Is it necessary to torque leaf spring bolts??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMoose, Nov 17, 2016.
  1. Oct 16, 2018 at 11:37 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I don’t always cross thread bolts but when I do I run that bitch down tight with an impact.
    MR5X5, JC15Taco and jv_74 like this.
  2. Oct 16, 2018 at 11:41 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Just JB Weld that shit.
    JC15Taco likes this.
  3. Nov 21, 2019 at 4:34 PM
    Aagill225
    Aagill225 Well-Known Member
    Arthur
    2004 Tacoma PreRunner
    None
    These comments though hahahahaha
    I’ll be installing mine very soon. Just waiting for a dry day. It started raining.
  4. Nov 21, 2019 at 5:33 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    If you intend to do any amount a wrenching on your vehicle, you should invest in a torque wrench.
  5. Nov 21, 2019 at 5:34 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Finger tight might be good enough.
  6. Nov 21, 2019 at 5:36 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    And we have a third opinion!!! :rofl:
    Cudgel[QUOTED] likes this.
  7. Nov 21, 2019 at 5:39 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Torque it to German specs "good n tight"
  8. Nov 21, 2019 at 5:42 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    A couple of track welds for good measure too.:welder:
  9. Nov 21, 2019 at 5:45 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I couldn’t resist. I’m not a pro mechanic and I’ve broken my fair share of bolts (more since they come from China with dubious markings) but the concept of NOT torquing suspension parts really scares me...I get it that complete fucking idiots drive on the same roads I do, but I assumed guys doing their own lifts at least read the instructions, especially if it was the first time using a wrench.
    JC15Taco[QUOTED] likes this.
  10. Nov 21, 2019 at 5:49 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    No need to explain Cudgel...knew exactly what was going on there!
  11. Nov 22, 2019 at 4:56 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yes, any time you put lube on a bolt that is required to be torqued, the lube changes the torque value. Unless a torque value is called for with a specific lube it should be done dry.
  12. Nov 22, 2019 at 6:02 AM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Just put a condom over the bolt and if you accidentally bust the nut the bolt will stay dry ensuring a proper torque - safety first.
    Silentshredr likes this.
  13. Nov 22, 2019 at 6:06 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  14. Nov 22, 2019 at 6:10 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Buy a torque wrench. They are cheap enough. You don’t need the professional ones you see on TV.
  15. Nov 22, 2019 at 12:30 PM
    #35
    96carboard
    96carboard Well-Known Member
    Lets put it this way: How badly do you want your axle housing to NOT fall off?
  16. May 22, 2024 at 10:33 PM
    #36
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    the 4 bolts your leaf springs are sitting on carry half the weight of your truck and all the junk we throw in it, do run a torque wrench on them they deserve it.
    Also, do not try to hammer these precious bolts through because the angle isn't perfect.
    Don't get me wrong, they can handle tapping but i've seen people try to jackhammer the bolt through the hole with half the eyelet lined up, its not pretty, neither is the grating sound of the nut as it torques out way below it should have.
    use ratchet straps (be sure to clear the brake lines) and a smaller jack to help line things up, raise and lowering the leaves will help get that rear shackle worked out.
    i needed a crowbar to wiggle one side since the leaves had a slight twist to them.
    wow, how did i not notice this thread was 5 yrs old? lol
    Steves104x4 likes this.
  17. May 23, 2024 at 7:18 AM
    #37
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Said his shaft was 8 inches, how would he know how tight it is?
    Use a Torque wrench or deal with the consequences.
    Life is too short to cheat your self over this.
  18. May 23, 2024 at 7:32 AM
    #38
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Nice thread bump..
    I think i went 80 lbs and checked/retorqued once a week for a month
  19. May 24, 2024 at 10:40 AM
    #39
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Buy the torque wrench and use it. While you can get away with a couple ugga duggas it may not be correct. I discovered that my ugga duggas were way to tight for my front suspension so now I have to go back through all the bolts with my torque wrench.
