Is it necessary to torque leaf spring bolts??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMoose, Nov 17, 2016.
  1. Nov 17, 2016 at 5:11 PM
    TacoMoose
    TacoMoose [OP] Well-Known Member
    2017 Tacoma OR
    I searched all over but could not get a straight answer. im doing leaf springs tomorrow and I'm not sure if i should buy a torque wrench to torque the U bolts and 2 bolts on both ends of the leaf spring. some people say you should torque it and others said just hit it with a impact. any thoughts ? ?
  2. Nov 17, 2016 at 5:18 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Just buy a torque wrench because it is super nice to have anyways. Nearly everything on your vehicle has a torque spec, even the oil drain plug.
    tacoman45 and Norton like this.
  3. Nov 17, 2016 at 5:19 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I prefer to torque my bolts/nuts when working on vehicles/motorcycles. A torque wrench is a worthwhile investment IMO.
    RobZ9132, spiralout462 and trdNick like this.
  4. Nov 17, 2016 at 5:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Cross threaded or torqued to spec, tight is tight.
  5. Nov 17, 2016 at 5:41 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Every bolt on your truck has a torque value.
    For a reason? Sure. Maybe not to save your life, but it's easier to torque it properly than it is to go out of your way to rip the shit out of it with an impact.
    Hardscrabble likes this.
  6. Nov 17, 2016 at 6:15 PM
    TacoMoose
    2017 Tacoma OR
    Thanks guys. I'll buy a torque wrench tomorrow. better safe than sorry
    Norton and timbobzimbob like this.
  7. Nov 17, 2016 at 6:23 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    A torque wrench is a must-have for u-bolts and wheel nuts, among other places. And don't torque your u-bolts to the 37 ft-lbs spec in the factory service manual either, that is WAY too low. 73-80 ft-lbs with lubed threads works well for 14mm u-bolts which these are, and was the spec for previous generations of Toyota pickups / Tacomas.
    spiralout462 likes this.
  8. Nov 17, 2016 at 6:23 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    It will make your life easier in the long run!
  9. Nov 17, 2016 at 6:28 PM
    TacoMoose
    2017 Tacoma OR
    Ill torque the u bolt to 80-90. what about the shackle and front leaf spring bolt? anyone have a torque on that? ive seeb numbers from 60 to 120
  10. Nov 18, 2016 at 7:46 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Spec is 89ft-lbs for the spring eye and shackle bolts. Leave them loose until everything is assembled and the truck is sitting on the suspension to prevent excess torsion of the rubber bushings in the normal position, which will accelerate bushing failure. Unless you are using polyurethane bushings, in which case it doesn't matter.
    http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/039012.pdf
    winkel likes this.
  11. Nov 18, 2016 at 7:49 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
  12. Nov 18, 2016 at 7:50 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Cross threads are strong threads.
    Also adding a little Loctite also helps.
  13. Nov 18, 2016 at 7:52 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Don't lube the threads! 80 ft-lb with lubed threads would be like 160 ft-lb dry, which is too much and can cause the U-bolts to yield or crack.
  14. Nov 18, 2016 at 7:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    I use a torque wrench on all moving suspension areas. Not to make sure it's tight enough, but to avoid over tightening. And it's important to know if a component is supposed to be torqued while loaded or unloaded, so you don't get binding.
    Also use for engine internals, spark plugs and sometimes on really light torque items, like ones measured in inch lbs.
    Everything else is done by feel. 'Cause I feel good (@lotuscupcar)
    Norton and PROseur like this.
  15. Nov 18, 2016 at 8:01 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    NO, it would not be equivalent to 160 dry. Depending on the lubricant, and any plating on the threads, the difference is roughly 10%. So 73 lubed is roughly equivalent to 80 dry, but with more consistent clamping force on all legs of the u-bolts.
    winkel, Too Stroked and Jemm63 like this.
  16. Oct 15, 2018 at 10:54 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    How can you tell if bolts should be torqued while loaded or unloaded? Im assuming Leafspring, shackle and ubolts should be loaded when torqued?
  17. Oct 16, 2018 at 5:09 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Easy. If the bushing is a captured bushing, you torque it with load. Captured means the bushing is bonded to the shell/sleeve. If the bushing is not, and you could theoretically spin the control arm/leaf spring/component 360 degrees without the bushing binding, you can torque it any way you wish.
  18. Oct 16, 2018 at 6:00 AM
    Slvr14tacoma
    Mid travel
    Good to know thanks
  19. Oct 16, 2018 at 7:09 AM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    everything has a torque rating for a reason
    dont mess with good engineering!
    Slvr14tacoma likes this.
  20. Oct 16, 2018 at 9:55 AM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Re-torque the U bolts after driving around too. I re-torqued mine once a week for about 5 times lol. The nuts kept tightening a little more until finally one day there was no more movement, everything truly tight and even. I did 90 ft-lbs dry, with OME U-bolts/nuts on OME springs with an angle shim.
