Is it better to buy the pieces for a Timing Belt + Water Pump replacement separately or as a kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ctrl_Alt_Def34t, Jan 9, 2016.
  1. Jan 9, 2016 at 4:17 PM
    Ctrl_Alt_Def34t
    Ctrl_Alt_Def34t [OP] Member
    2000 V6 TRD
    HID Projectors | Switchback Turn Signals/DRLs
    Will I get higher quality parts by doing it one way over the other? What did you do and where did you buy your parts? This is for the 3.4L V6.
  2. Jan 9, 2016 at 4:20 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I bought a kit of eBay with all OEM parts. I'll look to see if I can find which one.
  3. Jan 9, 2016 at 4:27 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    You should check out trdparts.com. They have all genuine OEM parts for half price. And you know where you're getting it from.
  4. Jan 9, 2016 at 4:30 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  5. Jan 9, 2016 at 4:35 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
  6. Jan 9, 2016 at 4:36 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
  7. Jan 9, 2016 at 4:46 PM
    keakar
    karl
    louisiana
    the links are to a timing belt kits but I fixed the post so it reads correctly
  8. Jan 9, 2016 at 4:48 PM
    Looiz
    Looiz Well-Known Member
    Los Angeles
    95.5 RegCab
    ...blank canvas...
    This is the one I have purchased twice from the same vendor on Ebay. Was very pleased with it, all OEM (notice a difference in the price) and shipped it out right away. They go on sale from time to time so you can save a few extra bucks. They are not all the same so read the description and the list of parts carefully.
    http://www.ebay.com/itm/TIMING-BELT...CES-/180729034728?vxp=mtr&hash=item2a144a37e8
    Any other maintenance on the truck I would order OEM parts online. Specifically Here.
    Camelback Toyota Parts
  9. Jan 9, 2016 at 5:18 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    This, many of them say OEM and have most OEM parts but not all OEM.
  10. Jan 9, 2016 at 7:04 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I always use the Aisin kits.
  11. Jan 9, 2016 at 7:06 PM
    keakar
    karl
    louisiana
    if you want to spend $30 extra buying the exact same kit with the exact same parts from the exact same guy, then go ahead, but if you follow your own suggestion and read the list of what parts you are getting, you will see the kit I linked earlier is the same kit but at a $30 cheaper price with "slight" differences in description such as "koyo" instead of saying "Toyota koyo" but they are exact same part numbers. the only difference is this kit gets the parts direct from the Toyota parts suppliers, so you don't have to pay extra to buy an asin part box with a toyota sticker on it.
    as you said "read the description carefully to be sure what you are buying", I had conversations with "aircabinman" to see why he had different prices for the same kits and he told me "some people rather pay more to see a toyota sticker on the box" so those kits cost more because they are sourced through Toyota rather then straight from the mfg but the parts are exactly the same and made by the same mfg.
  12. Jan 9, 2016 at 8:37 PM
    Looiz
    Los Angeles
    95.5 RegCab
    ...blank canvas...
    :anonymous:... guilty pleasure.
    @keakar Thanks for sharing your correspondence with "aircabinman." Good to know for the next time I purchase a timing belt kit.
    keakar[QUOTED] likes this.
