Is it ok for spare tire to be 1" smaller in diameter?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Mar 24, 2021.
  1. Mar 25, 2021 at 5:17 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I have 255/80's on my truck and a stock size spare still. I had 265/17's before with same stock spare. I figure the small spare will get me to a tire shop fine for repairs.
    tonered and Junkhead[OP] like this.
  2. Mar 25, 2021 at 5:43 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    A friend's Jeep with 3 worn 37s and the new spare will cause the traction control to kick in on the highway. Just another interesting thing that can be caused by different sizes.
  3. Mar 25, 2021 at 5:52 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Not if you do 5-wheel rotations like I do.
    Junkhead[OP] likes this.
  4. Mar 25, 2021 at 7:18 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Yeah, it's a little more difficult/expensive with tpms and rim-matching
  5. Mar 25, 2021 at 7:33 AM
    Junkhead
    Junkhead [OP] TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    That’s not bad at all.
  6. Mar 25, 2021 at 7:35 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    How would you rotate to the front with 1 jack though?
  7. Mar 25, 2021 at 7:35 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Just a bit;)
  8. Mar 25, 2021 at 7:37 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If you are out on the trail you jack up the rear, take off the rear tire. Then put your flat tire on (dont need to put the bolts on tight, just thread them on) Then jack up the front, swap the tire, then jack up the rear again and put the tire on and put your flat back.
    You can also put logs under the rear axle, but thats not nearly as stable as bolting a wheel (even with flat tire) on.
  9. Mar 25, 2021 at 7:48 AM
    Lt. Dangle
    Ohio
    I should add that I have a plug kit and air compressor so repairs can be attempted before needing the spare.
  10. Mar 25, 2021 at 7:51 AM
    RIDER34
    RIDER34 Well-Known Member
    16 Inferno SR5, 18 magnectic gray SR5 4x4
    IMO Its the spare tire, Will be temporary just to get the closest tire place to get the problem solved. Cant recall the last time I used my spare tire. knack on wood.
    vicali and Lt. Dangle like this.
  11. Mar 25, 2021 at 7:54 AM
    Lt. Dangle
    Ohio
    Pretty much my mindset. I've lowered mine a couple times to lube the lift mechanism and turn the tire over so I could check the PSI on it, but otherwise it's just there.
    RIDER34[QUOTED] likes this.
  12. Mar 25, 2021 at 7:57 AM
    5nahalf
    Erik
    Minnesota
    Ive been driving for 20 years, I have used exactly zero spares on my own truck, but I used a spare on my wifes truck once, and it was a snow tire so she shredded it driving for a little bit.
  13. Mar 25, 2021 at 7:59 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I bought a full-size spare but a friend made a valid point - if I never use it, it may just disintegrate over time and be useless anyway
  14. Mar 25, 2021 at 8:02 AM
    RIDER34
    If yo want to go by the books, you should do a 5 tire rotation.... not me :D
    Kerbouchard! likes this.
  15. Mar 25, 2021 at 8:09 AM
    #35
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The most flexible, safest thing to do is just have a tire of the correct diameter. You don't know where you'll be when it goes so you may have to be on that spare for a while.
    I usually get a used spare, or rotate in the best tire from my last set.
  16. Mar 25, 2021 at 8:11 AM
    #36
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    This is a good point...something I was considering a few days ago.
    Has anybody ever put the OCD effort into starting with 5 matching tires and rotating all five a specific intervals so that the "spare" gets worn evenly. So, technically there isn't a spare, there is just a fifth tire.
    Edit: this got answered above in the time it took me to type the question.
    Malvolio likes this.
  17. Mar 25, 2021 at 8:15 AM
    #37
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I came here to say the same thing. That's why it is for emergencies. This is the first vehicle I've ever owned with the spare being the same size as the tires that are on the truck. Even my GMC pickup had a smaller spare even though it was still considered a full size spare. Basically, it's to get you to a repair shop and not to drive every day like some people do.
    FWIW OP, I had to drive around on my spare in my GMC for about a week while I waited on a new tire to come in (long story). The spare was roughly an inch smaller than the stock tires. I didn't seem to notice any issues.
    RIDER34 likes this.
  18. Mar 25, 2021 at 8:21 AM
    #38
    RIDER34
    Wonder if the Toyota care includes the 5th wheel rotation , just to not void my tire warranty :D
    Will ask that when my tire rotation is due under the Toyota Care program.
  19. Mar 25, 2021 at 8:29 AM
    #39
    Kerbouchard!
    Englewood, CO
    fishin' tank
    What's the pattern and timing? Meaning, usually a 4 tire rotation is back-to-front, side-to-side. When you rotate in the fifth where do you put it and which tire gets pulled out?
  20. Mar 25, 2021 at 8:30 AM
    #40
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    6 tire rotation would be the best
