Is it ever really necessary to install a lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18TRD_OR, Apr 15, 2018.
  1. Apr 16, 2018 at 9:53 AM
    #61
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The Off-Road model is pretty decent right out of the box. Just add taller tires and your good to go!
  2. Apr 16, 2018 at 10:05 AM
    #62
    Syncros
    Syncros Well-Known Member
    Haven't had a lifted truck in 10 years. I'm content with the capability of a stock midsize with an offroad package. To run proper trails here I'd need minimum of a 2.5" of lift, 10 ply 33's, re-gear, front locker, full skids, sliders, plate bumpers, a winch, recovery gear. Then I have to accept the fact that I'll be getting trail damage on my $$$ daily driver, burning fuel like an old big block with the passing power of a smart car in mountain passes.
    Only damage I've gotten where I travel is a dented skid plate and muffler. Can live with that, I'd rather run trails on 2 wheels anyway.
    Hawk45, tonered and hiPSI like this.
  3. Apr 16, 2018 at 10:13 AM
    #63
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    Sorry. Meant to ask how much hit to MPG?
  4. Apr 16, 2018 at 10:14 AM
    #64
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have a mountain bike that will run the trails lol. If I ever were possessed to want to four wheel hard core for fun again, I would just go buy a Jeep and spend a few grand fixing it up. That is the ultimate off road vehicle. Sucks on road, but off road it is king.
    Hawk45, Syncros[QUOTED] and tonered like this.
  5. Apr 16, 2018 at 10:27 AM
    #65
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    I'd assume about 1-2 MPG hit... it will be worse if you did a larger tire or E load.
  6. Apr 16, 2018 at 10:30 AM
    #66
    famof5taco
    famof5taco Well-Known Member
    Shelton
    VA
    17 TRDORDCSB
    pro grille, raised vinyl "TACOMA" letters on tailgate, de-badged, tint, ARE truck cap, BFG KO2s waterport, vinyl Tacoma inserts in dash, red "TRD Engine"push button start, MTF!!!
  7. Apr 16, 2018 at 10:33 AM
    #67
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    I say buy protection first and then wheel it and see where you need to improve it. If you are worried about losing OEM ride quality, don't be. Assuming you can pony up the cash, there are aftermarket kits that are loads better in terms of ride quality. My BP-51 is a good example of that.
    Like countless others have said, the Tacoma is pretty darn capable stock so you might get out there and realize you don't need to waste your money on a lift. Skids and sliders however are never a waste of money.
  8. Apr 16, 2018 at 10:37 AM
    #68
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Waiting is always smart. If later you feel you need it you will know exactly why. I did the 265s and was very pleased with the results. I’ve since lifted but not as far as I had planned and more for performance of the suspension overall than clearance and durability. A lot of off road trails are more about technical vs. technology, whereas lifts bring in trade offs and expense along with more ridicule than you might expect.
  9. Apr 16, 2018 at 10:46 AM
    #69
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Agreed on sliders for sure, skid plates maybe a little less critical but not bad money spent. I totally agree that there's no reason to be in love with the stock suspension. Even just a basic OME or Bilstein you'll see the difference on washboard and the higher end stuff just floats over the stuff. I started with a stock TRD OR, too, so it's not about the base parts either. Stock suspension isn't about the best off highway ride but on pavement.
    Also when you do start adding stuff like armor the stock springs will be quickly over matched, so you need higher rate ones anyway so might as well upgrade shocks, too. Load capacity is why I have some lift, though.
    The question is do you need 3" of lift and the answer is definitely no. But I don't like the way that Tacoma rear leafs are slightly negatively arched stock and definitely don't like riding on the overloads and bump stops off highway.
    So I put on stronger springs that only end up flat with load on the trails. This took about 2" over stock, which meant I added some front lift so I wasn't excessively raked. The 2.5" body shocks were a luxury, I know that. But I also don't see any reason for block lifts on stock coil overs. If you're going to lift, do it right at least.
    STexaslovestacos likes this.
