Is it OK to just use Denso Plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wmgeorge, Aug 3, 2021.
  1. Aug 3, 2021 at 6:49 AM
    wmgeorge
    wmgeorge [OP] Well-Known Member
    I purchased some Denso K20HR-U11 plugs but isn't OEM NGK & Denso? Is it ok to use these for the first plug change at 87,000 miles. This is a used truck and its never been done I think. 2015 V6 Automatic.
  2. Aug 3, 2021 at 7:16 AM
    mystert
    mystert Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    Stop over thinking and put them in, they are stock plugs, you will be fine. Copper plugs are to be changed every 30k so you are 57k overdue.
    Gunshot-6A likes this.
  3. Aug 3, 2021 at 7:21 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Yes, that’ll be fine. You can find a couple of message threads that talk about the possible/likely reasons that Toyota chose to do this, and none of them suggest to continue the practice. The main recommendation/opinion you’ll find is to stick with non-iridium plugs if that’s what was used stock. I just put a set of these same plugs into my Taco and they’re performing just dandy.
    wi_taco and Gunshot-6A like this.
  4. Aug 3, 2021 at 7:22 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Denso or NGK for tacomas, nothing else. So if you got any of these two, it's good
    Then if you don't know what to choose between copper, platinum or iridium, the only difference between them is their longevity. They don't give more HP or anything
    Copper is the cheapest but they also have the shortest lifespan. They must be replaced at about 30k miles intervals
    Platinum have a longer lifespan, needing to be replaced at about 100k miles
    Iridium are the most expensive of the bunch, but they can last for 120k+ miles
    DGXR likes this.
  5. Aug 3, 2021 at 7:23 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If you put the wrong plugs on the wrong side you'll get worse gas mileage but only when making turns on the side of the engine with the wrong plugs.
  6. Aug 3, 2021 at 7:23 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  7. Aug 3, 2021 at 7:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The denso's for the 2nd gen seem to wear better than the ngk cross part. So run the densos
    That stated the ngk half n denso in the other half stems way back with toyota, its just how they do things and makes it easy to see if someone has ever changed plugs.
    ardrummer292 and Gunshot-6A like this.
  8. Aug 3, 2021 at 7:37 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Your refrigerators running
    Better go and catch it :boink:
    Key-Rei[QUOTED] likes this.
  9. Aug 3, 2021 at 7:44 AM
    Key-Rei
    Key
    Florida
    Dang it not again...
    ROOMBA FRIDGE GET BACK HERE YOU'RE TOO DELICATE FOR THE REAL WORLD!
    :goingcrazy:
  10. Aug 3, 2021 at 7:45 AM
    wmgeorge
    FYI Not overthinking just checking, duh. I was debating having the Dealership change but in my 78 years I have always done my own. No reason to stop now.
    Thanks for the helpful replies and now it headed to stupid, time to stop the emails!
    Jimmyh and ardrummer292 like this.
  11. Aug 3, 2021 at 7:47 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Is the truck running bad? Why are you changing the plugs? I've taken vehicles close to 200K miles on original plugs with no ill effects. It's not like the old days when you had to change the points and plugs every 18K miles.
  12. Aug 3, 2021 at 7:50 AM
    Black DOG Lila
    Virginia
    Buy a Diesel
    Problem solved
  13. Aug 3, 2021 at 8:06 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Run them! If I was going to replace copper plugs in any engine, I would definitely spring for the long-life iridiums so I don't have to do it again for a long time.
  14. Aug 3, 2021 at 8:49 AM
    wmgeorge
    Yup I am a fan of Iridium's but when your 78 lifetime warranty is kind of over Kill :)
    tacoman45 and DGXR like this.
  15. Aug 3, 2021 at 8:54 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4
    Overbuilt daily driver
    @wmgeorge, I noticed the same thing as the quote above mentions. I'm not sure if this is because NGK gaps their plugs wider than Denso, or if it's because NGKs actually wear down faster than Densos. Either way, I replaced all my plugs with Densos. Copper plugs are the way to go if you want to avoid some of the fussiness that can reportedly come with platinum and iridium plugs.
    *Edited to add*
    Gap difference and observations in my build thread here:
    https://www.tacomaworld.com/threads/a-non-enthusiasts-tacoma-build.667560/page-2#post-23926818
    Dm93 and wmgeorge[OP] like this.
  16. Aug 3, 2021 at 6:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Many people have ran the stock copper plugs over 100k with no issues although I wouldn't recommend it. Some people have reported issues running Iridium plugs in the 4.0L, I'm not sure why but it doesn't seem to like them all that well.
