Is It Hard To Install A Lift On a 5 lug Base Reg Cab Taco?
Discussion in 'Suspension' started by tacomathunder, May 16, 2010.
  1. May 16, 2010 at 4:57 PM
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    hey guys, i have a regular cab taco that is base with the puny rims and tires.....5 lug....is it hard to install a lift on these 5 luggers??
  2. May 16, 2010 at 5:11 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    I have a 1st gen. 5-lug so I'm not sure about the 2nd gens but there aren't too many companies out there making kits for our trucks. I know Readylift has a kit for 2nd gens. I put spacers on mine to run a little bit bigger tires and payed $220 in labor b/c there was alot of disassembly to put them in. Our trucks don't have struts like the PreRunners and 4wds.
  3. May 16, 2010 at 5:14 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    oh damn....i really like those tires your running...look real good
  4. May 16, 2010 at 7:32 PM
    CUtigerfan
    South Carolina
    04 Base
    Thanks. they're Goodyear Wrangler Duratracs in 235/75. I would get them in 31×10.5s though if I had to do it again. If you put the Readylift kit on I think you could run them.
  5. May 17, 2010 at 12:26 PM
    ToeCutter66
    ToeCutter66 Active Member
    Kevin
    Sterling VA
    09 4x2 5-lug
    None, yet.
    I recently installed the readylift in my 09 base taco 5-lug. I was able to get the fronts and one rear done on a saturday, and got up early on sunday and was done before 10:00am. It is kind of a pain, some grinding/cutting is needed, so make sure you have a sawzall and a grinder handy. It also helps to use air tools.
    I would not do it again if given the chance. It was a pita, and now the truck rides like ass. If it was not so painful, I would remove the lift and stay with the stock ride. But the truck does look better.
  6. May 17, 2010 at 2:20 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    so you wouldnt recomend it??...its not worth it.....how can i get a good look at the stock height?
  7. May 17, 2010 at 2:24 PM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
  8. May 17, 2010 at 2:58 PM
    CUtigerfan
    South Carolina
    04 Base
  9. May 17, 2010 at 3:16 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I put a lift from Fat Bob's on my 5-lug. It's basically the same as the Readylift. I replaced the front struts and the rear shocks at the same time with some Bilstein HD's. The ride is about the same as stock. I've read several posts where people say their truck rides like a brick after installing the spacer lift, but mine rides just fine. I did the fronts on a Saturday and the rears on a Sunday morning. Had to cut off the top of one of the mounting studs on the strut top plate, but knew about that from the install video on Readylift's site. I like the lift and the way it looks now that I can run 31x10.5's.
    I wish I could have afforded to put on a Total Chaos mid travel UCA and SAW coilovers, but that'll have to wait. A few other users (neslerrah and Stupid Hurts) have also lifted their 5 luggers with the spacer lift. NakedTacoma has lifted his with total chaos stuff and is planning on long-travel I think.
  10. May 17, 2010 at 6:38 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    your truck looks really good...so how much did you spend overall for the lift and the Bilstein HD's, and re-gearing....??
  11. May 17, 2010 at 6:50 PM
    afd23a
    The Dynamo of Dixie
    Thanks for the complement. It's not quite done yet.
    The lift kit runs about $230-275
    Bilstein HD Shocks $280 for all 4
    Got a compete third member from another member for $500 for the regear. Haven't put it in yet though.
  12. May 17, 2010 at 6:52 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    so the re-gearing is necessary to have cuz of rpms, with new bigger tires?
  13. May 17, 2010 at 6:58 PM
    afd23a
    The Dynamo of Dixie
    Exactly. The computer has kind of adjusted itself a little bit, but there's still a power loss and low fuel economy. There are other folks on here who have done the same type of lift, but haven't regeared yet either. It can be a pricey thing to have done and can be hard to find the right gear ratio. That's why some people say it's better off just getting a prerunner or 4cyl 4x4 taco.
    Oh yeah, I installed the lift and shocks myself so there was no install fee.
  14. May 17, 2010 at 7:25 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    so the install was easy...im 18 and pretty machanically inclined so, i can do stuff, unlike other people i know...lol:D
  15. May 18, 2010 at 5:50 AM
    ToeCutter66
    Kevin
    Sterling VA
    09 4x2 5-lug
    None, yet.
    I had heard that the Bob's kit has longer AALs and is supposed to ride better. I am glad to hear that its true. I might contact them and see if I can just get the leaves.
    Also, Tacomathunder, I am an old guy (43) and have way less tolerance for a harsh ride than I did when I was younger. You might not find the ride with the readylift kit that harsh. Edit, I found it was easy to rotate the top plate on the strut if you use spring compressors. Also, get some big ass c-clamps for installing the rear aal's. I had a couple medium sized ones and completely trashed them.
  16. May 18, 2010 at 5:55 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Come to AZ, I can help with the install. I did my Readylift install in about 5 hours. When I had to replace my front stuts, it took less than 2 hours (for both)
  17. May 18, 2010 at 2:23 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    yea, i really like your truck a lot....that would be the dream truck for me
    also, how does your truck ride with the ready lift and new shocks?
  18. May 28, 2010 at 4:09 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    theres nothin to installin that kit replace the rear shocks with some from a prerunner and it rides [​IMG]fine to me
  19. May 28, 2010 at 4:14 PM
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
