is it hard to remove a "richmond" (lock-right) locker?
Discussion in 'Technical Chat' started by rab89, Mar 11, 2013.
  1. Mar 11, 2013 at 10:17 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I'm looking to buy a first gen, and want to remove the lock right that is currently in it. Do I need to re-set the backlash and other parts within the 3rd member? or is it simply remove the 3rd memeber, remove the lock right and re-install without the lock right?
  2. Mar 14, 2013 at 6:27 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    If you are exchanging the entire third member, you won't need to set up anything. If you are replacing the locker in the third member with another carrier assembly, then yes, you will need to set preload and backlash.
  3. Mar 14, 2013 at 7:42 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Define "remove lockriright"? Lockright replaces spider gears so if you remove lockright you will have to install spider gears with washers correctly installed. otherwise spider dears will chatter.
    You are better of finding open diff and swappign that and selling lockright diff.
  4. Mar 14, 2013 at 6:35 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    thanks guys, after driving the truck, it's really not that bad having the locker in there.
