Is it ok to hit the redline?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimbo2, Aug 5, 2018.
  1. Aug 9, 2018 at 10:23 AM
    #141
    Joisey
    Joisey Well-Known Member
    I had a neighbor with a 75 350 V8 Chevy half-ton pickup, three on the tree that he bought new. He was in third gear faster than my automatic Tacoma can do it and he never exceeded 2000 rpm. He also never downshifted after making a severe turn, like turning into a side street. It was just his driving style.
    I did all of the maintenance work for his vehicles. I put three complete clutches in that truck in just over 100K miles. Four complete sets of U joints. Spark plugs lasted about 10K (electronic ignition) and had to be replaced because the porcelain shattered from preignition. The cause of the preignition was too much of a load on the engine at too low of an rpm...classic lugging of an engine. I tried lower heat range spark plugs and they were of no help. The engine had an oil burning problem, most likely from digesting those shattered pieces of spark plug porcelain.
    There is damage to be done at both ends of the rpm scale.
    tinker_troy and Wulf like this.
  2. Aug 9, 2018 at 10:29 AM
    #142
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What the fuck are you talking about? Literally LMFAO! Ever heard of a rev limiter???
    Ignore this guy OP, as long as you give your engine oil 5-10 minutes at moderate RPMs it's plenty fine. Actually it's beneficial to run high RPMs occasionally.
    Google Italian tune up if you wanna learn more about the idea
    nikonNUT, Thegenerik1 and tinker_troy like this.
  3. Aug 9, 2018 at 10:30 AM
    #143
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Can you even lug an auto?
    tacoguy88 likes this.
  4. Aug 9, 2018 at 10:34 AM
    #144
    TireFire
    Olympic Peninsula
    So you're comparing an engine from 1975 to one from 2018. Surely they must be the same
    tacoguy88 and TFly like this.
  5. Aug 9, 2018 at 10:40 AM
    #145
    Joisey
    I will write this slowly because I know you do not read very fast. It is about lugging an engine, compared to excessive rpm, and both doing damage. You can do the same damage in a 2018 stick vehicle, except perhaps for the pinging. The computer can only retard the spark so far. It takes into account the vehicle being operated in a fairly normal manner.
    Gritz N' Gravy likes this.
  6. Aug 9, 2018 at 10:41 AM
    #146
    Joisey
    Not to the extent of doing damage, unless it is a true manual shift automatic.
  7. Aug 9, 2018 at 11:05 AM
    #147
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    OP drives an automatic
  8. Aug 9, 2018 at 11:07 AM
    #148
    Joisey
    I understand that the OP drives an automatic, but it was your question that I answered.
    Herniator likes this.
  9. Aug 9, 2018 at 11:09 AM
    #149
    B33
    B33 Well-Known Member
    2017 tacoma TRD Sport
    theres this crazy thing called a rev limiter you are fine it won't let you go passed redline
  10. Aug 9, 2018 at 11:21 AM
    #150
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    You brought a manual transmission issue into a thread started by a guy driving an auto.
    It’s good info, just not applicable to the OPs situation.
  11. Aug 9, 2018 at 11:27 AM
    #151
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I agree with some of you that if you rev your engine up to red line constantly it will most likely be more stress on your engine than keeping it under 5k or something, however I also don’t understand people who shift at 2.5 -3k (on a standard) unless you simply have nowhere to be and are intentionally going slow or are trying to squeeze every MPG out (go buy a Prius)... I have owned mostly cars and some that are relatively sporty over the years, and I admit I’ve brought the RPMs up to red line on a regular basis on all of those vehicles, including my Tacoma when needed, especially entering a highway. Never had an issue what so ever.. I’m not saying go out and intentionally beat the snot out of your cars but geez you don’t have to be a sally about it either.... If you’re paranoid then drive like an old lady If that’s your thing. If you hit the red line the engine will take it 99% of the time without any problems in my experience..Just drive the darn thing the way you have to and if it happens to get up in the RPM's so be it, the truck will do its thing too..
    TireFire likes this.
  12. Aug 9, 2018 at 11:28 AM
    #152
    TireFire
    Olympic Peninsula
    I guess the computer made you more retarded than the spark
  13. Aug 9, 2018 at 11:30 AM
    #153
    Joisey
    You started with the attitude, not me. If you want to be civil, I can be civil. If you want attitude, I have plenty to share.
    tacoguy88 and Herniator like this.
  14. Aug 9, 2018 at 11:31 AM
    #154
    tacoRenner
    tacoRenner Well-Known Member
    Sacramento, CA
    '11 Tacoma CrewCab TRD off-road
    LOL you sound like an idiot
    Thegenerik1 and Herniator like this.
  15. Aug 9, 2018 at 11:32 AM
    #155
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    You literally just covered every driving style known to man. And I learned nothing from it.
  16. Aug 9, 2018 at 11:33 AM
    #156
    TireFire
    Olympic Peninsula
    I didn't start making a personal insult. But I'm good with civil from this point on
  17. Aug 9, 2018 at 11:35 AM
    #157
    Joisey
    As am I. Question. Where did you find your avatar? I like it!
  18. Aug 9, 2018 at 11:45 AM
    #158
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    The engine is quite smooth at the high end of the RPM range. Again it'll do it. It won't likely throw it's guts out anytime soon. It'll last much longer if you take it easy on the engine. Lugging is bad for them too.
  19. Aug 9, 2018 at 11:50 AM
    #159
    TireFire
    Olympic Peninsula
    Google the Toyota TPMS warning light.
    Mine is constantly on because I have aftermarket wheels and sold the fugging sensors
  20. Aug 9, 2018 at 11:56 AM
    #160
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    yes very beneficial to run at high RPMs https://www.youtube.com/watch?v=mVkWA0uoYC8
