Is it my shocks or my tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nh_yota, Aug 8, 2017.
  1. Aug 8, 2017 at 9:49 AM
    nh_yota
    nh_yota [OP] Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    So I got back yesterday from a 900-mile round trip out to Rochester NY this past weekend, and the drive was uneventful except for horrendous traffic on the Mass Pike on the way out, and a somewhat uncomfortable ride in my Tacoma.
    I bought the truck new in 2010 and have made plenty of long trips in it over the years, but this was the first time it's been out to western NY via the NYS Thruway. It has 94k miles and only 2k miles on the new Cooper A/T3 tires I had installed last month. The ride was noticeably bouncy, especially on a 20+ mile stretch of the Thruway west of Syracuse. At one point I thought one of my rear wheels lost a weight because it was so bouncy on that stretch of highway.
    Anyway, the tire pressures were 30 PSI cold all around when I checked them before I left NH and then again before I left NY. The tires are P265/75-16 so they are not LT rated, and I wasn't carrying anything in the bed. It was just me in the driver's seat and maybe a 150-200lbs of gear in the cab (it's a double cab).
    The ride was very harsh and bouncy like you get when the tires have too much air in them, which is odd because they weren't overfilled. I had the springs replaced last summer because of the most recent TSB, and the ride was actually improved over the stiffer 4-leaf springs I had after the first spring TSB in 2010.
    I had a set of Cooper A/TW tires in OEM size P265/70-16 before the A/T3 tires and I didn't experience as harsh a ride on the highway, so I don't know if it's actually the new tires making a difference or if I need new shocks. Would a set of 5100's in the rear help improve the ride? Or is there something else I should investigate? Maybe the A/T3's are just bouncy.
  2. Aug 8, 2017 at 9:56 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    1. Verify your gauge - compare to another.
    2. Verify bouncing on a couple of other roads.
    3. 94K miles, you may be ready for new shocks.
    greeneggsnspam and JAMES399 like this.
  3. Aug 8, 2017 at 10:00 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Shocks. And verify the balance on those wheels too. If they feel like they are bouncing up and down, thats a static balance issue if the shocks are still good.
    Any oil coming from the shock bodies? A tell tale sign of a blown shock.
  4. Aug 8, 2017 at 10:10 AM
    nh_yota
    Jeff
    Portsmouth, NH
    As for my pressure gauge I have one of these and I'm fairly confident about its accuracy. The tires have been balanced twice by my local tire shop since new (they are only a few weeks old) and they ride smooth except for a little vibration around 55 mph. I am having them road-force balanced by my Toyota dealer tomorrow morning to see if that makes any difference.
    As for the shocks, I haven't notice any leaks but I also haven't looked at them under the truck in a few months.
  5. Aug 8, 2017 at 10:24 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Are you sure its not just the new tires?
    JoefromPTC likes this.
  6. Aug 8, 2017 at 11:58 AM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    Have the original tire shop check that the tires are round - some tires come from the factory out of round (even slightly) and this cannot be corrected. No amount of balancing will solve that problem. If they are out of round, they need to be sent back. I've had this happen before. Not very common, but it's possible 1 out of the 4 tires could be bad. I'm running Cooper AT3's on two trucks right now, no issues whatsoever.
  7. Aug 8, 2017 at 12:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    Shocks don't have to leak to be worn out. In fact, most don't.
    At 94k they are worth changing, even if it doesn't fix your problem.
    I'd try lower pressure in the tires, using a tread chalk test to verify when you hit the right pressure related to wear.
  8. Aug 9, 2017 at 12:48 PM
    nh_yota
    Jeff
    Portsmouth, NH
    That's my plan.
  9. Aug 9, 2017 at 12:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    94k on original shocks, they are done. Replace them as they need to be replaced regardless (go 5100's all 4 corners and set the fronts at 0 if no lift is desired). Then go get your tires re-balanced.
    Clearwater Bill likes this.
  10. Aug 9, 2017 at 2:16 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I had the AT3 on my Ford Ranger and if I went by the placard on the door to inflate them it did bounce all over the road so I had to play with the air pressure for a few weeks the AT3 have a very stiff side wall so the normal tire pressure would make them even stiffer you may have to get down to a lower air pressure
    TOMB
  11. Aug 9, 2017 at 2:20 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Shocks wear out by around 100k?
  12. Aug 9, 2017 at 2:30 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    ^^This. Had that happen to me once. Noticed the wheel bouncing a lot only at a certain higher freeway speed, and was much less (almost non existent) driving on city streets.
    JoefromPTC[QUOTED] likes this.
