Is it bump steer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeminyned, Jan 7, 2022.
  1. Jan 7, 2022 at 10:12 AM
    jeminyned
    jeminyned [OP] Well-Known Member
    Jerry
    2013 4 Dr Black Tacoma TRD Offroad
    Seat Covers and just getting started!
    Hello Tacoma Gurus, I recently got my 2013 DCSB Off Road lifted 3" Suspension Lift with the differential drop and sway bar relocation bracket installed and I've noticed that the steering wheel moves in relation to a bump or a dip in the road. I told the shop that installed it to set it at 2.5" but when I went to pick it up it looked like they maxed it out at 3" and it looked good so I left it that way. It has almost 129,000 miles on it . I'm thinking this is bump steer or is something worn out like lower ball joints or something else and wondering what I need to do to get it fixed.
    It's this kit: https://4x4.fatbobsgarage.com/toyot...orce-suspension-package-2005-2021-p33238.aspx
  2. Jan 7, 2022 at 11:02 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did they do an alignment post lift? If so, what are the specs, post up the post alignment spec sheet.
    drizzoh likes this.
  3. Jan 7, 2022 at 11:15 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Check your upper steering shaft that gets crusty
    jeminyned[OP] likes this.
  4. Jan 7, 2022 at 11:19 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This. Caster will need to be corrected with a lift that high. I put high caster UCA's on my third gen to remedy this. I believe it's the same situation on the 2g's. Truck is very happy sitting at 4 degrees of caster.
  5. Jan 7, 2022 at 12:30 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Are your UCA’s stock?
    jeminyned[OP] and DG92071 like this.
  6. Jan 7, 2022 at 5:48 PM
    TacoTuesday1
    SD CA
    bump steer happens on old Audi's and Porsche's because the tie rod shortens during suspension compression
  7. Jan 7, 2022 at 6:05 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    This, but anything with an IFS can get 'bump steer' if the tie rod angle isn't "flat" after a suspension lift. The steeper the angle of the tie rods (looking directly at them from the front of the vehicle), the more pronounced the toe in/out gets as the suspension cycles.
  8. Jan 7, 2022 at 7:58 PM
    DG92071
    DG92071 Well-Known Member
    At 2.5" or 3" of lift if you didn't change the UCA's you'll get a bump steer type of situation. The stock upper ball joint runs out of down travel with that much lift.
    jeminyned[OP] and Island Cruiser like this.
  9. Jan 8, 2022 at 9:03 AM
    jeminyned
    Jerry
    I got the SPC Light Racing Control Arms listed at the bottom of the lift page link and they charged me for an alignment but didn't give me a copy of the alignment specs.
  10. Jan 8, 2022 at 9:08 AM
    jeminyned
    Jerry
    I got the SPC Light Racing Control Arms listed at the bottom of the lift page link and they charged me for an alignment but didn't give me a copy of the alignment specs. I may take it to a different shop and have them do another alignment and correct the UCA angles if that's the problem and look at the tie rod angles like 2ndhandTacoma mentioned. Anything else to look for while they are at it?
    DG92071[QUOTED] likes this.
  11. Jan 8, 2022 at 10:44 AM
    jeminyned
    Jerry
    Thank You to everybody for your input on this problem and I will have it checked and see what they tell me. Much Appreciated!!!
    DG92071 likes this.
  12. Jan 8, 2022 at 6:27 PM
    DG92071
    Then it shouldn't be lack of upper ball joint travel. Front alignment makes a pretty big difference on my truck but I haven't experienced bad bump steer in a Tacoma yet so idk.
    jeminyned[QUOTED][OP] likes this.
  13. Jan 9, 2022 at 11:55 AM
    jeminyned
    Jerry
    It isn't bad bump steer, it's tolerable, but it is there and my OCD knows it's there!
  14. Jan 9, 2022 at 4:53 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    https://jdfabrication.com/collections/05-15-6-lug/products/howe-tc-pump-steering-kit
    read the product description
  15. Jan 10, 2022 at 3:01 PM
    jeminyned
    Jerry
    I read it, Nice! So that's what it is instead of bump steer. Well Dang! Bump Steer would be cheaper to fix if that's what it was! I may have to live with it for what that thing cost but I'd like to have it. I'd have to drive cross country to get it installed since I'm in Jawga! Thanks 81Trekker!
