Is it capable?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by old dad, Nov 30, 2016.
  1. Nov 30, 2016 at 8:24 AM
    old dad
    old dad [OP] Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    I need to transport a riding mower. Don't have a trailer for it. My question is can my base model tacoma and the tailgate support the lawn mower when using ramps to drive the mower onto the truck bed. The weight of the mower is 415lbs and I'm about 135lbs.
    Will the tailgate support this action?
  2. Nov 30, 2016 at 8:26 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Probably a few times... Look at some tailgate reinforcement parts. @KB Voodoo
    1Shifter and KB Voodoo like this.
  3. Nov 30, 2016 at 8:30 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I had the back wheels of a John Deere rider sitting right on the tailgate of my 2013......btu I also had our tailgate cap installed at the time.
    http://www.kbvoodoo.com/shop/powder-coated-tailgate-cap-system
    Toyko Joe likes this.
  4. Nov 30, 2016 at 8:31 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Might be dumb, but could you go to home depot and get some cheap piece of wood to lay over the tailgate to give it some reinforcement and have it underneath the wheels? Im sure with the weight of the mower the piece of wood likely wouldn't shift much.
    Coot
    Pigpen, Crom and Toyko Joe like this.
  5. Nov 30, 2016 at 8:33 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    I think the 08 and up tailgates are stronger from the factory. anything earlier and it will taco under the weight.
  6. Nov 30, 2016 at 8:37 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This is a good idea, and cheap insurance.
    I have an '09 and did internal repair to my tailgate. Worst my gate ever saw was me standing on it.
  7. Nov 30, 2016 at 8:42 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Hopefully you can get a piece of wood long enough for it to extend from the tailgate while its down to atleast a third of the bed that way the weight distribution can alleviate some of the load. Depending on how you plan to load the mower, you should be able to easily remove it from the bed if it starts to give although I would think you have some time to get it off if needed. Def will be interesting to hear how it goes either way.
    Coot
  8. Nov 30, 2016 at 8:43 AM
    old dad
    mark
    sc
    tacoma pickup
    n/a
    I looked at the tailgate-cap-system @KB Voodoo, nice, but I dont have the bucks(price is ok), nor time for it to get to me. I like and agree with @Coot83 on the board covering the tail gate. Will the cables hold up ok do you think?
    I'll be making the trip on the 9th of Dec and back on the 12th, so I may do a test load with my younger but bigger brother standing by before the trip and will let ya'll know.
    Nickel and Coot83 like this.
  9. Nov 30, 2016 at 8:45 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    It's fine
    I had a 2000 Standard cab 4cyl.
    I had a Yamaha banshee in the back of my truck going out riding all the time never had any problems..
    It was about 400Lbs pluss all my gear
    Coot83 likes this.
  10. Nov 30, 2016 at 8:46 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Damn that's another good question. Do you have any way to measure the mower from the front center of it to the edge of the back tires? Knowing how much distance on the rear tires might stick out might help in getting some idea of what the tailgate would have to support. Also if you have a shorter rear end you could also back it in to the bed as the closer you can get the wheels into the bed area will obviously help out the tailgate.
    Coot
  11. Nov 30, 2016 at 8:46 AM
    Toyko Joe
    Buy a 3/4" piece of plywood. cut out for the wheel wells. Ratchet strap the front and back down to the tiedown points... @Coot83 has a pretty economical plan here.
    Old School and Coot83 like this.
  12. Nov 30, 2016 at 8:48 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Well I think you took my plan and made it a reality. Im thinking OP you got some possibilities here.
    Coot
  13. Nov 30, 2016 at 8:49 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    You can rent a trailer for cheap, if it's a one-time thing...
    Jester243 and Toyko Joe like this.
  14. Nov 30, 2016 at 8:51 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Keep in mind weight closer to the tail gate support cables is not nearly as hard on the tailgate than weight right in the center.
    Crom and Coot83 like this.
  15. Nov 30, 2016 at 8:52 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah good point!
    Coot
  16. Nov 30, 2016 at 9:06 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Very true. The tailgate itself is strong around the edges, I found it's double sheet wall in some places there, it's the center that is weak.
    Edit: some pics over here
  17. Nov 30, 2016 at 9:09 AM
    old dad
    mark
    sc
    tacoma pickup
    n/a
    It's a rear engine snapper,,so I'm planning on backing it on so the the main weight during the trip won't be past the rear tires on the bed. I've got some wood, just will need to cut it to fit. Thanks for all the help,,I've never yet had a question here that has gone unanswered. Thanks again guys.
    old dad (not so old as just worn out)
  18. Nov 30, 2016 at 9:10 AM
    Crom
    Nick
    San Diego, CA
    Millions
    welcome
  19. Nov 30, 2016 at 9:25 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Take the tail gate off and use these:
    Crom likes this.
  20. Nov 30, 2016 at 9:36 AM
    Old School
    Old School You are ignoring covfefe by this member.
    @old dad You may need to consider AAL, or air bag assist if you plan to carry this mower a lot!