  10. Apr 16, 2018 at 10:57 AM
    #70
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    265/75/16s. Stock
    285/70/17s. Lifted
    SilverII, Intrepid and Sdtrueblue like this.
  11. Apr 16, 2018 at 11:09 AM
    #71
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    My company vehicle is a 2013 TRD sport with a 6" drop bracket lift, blocks in the back and 33" tires. Rides like hell on road, constantly breaks front suspension parts, eats tires, and honestly, does nothing my stock 2017 SR5 cant do. Driving that truck cured me of any desire to mess with my suspension.
    Syncros likes this.
  12. Apr 16, 2018 at 11:14 AM
    #72
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    TBH if I could get stock-height rear leafs with more load capacity, I'd go with that and be happy as a clam. But uprated springs generally come with a lift, so I'll probably end up having to lift the front an inch or so anyway.
  13. Apr 16, 2018 at 11:25 AM
    #73
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Good reality check in this thread. I am running a stock OR and it's fine but I've been eyeing the FN fx pro 17s and 275/70/17s. If I can pull that off on stock suspension/height it will definitely be less stressful than having to deal with changing everything all at once.
    Intrepid likes this.
  14. Apr 16, 2018 at 11:35 AM
    #74
    Rowdymoon
    Rowdymoon Well-Known Member
    Courtice Ontario
    2017 Inferno OR SB Canada
    6112's and 5160's
    99% of all trucks out there ( regardless of brand) that are lifted....are lifted for looks only and not for practical reasons.
  15. Apr 16, 2018 at 12:14 PM
    #75
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    And the other 1% are on TW
    :transformer: :benchpress:
    xsf18cdf and FlyFisherCJ like this.
  16. Apr 16, 2018 at 12:19 PM
    #76
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    There are a couple of ways to get upgraded springs without lift but my experience (albeit on a pre-Taco Truck) is that springs you might see on commercial or contractor trucks can sometimes be so much higher rate as to be filling rattling if you don't have 750 lbs of stuff in the back. So it's something to ask of the vendor. Also custom packs are an option to get the right spring rate and height.
  17. Apr 16, 2018 at 12:22 PM
    #77
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's unfortunate that a shitty drop bracket lift put a bad taste in your mouth. A proper, small suspension lift is headache free when installed properly.
    jeremy5000 and DaveInDenver like this.
  18. Apr 16, 2018 at 12:24 PM
    #78
    eon_blue
    Azusa, CA
    Agreed, I wouldn't compare suspension lifts in general to drop bracket lifts...those are pretty extreme and if not done properly, can ride and feel like crap. A one to three inch suspension lift via front coils and rear leaf springs can ride just as nice (or better) than stock and not run the risk of drivetrain damage if done right. 3" is pushing it but with the right setup it can be done.
  19. Apr 16, 2018 at 12:40 PM
    #79
    eddie.b
    eddie.b New Member
    Edvin
    2017 Tacoma TRD OR
    Don't do your lift first. Like others have said here, what you will most likely need regardless of lift is going to be armor. So get some sliders/skid plates and hit the trails. You will quickly find out the limitations of your truck and depending on how much gear you carry you might start to sag and you might get away with an add-a-leaf over a full leaf spring replacement.
    This is the point where I upgraded mine. I went with a mild 2" lift which doesn't mess your geometry up and you don't have to do anything complicated. Really, this was mostly to bring it up a little bit over stock since I was sagging a lot and my rear would hit the bump stops all the time which was a bit annoying and to improve my ride quality in general with all the extra weight I had put on.
    I'm still on 32" mostly due to the unsprung weight. I am running Cooper AT3's in C rating which are 46 lbs per tire and perform well enough for me on and off-road. If I went up 1" in tire size and went with some ST MAXX's in E rating (which some will claim is a must) I would be at 59 lbs per tire. That's 13 lbs difference or 52 lbs total which is a pretty big deal and our trucks are dogs as is.
    DaveInDenver likes this.
  20. Apr 16, 2018 at 12:47 PM
    #80
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    Leveling looks better, IMO, but the rake is for hauling material. If rake was for handling, every vehicle would have it.
