Is it hard on ur clutch when u pay ur throttle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huntn57, Aug 17, 2014.
  1. Aug 17, 2014 at 1:33 PM
    Huntn57
    Huntn57 [OP] Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    Is it bad to pat throttle?
  2. Aug 17, 2014 at 1:58 PM
    gearcruncher
    Canadain bumper technician
    Would help if you could explain a little more ?
    If you are asking if you have to slightly gas the pedal while slowly letting the clutch out to get the truck moving , it would be dependant on the incline and the gear ratio .
  3. Aug 17, 2014 at 2:05 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    engaging the clutch puts wear on it-regular driving and regular loads should not-unless it is SLIPPING
  4. Aug 17, 2014 at 2:12 PM
    Huntn57
    Justin
    VA
    1995 Toyota Tacoma
    Patting the throttle when u take off
  5. Aug 17, 2014 at 2:24 PM
    gearcruncher
    Factory differential ?
    factory tires ?
    The proper way to let the clutch out when learning to drive a manual transmission is "Without" using the gas pedal . Once you have mastered this , adding a little fuel to the mix shouldnt be an issue
  6. Aug 17, 2014 at 2:31 PM
    Huntn57
    Justin
    VA
    1995 Toyota Tacoma
    Yes stock. I normally let the clutch out about half way then hit the gas. But I will admit sometimes I get a little to throttle happy. So it would be a lot better on hither clutch if I could take of with no gas. I have 3:53 gears so it really has to be flat when I can do it
  7. Aug 19, 2014 at 2:28 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    the only time its hard on your clutch is when you are using it if your foot is on the clutch you are wearing out its parts they are designed to be used just not excessively and having your foot half way down is the worst. there's a thing called idling away which is when you use no gas petal at all which is the best.
  8. Aug 19, 2014 at 1:57 PM
    Indy
    Indy Master of all I survey.
    Heh, with the 2.7 and oversized tires I'd end up wearing out my starter before I got out of my driveway :laugh:
