Is it ok for spare tire to be 1" smaller in diameter?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Mar 24, 2021.
  1. Mar 25, 2021 at 8:31 AM
    #41
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Open diffs mean it doesn't matter - it's not a Subaru (or awd with slipping clutches)..
    TireFire and therealprotaco like this.
  2. Mar 25, 2021 at 8:31 AM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. You would just want to stay out of 4wd on hard packed surfaces. Basically, it will end your wheeling day, but will get you back home.
    Junkhead[QUOTED][OP] likes this.
  3. Mar 25, 2021 at 8:34 AM
    #43
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Its not good for the diffs to be constantly making up that difference in speed when going straight instead of just in corners.
  4. Mar 25, 2021 at 8:56 AM
    #44
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    It will be alright to get you home or to the tire shop until you get a tire replaced/repaired.
    I know the shuffle, our forester spare goes on the back and fuse gets pulled under the hood.. it's an added pain in the butt.
    265/65 to 265/70 is not going to explode a diff.
  5. Mar 25, 2021 at 9:09 AM
    #45
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Luckily a good friend of mine has a lift I have access to. But I’ve done it with a floor jack.
  6. Mar 25, 2021 at 9:13 AM
    #46
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    grogie and Kerbouchard![QUOTED] like this.
  7. Mar 25, 2021 at 9:20 AM
    #47
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Other than the 5 tire rotation guys or when you upsized, when when was the last time anyone replaced their spare? I always put the spare on the rear for the short (50 miles or less) drive to get it fixed. Especially if I'm helping someone I don't know. The spare is normally smaller or old/ in crappy shape. If it blows out the vehicle will be more controllable if that happened on the rear.
    For my spare I normally take the best tire of the 4 I'm running at the time of replacement and have that mounted as the spare. I also carry a plug kit and oba.
  8. Mar 25, 2021 at 9:29 AM
    #48
    0xDEADBEEF
    True, but then you're dependent on the assumption that you'll be able to get to a tire shop in a short distance. The first and only time I've needed a spare it was 10pm on a Friday night and I was in the middle of Kansas. I had a decent spare and that let me finish my trip without worry and deal with it at my leisure, which turned out to be a couple of days later. 100% worth having the right size tire IMO.
  9. Mar 25, 2021 at 9:59 AM
    #49
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
  10. Mar 25, 2021 at 10:00 AM
    #50
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Hmm, so when I switch from 255/70R17 winters to 265/70R17 Summers I'll need another spare, blizzaks are $241ea, and then a wheel is going to be $90, plus $289ea for another ToyoRT as my summer spare.. So you figure spending $620 plus mount+bal is better off than maybe having to put a 1"or 1/2" diam difference wheel on an open diff in an emergency?
    I've daily driven a Tacoma for 10 years now, and went 12 years before that with a 86 pickup.. needed the spare zero times.
    I'll just keep my OEM spare IMO.
  11. Mar 25, 2021 at 10:05 AM
    #51
    0xDEADBEEF
    So, you're saying people have different situations and the same thing doesn't work for everyone?
    Malvolio and vicali[QUOTED] like this.
  12. Mar 25, 2021 at 10:06 AM
    #52
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I've always done five tire rotations on a Jeep with matching wheels and tires, that way I use the spare, always have a matching spare, and it's got equal wear. I'd like to do the same with my Tacoma but I'd have to get a matching wheel, and of course the issue with the TPMS. Another nice thing is just makes rotating ires easy ... raise up a wheel, replace, move to the next!
  13. Mar 25, 2021 at 10:08 AM
    #53
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Malvolio and 0xDEADBEEF[QUOTED] like this.
  14. Mar 25, 2021 at 10:14 AM
    #54
    JasonLee
    15 TRD OffRoad
  15. Mar 25, 2021 at 10:50 AM
    #55
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Specific Tpms sensor would have to be reprogrammed every time
    Tacowin1013 likes this.
  16. Mar 25, 2021 at 10:56 AM
    #56
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Alright, this thread seems to say you can't add a 5th TPMS sensor to the ECU: https://www.tacomaworld.com/threads/is-it-possible-to-add-a-5th-tpms-sensor.426434/
    However, this video seems to have the practical answer: https://www.youtube.com/watch?v=kkJJabCQaqA
    The TPMS sensors turn on based on centrifugal force or changing the air pressure. The receiver to pick up all 4 drive wheels is mounted in the rear passenger side a-pillar. Based on what the guy is saying, yes, you can install 5 TPMS sensors. The catch is that you have to program your truck to the active TPMS sensors.
    So, that would mean you'd have to:
    -label each tire and know the TPMS serial numbers
    -Rotate your tires
    -Drive a bit to make sure all 4 drive tires are activated and the 5th tire shuts itself off
    -use Techstream to reprogram your ecu to pick up the 4 active sensors
    eurowner and grogie like this.
  17. Mar 25, 2021 at 11:03 AM
    #57
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    If i had a full lift in my garage where it would make dropping the spare and rotations seamless, yes I would be the type of person to rotate my spare into rotation. But no, i dont, and no i never touch my spare except once a year when i check the tire pressure and fluid filim the area
  18. Mar 25, 2021 at 11:13 AM
    #58
    JasonLee
    15 TRD OffRoad
    It's not hard to do 5 wheel rotations with just a jack (and your level of safety - I also support that corner with a jackstand). I never have more than one wheel off the truck at one time.
    Now a 4 wheel rotation - that's when you have at least 2 wheels off the vehicle.
  19. Mar 25, 2021 at 11:16 AM
    #59
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    For those using a 4 tire rotation
    If you have a matching full size spare with 17mm tread depth, and after 50k miles your other four tires have 4mm tread depth left, the spare is 1 inch larger. (13mm on the top of the tire + 13mm on the bottom = 1 inch) So it's equally good for the spare to be 1 inch smaller because after 50k miles it will actually be the same size.
  20. Mar 25, 2021 at 11:20 AM
    #60
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    What tires are you running with 17mm of tread depth? 8-9mm is avg for new tires.
