whats that going to do though? cant i just keep my axles in there and keep it un locked?
  9. Nov 3, 2012 at 5:01 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Unlocked you'll be fine. I actually drove a 91 I had a long time ago with no front diff in it at all for 2 weeks in the middle of a ring and pinion swap. Had the axles duct taped to the horns on the frame where the motor mounts are. It was fine. Would have been a mess had I locked the hubs though. If you've changed the seal twice and it's being installed correctly I would suspect the axle surface the seal rides on is damaged. You may need to swap another axle in.
  10. Nov 3, 2012 at 5:01 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Best advice- fix it. If you can afford to have that setup you can afford to have a professional take a look if you've already failed twice. Just my $.02 brother
  11. Nov 3, 2012 at 5:02 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Do you have manual hubs?
    If so then unlocked the shafts dont spin correct?
  12. Nov 3, 2012 at 5:03 PM
    Leggo
    Newton,Ma.
    sorry I didn't read that you are not talking about a 2nd gen.
    Unlock the hubs and you will be okay not using 4wd.
  13. Nov 3, 2012 at 5:03 PM
    97yota4wd
    Eric
    Mesa, AZ
    damit i just went out and had it in 2wd and drove and my axles do spin.....
  14. Nov 3, 2012 at 5:04 PM
    95 taco
    95 taco Battle Born
    yeah, manual hubs
  15. Nov 3, 2012 at 5:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm pretty sure if you unlock the hubs, the diff won't spin. Easy way to find out is, if you have a go pro, or a willing volunteer, unlock the hubs, keep the truck in 2wd and drive foward. See if the shaft from the front diff to the x-fer case moves at all. If it doesn't rotate as the truck drives ahead, you're good to go (it shouldn't move, there shouldn't be anything driving it).
  16. Nov 3, 2012 at 5:07 PM
    nfs257
    DFW
    She gone
    If they are spinning that means the inside gears are also spinning even if the diff isnt engaged. Tells me that it would NOT be ok to drive unless you pull the front arms...
  17. Nov 3, 2012 at 5:09 PM
    Pugga
    Massachusetts
    So... why won't you have oil in the differentials? Is it because of an oil seal or some other reason?
  18. Nov 3, 2012 at 5:12 PM
    97yota4wd
    Eric
    Mesa, AZ
    i work on all my own stuff, if i cant do it i usually know someone who can.. next week it will back apart and we will figure out whats wrong.
    but the axles spin?
    thats what i thought, we put it in 2wd and drove forward, the axles spun in opposite directions, one forward one backwards.
    pull the front axles you mean?
    what do i need to do to run in 2wd? pull my axles?
    a seal i think.... we have changed it 3 times and its not doing anything, i dont really understand. this side was fine untill i changed my driver side, once i changed my driver side my passenger side started to leak overnnight, i didnt even drive it.
  19. Nov 3, 2012 at 5:13 PM
    97yota4wd
    Eric
    Mesa, AZ
    will pulling my front drive shaft change anything?
  20. Nov 3, 2012 at 5:20 PM
    Pugga
    Massachusetts
    I think it's just spinning out of friction. There's no power to it, so if you could grab the front gear by hand, you could hold it still but with those hubs spinning, it's making the shafts spin and then the differential. I don't think removing the front shaft will make any difference. Does your truck have the ADD system or is it a manual transfer case and manual hubs?
    Even if it's a little low on fluid, just spinning will be fine, just keep an eye on it and don't run it dry.
