Is it possible for a airplane to take off from a treadmill?
Discussion in 'Off-Topic Discussion' started by WPDAWG11, Apr 7, 2013.
  1. Apr 7, 2013 at 4:53 PM
    #61
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    +1 ^^this^^
    The prop/turbine or whatever source of propulsion (except drive wheels) has nothing to do with the lift component of a wing.
    Some people cannot disconnect the fact that an airplane's wheel are just bearings (without drive capability) to roll on the ground.
    The wheels/bearings can be spin in any direction regardless of the plane's indicated airspeed..... once the propeller/turbine has generated thrust, the wheel/bearing speed and whatever direction they're spinning no longer enter the equation.... relative to the ground.... or moving treadmill for that matter.;)
  2. Apr 7, 2013 at 4:56 PM
    #62
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    It was resolved, we are all super smart
    :deadhorse:
  3. Apr 7, 2013 at 4:59 PM
    #63
    File IFR
    Central MA
    LOL
    Yeah, I know, but there's always a non-believer out there.:D
  4. Apr 7, 2013 at 5:02 PM
    #64
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    More importantly.......will a boat on a conveyer belt fly?
  5. Apr 7, 2013 at 5:11 PM
    #65
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    But the treadmill is irrelevant because the plane is producing its forward velocity through the propeller or jet engine.
    The plane doesn't care how fast the GROUND is moving under it... all the plane cares about is the speed of the air.
    If the plane takes off at 100mph, and you move the treadmill at 100mph, then the plane will still take off at 100mph airspeed, and relative to you, the observer. The wheels will be spinning at 200mph, but it will fly just fine.
    If it were a car attempting to tow a glider into flight, then no... it would not take off on the treadmill because the car's wheels are the source of the forward velocity.
  6. Apr 7, 2013 at 5:12 PM
    #66
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Now that is some shit I would like to see!
  7. Apr 7, 2013 at 5:12 PM
    #67
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This^
    No lift no fly, the wheels can spin like crazy, unless there is lift it stays on the ground.
  8. Apr 7, 2013 at 5:15 PM
    #68
    Rich91710
    Rich
    Los Angeles
    08 Base
    Of course.
    What happens to your MPG when you drive your Taco at 75 compared to 55?
    Air resistance is a FAR greater factor than ground rolling resistance.
    One of my worst tanks should have been one of my best. Flat, level highway rolling 65. Under normal conditions, I would have pulled 25-26mpg. But I was rolling into a strong headwind from a storm system to the north.
    Barely maintained 22.. which is what I normally get in New Mexico and Texas rolling 80.
  9. Apr 7, 2013 at 5:16 PM
    #69
    Bandit196
    Bandit196 Well-Known Member
    Ross
    Denver, CO
    '09 DCSB
    OME 885's, N140's front, N182 rear with Dakars , 275/70R17 BFG T/A KO on 17x8 Yuma 908B's
    I believe the answer to that is 12.
  10. Apr 7, 2013 at 5:18 PM
    #70
    File IFR
    Central MA
    Here's an experiment that had me undecided before the outcome.... A jet attached to a skateboard blowing onto a sail.
    ... Will the jet move the skateboard to it's intended travel, or go 'backwards' towards the sail.. like a sailboat. :D
    http://www.youtube.com/watch?v=k3V0KKvXmcs
  11. Apr 7, 2013 at 5:18 PM
    #71
    teneighty
    What kind of boat? How big of an outboard?
    This is the correct answer ^
  12. Apr 7, 2013 at 5:19 PM
    #72
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I hit wind so fast in the Gorge here the dumbo eared front mudflaps twisted in the wind and one touched the tire at times, made a god awful squealing rub.
  13. Apr 7, 2013 at 5:19 PM
    #73
    Rich91710
    Rich
    Los Angeles
    08 Base
    From some of the answers, I think there may be some confusion in the parameters of the myth because the OP oversimplified the question.
    1 - If you put a plane on a treadmill and crank it to 100mph with the planes engine running and the brakes released > Yes, it will lift off and fly.
    2 - If you put a plane on a treadmill with the engine off, brakes off, and tethered at the nose so it can not move backwards and run the treadmill to 100mph > No, it will not take off and fly.
    3 - If you put a plane on a treadmill with the brakes locked and run the treadmill to 100mph, you're going to need to buy a new plane.
  14. Apr 7, 2013 at 5:24 PM
    #74
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Drankin makers on the rocks LMAO @ this thread
  15. Apr 7, 2013 at 5:24 PM
    #75
    Tacoyota
    08 4wd
    what you see with the sail is not accurate really. The sail did nothing but block air. Air spilling out the sides curled back and moved it forward. In other words... skip the sail and turn the damn fan around and do it right, more speed.
    Their logic would have a helicopter flying higher if it had a fake ground strapped under it to fly higher.
  16. Apr 7, 2013 at 5:30 PM
    #76
    File IFR
    Central MA
    True, I'm aware of it. I can't seem to find the outcome of the test... they stop short of it in the vid. :mad:
    Note, the sail IMHO, is too far away from the engine to become a "thrust reverser" of sorts.
  17. Apr 7, 2013 at 5:31 PM
    #77
    Tacoyota
    08 4wd
    yea, im getting old enough to almost have missed it.
    you made a good call on thrust reverser, it explains it better.
  18. Apr 7, 2013 at 5:34 PM
    #78
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Wow, Tundras are used by Mythbusters, Tundras pull space shuttles. Whats next?
  19. Apr 7, 2013 at 5:36 PM
    #79
    Rich91710
    Rich
    Los Angeles
    08 Base
    It was actually confirmed... worked like the cartoons did, but it was not terribly efficient.
    I don't recall their explanation for what happened, and I remember that it blew everyone's minds... none of the cast expected the outcome they got.
    With a jet engine, it works as a thrust reverser because the jet heats the exhaust so you have a higher pressure on that side compared to the intake... same way a full scale thrust reverser works.
    The mind blower was that it worked with the electric motor spinning the prop. Newton's law says that it should not have moved, so there had to be "something else" going on.
  20. Apr 7, 2013 at 5:37 PM
    #80
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Well, the mythbusters episode isn't really accurate because the plan is moving faster than the tarp allowing the plane to apply a higher amount of thrust and as soon as the plane started that it wasn't in contact with the conveyor so its still unproven...
