is it okay to put jack stands on my skid plates?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Jun 7, 2010.
  1. Jun 7, 2010 at 11:17 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    im taking the front tires off today and i need to get the front end up but im not to sure where to put my jack stands.... can i put them on my skid plate or do i need to take them off?
  2. Jun 7, 2010 at 11:26 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  3. Jun 7, 2010 at 11:27 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I would recommend that you place the jack stands on the frame, right around where the crossmember is.
  4. Jun 7, 2010 at 11:28 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    You can do it if you don't care about having a truck on your head.
  5. Jun 7, 2010 at 11:29 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    But if they are stock, then no.
    Put the jack stands under the frame. DO NOT put them under the lower control arms. That may work in a pinch, but I speak from experience when I say you don't want to get under that vehicle.
    If the stands don't reach, get bigger stands. If not then get some wood blocks. They will work if you make sure the vehicle is stable when you rock it back and forth.
    Consult the truck's manual for jacking points if you're still confused.
  6. Jun 7, 2010 at 11:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Absolutely NOT! Even if you remove the skid plate, there's nothing under that you can jack from.
    Look in your owners manual. THere's a diagram in there that tells you exactly where to put jackstands.
  7. Jun 7, 2010 at 11:45 AM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    sweet thanks for the advice!
  8. Jul 18, 2010 at 12:11 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    I was just double-checking this before I started tire rotation (because the owner's manual only provides jack points for flat tire chaning purposes, not jackstand setup), and noticed that the FSM link provided in post #3 above is not for 1st gen.
    The 1st gen manual (well, 2003 FSM) is on page IN-8 and is different than the 2nd gen.
    Attached for your reference...and safety.
  9. May 15, 2011 at 8:50 AM
    ywen
    ywen Well-Known Member
    hmm the FSM shows one central lift point in the front.. what if I just want to get one tire up? can I lift it on just one side and put the jack underneath?
