Is it okay to jack up a tacoma through the skid plate?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geo8866, Feb 26, 2022.
  1. Feb 26, 2022 at 6:36 AM
    geo8866
    geo8866 [OP] Unknown
    2019 TRD Sport cement
    https://youtu.be/HNw1neSUfAY
    I recently added the TRD skid plate to my 2019 sport model. I thought I would no longer be able to utilize the center front jack point because it is now covered by the skid plate. At 2:40 into this video, the guy uses the center jack point even though he has a TRD skid plate. Is that okay to do?
    Also, is it okay to jack the rear using the differential "pumkin" as he does?
    Thanks
  2. Feb 26, 2022 at 6:46 AM
    kderp
    kderp Well-Known Member
    Phila PA
    2021 Tacoma TRD Bro
    If you look on the instructions for the skid plate, it indicates there is a jacking point on it.
    geo8866[OP] likes this.
  3. Feb 26, 2022 at 6:46 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It might scratch/dent it but don’t see why it would be bad. I’ve lifted by the pumpkin many times. Just don’t jack on the drain bolt.
  4. Feb 26, 2022 at 6:51 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Use a 2x4 on the jack
  5. Feb 26, 2022 at 7:06 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Yes to both questions. This is the quickest way to get the truck up on 4 jack stands. Lift the rear using the pumpkin and put 2 stands under the rear axle. Lift at the front and put stands near the front wheels. Reverse to drop it back down again.
    Do not lift it by the pumpkin or front point and just start working on stuff without stands. You're asking for major trouble if you do.
  6. Feb 26, 2022 at 8:07 AM
    Chocaholic
    Chocaholic Well-Known Member
    I use a hockey puck.
    MadKatt, RustyGreen, Key-Rei and 2 others like this.
  7. Feb 26, 2022 at 8:10 AM
    geo8866
    Thanks to all. The hockey puck idea is great. I just ordered one on Amazon.
  8. Feb 26, 2022 at 8:11 AM
    Bishop84
    Bishop84 Well-Known Member
    It's ok but not my first choice. You gotta make sure you hit the spot 100%, and its harder to identify that spot with the skid in the way.
  9. Feb 26, 2022 at 8:19 AM
    geo8866
    I saw that but I always like to check with you presumably younger guys to verify. I'm almost 60. I still remember when the jack went into a little hole on a big chrome bumper.
  10. Feb 26, 2022 at 8:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    I remember 60. :p
    Remember the bumper slits too, for the lousy bumper jacks, which worked ok to change a flat, IF you were on a flat-ish hard surface.
    One of my first tool purchases after basic handtools was a used 4 ton floor jack and 4 jackstands.
    On my Miata I had to drive onto 3" ramps to get it high enough to get a low profile race jack under it. :D
  11. Feb 26, 2022 at 8:52 AM
    kderp
    Phila PA
    2021 Tacoma TRD Bro
    With your wisdom, you’d rather trust some hot shot on the internet than the documentation from the manufacturer??
  12. Feb 26, 2022 at 9:40 AM
    philth
    philth .
    geo8866[OP], beergeek and henryp like this.
  13. Feb 26, 2022 at 11:29 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Look at your skid plate. The jack point is labeled. Don’t worry about scratching it. It’s a skid plate. Scratches will separate you from the posers.
    geo8866[OP] and JJ Diablo like this.
  14. Feb 26, 2022 at 4:03 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If you remember 60. You weren't there.
  15. Feb 26, 2022 at 5:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    I didnt say 'the 60's'.
    And yeah I was there too, and remember just fine. :p
  16. Feb 26, 2022 at 6:43 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I jack up my truck with my RCI skid plates on no issues plus can still see the jack point from the side.
