Is it possible for a airplane to take off from a treadmill?
Discussion in 'Off-Topic Discussion' started by WPDAWG11, Apr 7, 2013.
  1. Apr 7, 2013 at 4:19 PM
    #41
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    also look at the plane they used in myth busters. The prop is clearly positioned under the wings. So how would it make lift then if its underneath the wings?!?!?!
  2. Apr 7, 2013 at 4:19 PM
    #42
    Bandit196
    Bandit196 Well-Known Member
    Ross
    Denver, CO
    '09 DCSB
    OME 885's, N140's front, N182 rear with Dakars , 275/70R17 BFG T/A KO on 17x8 Yuma 908B's
    Hey man, I'm just tryna help you out, no need for that. My point is that regardless of the type of engine or propulsion on the wing or fuselage, it's gonna take off.
  3. Apr 7, 2013 at 4:19 PM
    #43
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    Well duh, because you have a difference in velocity between the fixed object (plane wings) and the air... Generating lift...
  4. Apr 7, 2013 at 4:20 PM
    #44
    tostidos
    Apple Valley, CA
    07 LT 6spd
    :violent:
  5. Apr 7, 2013 at 4:22 PM
    #45
    teneighty
    Check out my Build
    So you saying you put a plane on a huge conveyer... Then accelerate the plane so that you are staying in the same position on the belt...
    You will fly???
  6. Apr 7, 2013 at 4:23 PM
    #46
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    think of a fan boat... it moves foreward, that's all the prop does is move the boat, or on a plane pull the plane fast enough until the wings can lift/fly.
    its about speed through the air for lift, not ground speed actual
  7. Apr 7, 2013 at 4:23 PM
    #47
    Bandit196
    Ross
    Denver, CO
    '09 DCSB
    No, I'm saying that you put a plane on a huge conveyer... then accelerate the plane, it's gonna MOVE FORWARD and take off just like it would if it was on a runway.
    And then fly!!!
  8. Apr 7, 2013 at 4:26 PM
    #48
    teneighty
    Check out my Build
    I understand that but these guys seem to think that the plane won't move on the treadmill... If you give any thrust to the plane it will still move over the ground because there is very little resistance due to the tires rolling on the ground.
  9. Apr 7, 2013 at 4:27 PM
    #49
    tostidos
    Apple Valley, CA
    07 LT 6spd
    The experiment is with equal speeds. and to stay stationary you could probably be at idle or 1-5% throttle to get rolling. much like taxiing an aircraft around the airport. Of course planes dont fly at taxi speeds.
  10. Apr 7, 2013 at 4:27 PM
    #50
    teneighty
    Check out my Build
    Ooops... I was under the impression you thought it was staying in one spot...
  11. Apr 7, 2013 at 4:28 PM
    #51
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    X2
    With enough thrust, a pig will fly.
    For lift from a wing, it requires airflow over the wing, so the wing can re-direct it downward, sending the wing upward.
  12. Apr 7, 2013 at 4:29 PM
    #52
    Bandit196
    Ross
    Denver, CO
    '09 DCSB
    Hell no haha, that wouldn't work at all. I see now why we weren't on the same page.
  13. Apr 7, 2013 at 4:32 PM
    #53
    teneighty
    Check out my Build
    :sorry:
    Haha can you understand my frustration?!
  14. Apr 7, 2013 at 4:34 PM
    #54
    tostidos
    Apple Valley, CA
    07 LT 6spd
  15. Apr 7, 2013 at 4:34 PM
    #55
    teneighty
    Check out my Build
    Well, good to know TW is full of aeronautical engineers
    :facepalm:
  16. Apr 7, 2013 at 4:36 PM
    #56
    Bandit196
    Ross
    Denver, CO
    '09 DCSB
    haha on that note... time for beer.
  17. Apr 7, 2013 at 4:37 PM
    #57
    tostidos
    Apple Valley, CA
    07 LT 6spd
    haha I sure could use one of those about now.
  18. Apr 7, 2013 at 4:38 PM
    #58
    Tacoyota
    08 4wd
    in the end mythbusters ran out of ideas, tried to confuse the audience or themselves with nothing relelvant.
  19. Apr 7, 2013 at 4:40 PM
    #59
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I still want to punch that pilot in the nads. :mad:
  20. Apr 7, 2013 at 4:53 PM
    #60
    patacoman2001
    patacoman2001 Member
    '01 4X4 sr5 Xtra cab
    What a giant waste of time by the Mythbusters.
    Seems like most aircraft could generate a lot more ground speed than they actually need to lift off.
    Let them find the top speed of that plane, then pull their giant tarp in the opposite direction at that same speed.. then guess what?
