Is it normal for MPG to greatly decrease after 70+ mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taco_newb, Jan 11, 2018.
  1. Nov 24, 2021 at 7:14 AM
    #101
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, I get just short of 21 mpg running 70 mph on cruise feeding the 4.0L and Automatic.
    Over that.....mpg tanks. Also, figure out the gain in time.......
    Simple example: Drive 70 mph, you cover 70 miles in 1 hour. Drive the same 70 miles at 80 mph, you cover the distance in 52.5 minutes......you arrive 7.5 minutes earlier. Really its not much of a gain, especially in the typical 10-20 mile run. Generally, traffic will disturb a steady speed.
    shotgunbilly420 and RedWings44 like this.
  2. Nov 24, 2021 at 7:19 AM
    #102
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    The air dam isn't on the hood...………………….. its under the front bumper. The OR doesn't come with one and the Sport does
    Doggman likes this.
  3. Nov 24, 2021 at 7:20 AM
    #103
    Iltwort
    Iltwort Well-Known Member
    Then why do we all need to drive so fast? Being slow is really dangerous, especially on the morning run. Coming home is less stressful.
  4. Nov 24, 2021 at 7:21 AM
    #104
    Iltwort
    Ohh... And the OR can't have one because? Not that I want to do modifications for gas mileage.
  5. Nov 24, 2021 at 7:24 AM
    #105
    Knute
    Outside of cities, I roll in the RH lane on cruise set at 70 mph. In cities, cruise is off, I run with the traffic.
    cryptolyme likes this.
  6. Nov 24, 2021 at 7:26 AM
    #106
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I got 21.1 according to the trip meter, this morning. It gets much better in the summer. But I find going a little slower (than the 75 MPH speed limit) results in gas savings, not that much time loss, and I'm not angry at traffic since I'm not catching vehicles at the same rate. Plus, if I'm running behind, I have a little room I can use to step it up if needed.
    shakerhood likes this.
  7. Nov 24, 2021 at 7:42 AM
    #107
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    This is so true. I like driving quick but I hate to admit that being on the lower end of the average speed is much less stressful then being on the upper end and the loss of time is not that great.
  8. Nov 24, 2021 at 7:46 AM
    #108
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I travel 140ish miles a day for work and yes not using cruise helps mpgs . I try to keep it around 65 to 67mph
    zoo truck likes this.
  9. Nov 24, 2021 at 7:47 AM
    #109
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Mpg wise, manual sucks going faster than 65-70. I can get 24.75 in the summer driving 55-60 hah.
    MTs have 4.30 diff gear ratio so they run higher rpms on highway than ATs.
  10. Nov 24, 2021 at 7:47 AM
    #110
    Snoman002
    Sno
    21 DCSBORSWMT
    Radar cruise or steady speed cruise? I find the opposite to be true usually, but that is on the set speed cruise.
  11. Nov 24, 2021 at 7:49 AM
    #111
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    No you don’t. That thing might give you .5 mpg if you are lucky.
  12. Nov 24, 2021 at 7:55 AM
    #112
    RedWings44
    Michigan
    A multitude of factors come into play. I'd assume by this point you're past the break in. However, short trips kill MPG. Over 70 MPH kills MPG, especially in 4x4 pickups. Also, colder weather will cause the computer to adjust the fuel mixture, and not to mention winter gas is worse for MPG in general.
    As for your other comment about speed, having driven in Detroit I can personally attest that no, you do not NEED to go 80 MPH. Especially if you find yourself on 10 where the speed limit is actually 55.
  13. Nov 24, 2021 at 8:00 AM
    #113
    ryanvar42
    None
    because its tailored to the off road crowd so it doesn't come with one to have a better approach angle for offroading. it can have one it just doesn't because of that
  14. Nov 24, 2021 at 8:03 AM
    #114
    ryanvar42
    None
    Nah, I took it off and got 1mpg and put it back on and get 1.7. your math is off
    Junkhead[QUOTED] likes this.
  15. Nov 24, 2021 at 8:10 AM
    #115
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    .7 mpg?
    :rolleyes:
  16. Nov 24, 2021 at 8:11 AM
    #116
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Yup, your MPG will be better in spring/summer. Wait till it snows and you are in 4x4 for a full tank... 10-12mpg here we come :)
    Air dam is the part under the bumper. It doesnt come on OR's or PRO's. it increases mpg by about 5% on the highway.
    RedWings44 likes this.
  17. Nov 24, 2021 at 8:12 AM
    #117
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    One thing I've learned from TW is many people are FOS when it comes to mileage.
    You'll see someone with a stock 2wd auto 3.5 averaging 21mpg at 55 and some yahoo that claims 28mpg average at 85 mph with his full skids/bumpers/lifted 4.0 on 35's...
  18. Nov 24, 2021 at 8:29 AM
    #118
    ryanvar42
    None
    :rofl:
  19. Nov 24, 2021 at 8:41 AM
    #119
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    I agree.
    Adaptive CC = bad MPG
    Manual CC = Can be great if <72 MPH
    At least that's my experience.
  20. Nov 24, 2021 at 8:53 AM
    #120
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Also depends on conditions. Hilly terrain and CC will hurt mileage.
    I live in the middle of nowhere, no traffic, pan flat and straight roads, and have a manual. I haven't done the math but I can't imagine I'd get worse mileage using CC than without under these conditions.
    Snoman002[QUOTED] likes this.
