Is it bad to shift without the clutch sometimes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Aug 30, 2013.
  1. Aug 30, 2013 at 1:38 PM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    If you hit the exact right RPMs you can just pull it in gear with out the clutch. Is this bad for anything? I only do it for like 3rd and 4rth gears.
  2. Aug 30, 2013 at 1:40 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Like a "perfect shift" type situation?
  3. Aug 30, 2013 at 1:43 PM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    I do it all the time in my wife's Corolla. Also you rarely use the clutch to shift a truck, and when I say truck I mean semi or 10 wheeler (dump truck style).
  4. Aug 30, 2013 at 2:22 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    exactly, but its a bit of a pull but nothing over forceful. About 30mph for 3rd and 40mph for 5th.
  5. Aug 30, 2013 at 2:32 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    if your doing it right, I cant see it hurting anything. if you are putting pressure on it and waiting for it to "fall in" you are probly putting unnecessary wear on synchros.
    I had it about mastered in my 92. haven't tried it much with the new truck though.
    I have come to the conclusion that gas motors rev down too fast to make it easy to hit each gear correctly. and if you fuck up, and get it close enough to chatter, that's never good and was not accounted for in the trans design.
    unless your good at it, leave it to the big-rigs.
  6. Aug 30, 2013 at 3:58 PM
    Vmmvmmm
    Vmmvmmm Member
    Greg
    Riverton, UT
    White TRD O/R
    I once heard this is like catching a baseball with your teeth. You can do it, but there's a very high likelihood that you'll do some pretty good damage over time.
  7. Aug 30, 2013 at 4:12 PM
    Nfurtado77
    Nfurtado77 Well-Known Member
    As long as it doesn't grind it won't do any damage just make sure you match the revs properly.
  8. Aug 30, 2013 at 4:30 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    If it's done perfectly it's actually better than clutching BUT it's nearly impossible to do perfectly. If there's a grind then that's obvious damage, but even a delay with pressure on the stick before it drops in is wearing on the synchros more than clutching would. If you're good enough at it that it just drops straight into gear every single time with no clunk or delay then go for it, if it's even a little off use the clutch.
    Big rigs and some race trannys have no synchros and sometimes straight cut gears. These are totally different from what's in a normal vehicle and can't be compared as far as shifting technique.
    For 99% of drivers I'd say use the clutch.
  9. Aug 30, 2013 at 5:01 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you like your syncros yes.
  10. Aug 30, 2013 at 5:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Don't or you WILL be rebuilding the transmission. Use the clutch and don't skip gears, either.
  11. Aug 30, 2013 at 5:10 PM
    taco duck
    taco duck Well-Known Member
    SR5
    Why is skipping gears bad for the tranny?
  12. Aug 30, 2013 at 5:14 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Apparently the synchros don't line up correctly if you skip gears.
  13. Aug 30, 2013 at 5:23 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    When I had my FJ40 I could drive it without the clutch as long as it was moving without grinding any gears. Up or down. I loved that truck. I used to do it in my 89 when I was still driving it on the road. Now it rarely gets out of 1st on my property. As long as you aren't grinding gears or forcing the shifter to "pop" it into gear you aren't hurting anything. My current tacoma doesn't have a clutch pedal...
  14. Aug 30, 2013 at 7:12 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    My question is why? I drove a manual for 7 years years and 3 different cars, and never did it occur to me that pushing the clutch pedal was just too much work :confused:
  15. Aug 30, 2013 at 7:18 PM
    Nfurtado77
    It's just more of a challenge without a clutch.
  16. Aug 30, 2013 at 7:22 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    No you just have to double clutch it to prevent excess wear on the synchros. Another option is to wait for the input shaft to slow down enough to match the road speed preventing excess wear. Double clutching is just a faster way of doing that.
  17. Aug 30, 2013 at 8:11 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I used to do it all the time with this truck....
    I'm not sure I would try it on your Tacoma though. You either know what you're doing or you don't.
  18. Aug 30, 2013 at 8:52 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    It takes a bit of pressure to push it in but it never grinds.
  19. Aug 30, 2013 at 8:55 PM
    7six2Fan
    7six2Fan Well-Known Member
    Dave
    Maine
    '13 TRD Sport DC LB
    That's what she said.
  20. Aug 30, 2013 at 8:55 PM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    Well if it's bad for it then when the tranny goes bad you can just replace it with an automatic, since pushing the clutch is too much work for you
