Is it normal for tacomas wobble? 22 TRD offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beakerthemuppet, Feb 6, 2022.
  1. Feb 6, 2022 at 9:27 PM
    beakerthemuppet
    beakerthemuppet [OP] Member
    Got my truck two weeks ago. I noticed a slight back and forth wobble at like 70kmh. I thought it was the road. Now I’m thinking maybe wheel balancing on the rear. The dealer said that tacomas do wobble a bit at a certain speed but they will check it out. Is that right or are they talking crap? Also one of my rear fenders looks like it’s not flush to the body and there’s a gap in the sealant. They’re fixing it so I don’t care but I’m wondering how common that is just out of curiosity. They also dinged my plastic bumper guard. They’re replacing that too.
  2. Feb 6, 2022 at 9:51 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds like something is wrong, no wobbles in my truck.
    toku58 likes this.
  3. Feb 6, 2022 at 9:52 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    sometimes factory tires come poorly balanced from the factory. that’s what i’ve experienced with my Tundra.
    toku58 likes this.
  4. Feb 6, 2022 at 10:10 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Sounds like the flimsy rear hangers flexing to me, Archive Garage Hammer Hangers fixed my rear wobbles.
  5. Feb 7, 2022 at 7:40 AM
    klatekin
    klatekin Active Member
    2017 MGM TRD OR 6MT
    Have them re-balance the tires
    shakerhood and toku58 like this.
  6. Feb 7, 2022 at 7:49 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Did you get the Weebles edition? If yes be assured that it won’t fall down.
  7. Feb 7, 2022 at 7:53 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    shakerhood likes this.
  8. Feb 7, 2022 at 7:58 AM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Sometimes I get get wobbly but my Taco...not even at 85
  9. Feb 7, 2022 at 7:59 AM
    Frito
    Frito Well-Known Member
    Yes and also physically check your pressures with a good known gauge and compare them to the computer.
    GreenTaco22 likes this.
  10. Feb 7, 2022 at 8:54 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    If you want to see something else wobble - check your idler pulleys ! Dealer said they are designed that way ?
    You could rotate the tires to the front just to see if there is a change ?
  11. Feb 7, 2022 at 9:12 AM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    If it is at a specific speed, you probably have a balance issue. If it occurs as a result of the suspension cycling, it's bump-steer and the result of alignment or suspension issues. Other than that, you may have an unusual wear pattern on a tire or tires and that pattern may be grabbing parts of the road and making it walk around. I've seen that before where tire rotation was neglected and then someone decided to rotate them.
    Tacomas do not have a "wobble" as they are built. Whoever said that is either lazy and does not want to address the problem or does not know what he is talking about.
  12. Feb 7, 2022 at 1:05 PM
    beakerthemuppet
    No it’s factory. It’s got a factory lift on it as it’s the TRD offroad. I’m leaning towards rear wheel balancing being off. I’ll get them to check it. I’ll hopefully have it in within two weeks.it seems to come and go but it’s there on a smooth road at maybe 50-70kms
