Is it ok to use spare tire with the stock tire and bigger wheel?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacorio25, Apr 24, 2023.
  1. Apr 24, 2023 at 3:45 PM
    tacorio25
    tacorio25 [OP] Member
    2020 Tacoma Off road
    Would I be ok to use the Stock wheel and upgrade to bigger a tire only? Or would I have to upgrade both the tire and wheel?
  2. Apr 24, 2023 at 3:49 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly you don't have to unless you're going up to 33-34"+
    If just going to less than 33" just run a standard spare and swap it to the front when/if a puncture happens.
    Steel rims are usually more narrow, so 265 would be max (limiting to 32") or run a 255/75r16 (33")
    Do you plan on long adventures? Or just standard fare stuff?
  3. Apr 24, 2023 at 3:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you keep the stock tire, why would you need to upgrade the wheel? Are you adding secondary shocks or spindle gussets?
  4. Apr 24, 2023 at 6:52 PM
    tacorio25
    Because I have 33s, and I'd like to have a full size spare. Just wasn't sure if I could keep the stock tire and just get a new wheel instead of getting a new wheel and tire
  5. Apr 24, 2023 at 6:55 PM
    tacorio25
    Ya I have 33s, I'm just finally getting around to getting a full size spare. And ya I go on longish trips, usually no more than a week
  6. Apr 24, 2023 at 6:56 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You want to keep the stock 31" spare tire but get a bigger wheel i.e. from the 16x7" steelie to a 16x8" or 16x9" alloy wheel?
    AmateurTaco1313 likes this.
  7. Apr 24, 2023 at 6:57 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Bro what are you trying to do?
    please do not try and STRETCH a tire onto a wheel it’s not made for.
    I was able to put a larger tire on my stock spare wheel 255/85/17
    Still the tires were made to fit a 17” wheel
  8. Apr 24, 2023 at 6:59 PM
    tacorio25
    I'm trying to see if it's possible to keep the stock spare rim, then get 33" wheel to fit on the spare rim.
  9. Apr 24, 2023 at 7:01 PM
    AmateurTaco1313
    ROK
    Enough for now
    you mean a 33” tire to fit on the spare rim? Yea that’s totally doable
  10. Apr 24, 2023 at 7:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    "Wheel" and "rim" are the same thing :smack:
    Looks like you want to know if a 33" tire can fit on the stock spare steel wheel. A 255/85-16 tire will fit. A 285/75-16 tire will not fit.
    BC Hunter and AmateurTaco1313 like this.
  11. Apr 24, 2023 at 7:02 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I think you mean tire. Yes, a 33” tire can be installed on the spare steel rim. The stock spare tire needs to be removed from the stock spare rim.
  12. Apr 24, 2023 at 7:04 PM
    BLtheP
    Plano, TX
    Why would a 285/75 not fit? Isn’t the spare 16x7?
  13. Apr 24, 2023 at 7:04 PM
    tacorio25
    Ya brain farting over here
  14. Apr 24, 2023 at 7:04 PM
    tacorio25
    Ya that's what I meant, brain farting
  15. Apr 24, 2023 at 7:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I looked through a few 285/75-16 tires on TireRack and they require a 7.5-9.0" or 7.5-9.5" wide wheel.
    BLtheP[QUOTED] likes this.
  16. Apr 24, 2023 at 7:09 PM
    BLtheP
    Plano, TX
    Interesting. Once again, discount tire’s website does not reflect what the manufacturers show.
  17. Apr 24, 2023 at 7:15 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm confused.
    What rim ( wheel) diameter do you have?
    What tire diameter do you want to install on that rim (wheel)?
    They need to be the same.
  18. Apr 24, 2023 at 7:21 PM
    tacorio25
    I'm running a 17x8.5 and 285/ 70R17, not sure what the stock spare size is, just trying to figure out if it's even ok to do
  19. Apr 24, 2023 at 7:57 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  20. Apr 25, 2023 at 5:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Stock size is 265/70R16 or 31".
    I'm on 35s and carry a 32" spare. Drove 300 miles home on the spare once at normal highway speeds. No issues other than having to hold the steering wheel a bit off-center. Adaptive cruise may or may not work. That's a 3" difference in tire diameter. Your 2" difference in tire diameter should be ok.
    tacorio25[QUOTED][OP] likes this.
